Orthomosaic - PIX4Dmatic
This article provides detailed information on generating orthomosaics using PIX4Dmatic, including processing options, quality settings, and export settings.
Orthomosaic
Create an orthomosaic based on the digital surface model (DSM) and the images.
Note: since version 2.4.0, processing can be paused and resumed at any time as long as the project remains open. There is no need to cancel and start over. If processing is paused and the project is about to be closed, the following message will appear.
- Click Processing options
and enable the Orthomosaic option. - On the Menu bar, click Process > Orthomosaic...
OrthomosaicResolution
Algorithm
Blending algorithm
Oblique
Mask-aware
Visualization
Applying the Region of Interest (ROI) for cropping
Exports
Export JPG format settings
Export GeoTIFF format settings
Orthomosaic
It allows users to change the following processing options depending on the sensor type.
Orthomosaic using RGB images
Orthomosaic using thermal images
These parameters are specific for thermal orthomosaic.
Ambient air temperature. The software uses the flight-time air temperature to correct for infrared radiation emitted and absorbed by the air between the drone and ground.
Apparent reflected temperature. This accounts for the thermal radiation originating from the surrounding environment that bounces off your target object and into the drone's camera. For low-emissivity surfaces, radiation detected by the camera may be reflected from the sky or nearby structures. Entering this value enables the software to subtract the reflected environmental heat and isolate the target’s true temperature.
Ambient humidity. Ambient humidity: Water vapor in the atmosphere absorbs and emits infrared radiation. Relative humidity at flight time is used to correct for that atmospheric effect between the camera and the ground.
Scene emissivity. It measures how efficiently a material emits its own thermal energy. From 0 to 1, this value can be chosen from materials presets or can be introduced manually using the Custom option. Each material has their own emissivity value.
- Current material presets: asphalt, clayey soil, dry concrete, dry herbs, sand soil, shrubs, slimy soil, solar panel, tree, water, and wet herbs.
- Since one emissivity value is applied to the entire map, mixed scenes (e.g. soil + roads) can’t all be correct at once, so users should choose what matters most for their analysis.
Note: Settings are only available when thermal conditions can actually be read from the images (for DJI radiometric JPEGs this depends on the DJI Thermal SDK).
Resolution
- Resolution: Defines the spatial resolution used to generate the orthomosaic. The orthomosaic resolution is the same as the resolution of the DSM. For example, if the DSM resolution is set to 5 cm, then the orthomosaic resolution will also be 5 cm.
Algorithm
- Algorithm: Allows switching between the orthomosaic creation algorithms.
- Hardware accelerated (Default): The generation of the orthomosaic will be computed using a GPU-capable algorithm. This option can contribute to reduced processing time.
- Standard: The generation of the orthomosaic will be computed using the standard algorithm relying on the CPU.
Blending algorithm
- Minimal: Computes pixel color using a single or small number of input images.
- Full: Computes pixel color using all the input images.
- Deghost: Removes moving objects.
Oblique
Oblique (default - disabled): Enabling this option improves the orthomosaic for oblique projects.
Mask-aware
Applies a mask to exclude the elements from the orthomosaic. For a detailed understanding of how masks function within PIX4Dmatic, please refer to: Masks - PIX4Dmatic.
Note: Inconsistent results may arise if the mask settings for the orthomosaic and DSM differ. To ensure uniformity, regenerate the DSM to align the mask settings.
Visualization
The orthomosaic, whether RGB or thermal, can be viewed in both 2D and 3D to examine the generated result from different perspectives.
Visualization of RGB orthomosaic
| Visualization in 2D | Visualization in 3D |
Visualization of thermal orthomosaic
The thermal orthomosaic can be visualized using three shading modes: Color map, Hillshading (Greyscale), and Combined. A Z factor slider controls the vertical exaggeration of the visualization.
Additionaly, there are different color in the color palette to represent the temperatue values in the orthomosaic.
| Thermal | |
After processing the Orthomosaic, whether is RGB or thermal, the Region of Interest (ROI) can be applied to clip the output to a specific area of the project. This reduces the file size and saves time, as reprocessing is not required.
From the content panel, in the Orthomosaic section, the option Apply region of interest becomes available from the three-dot menu after a Region of Interest has been drawn.
This feature is available from Version 2.7.0.
Exports
The following formats are available when exporting the orthomosaic:
Tip: Use the JPG file format to ensure small file sizes and compatibility with image viewers. JPG files are not geolocated.
For the JPG format, the following export settings are available:
- Quality (90% - default): Defines the compression of the exported file and the JPG quality setting.
- 90%: The default quality value is set to 90% as it is almost indistinguishable from the quality of 100% but the image file created is twice as small.
- 100%: A quality of 100% results in the highest quality but the largest file size, indicating low compression.
- 0%: A quality of 0% results in the smallest file size but very low quality, with the highest compression.
- Image size (L- default): Defines the size of the exported file.
- L: Provides the best quality at the highest resolution achievable with JPEG, but may require more time and memory to open in third-party software. The image retains its original size unless it exceeds the max JPG size of 65535 × 65535 px (~17 GB uncompressed).
- M: A balanced resolution suitable for most applications that does not require maximum detail. The exported image has a max size of 16000 × 16000 px. Larger images are downscaled.
- S: Ideal for quick viewing, sharing via email, or on the web. The exported image has a max size of 4000 × 4000 px. Larger images are resized to fit within the 4000 × 4000 px limit.
Example: For a file with the original size of 7172 × 6117 pixels, the exported file with Image size:
- L: 7172 × 6117 pixels (Image scale 100%).
- M: 7172 × 6117 pixels(Image scale 100%).
- S: 3586 × 3058 pixels (Image scale 50%).
Tip: Use the GeoTIFF file format to create a geolocated orthomosaic.
For the GeoTIFF (.tiff) format, the following export settings are available:
- Compression (LZW - Default): Defines the compression of the exported file.
- None: No compression is used during the export, resulting in a larger file size.
- LZW compression: No data is lost during the compression of the file (lossless compression) and the .tiff is not degraded. This results in a smaller file size of the exported file.
- JPEG compression: Slight degradation of the .tiff file (lossy compression). The file size is much smaller compared to LZW compression or no compression options.
- File Type (Single - default):
- Single: The image will be exported in a single file.
- Tiles (2048 px - default): The image will be exported in tiles with a predefined size of 1024 px, 2048 px, or 4096 px. The origin of the tiles is the top left corner of the project boundary.
- Image Scale (100%- default): Defines the scale of the exported file.
- 100%: The exported image will keep the original size.
- 50%: The exported image will be scaled to 50% of the original size.
- 25%: The exported image will be scaled to 25% of the original size.
Example: For a file with the original size of 10000 x 10000 pixels, the exported file with Image scale:
- 100%: 10000 x 10000 pixels.
- 50%: 5000 x 5000 pixels.
- 25%: 2500 x 2500 pixels.
- Transparency. Select if the orthomosaic is exported with or without transparency to improve compatibility with third-party software.
- Export CRS. The image will be exported using one of this CRS:
- Project CRS.
- Web mercator.
KML: Tiles and KML/KMZ to import into Google Earth
Note: The KML/KMZ files imported into Google Earth must comply with Google´s guidelines*:
- Unzipped KML and KMZ files can be up to 1GB
*Disclaimer: This link leads to an external website that is not affiliated with Pix4D. Responsibility for the content, security, and privacy policies of third-party sites lies solely with the respective owners.
Tip: To reduce the size of the file, export the orthomosaic at 25% Image scale. If the file is still larger than 1Gb, generate lower resolution DSM and Orthomosaic (by setting Custom resolution for DSM) and re-export them to KML/KMZ.
- Save as...:
- Single: Specifies the path and the file name of the exported file.
- Tiles: Specifies the destination folder.
- On the Menu tab, click File > Export orthomosaic...
- In the Export orthomosaic dialog, select the export settings.
- Click Export.
