Download and installation - PIX4Dmatic
Download
PIX4Dmatic can be downloaded from three different locations.
Note: The version to download will depend on the expiration date of Support and Upgrade
Installation on Windows
Once the software has been downloaded, install it using the following steps:
1. Double-click the downloaded file. The PIX4Dmatic Setup wizard starts.
2. (optional) If the pop-up Open file - Security Warning appears, click Run.
3. In the pop-up PIX4Dmatic Setup, in the screen Welcome to the PIX4Dmatic Setup Wizard, click Next.
Pix4Dmatic setup wizard
4. Read and agree to the End-User License Agreement to continue the installation. Click Next.
5. (optional) Click Change... to change the destination path for the installation and click Next.
6. Click Install.
7. (optional) In the software information window: "Do you want to allow this app to make changes to your device", click Yes.
8. Click Finish.
If Launch PIX4Dmatic is selected (default) in the PIX4Dmatic Setup wizard, then the software will be launched automatically. Otherwise, open the software using the Windows Start menu.
Note: If PIX4Dmatic 2.2 (or older) is installed on Windows, installing version 2.3 (or newer) may cause a "Setup failed" error. To resolve this, uninstall the older version before installing the newer one.
For more information, Setup Failed: How to upgrade to PIX4Dmatic 2.3 or newer from an older version on Windows
Installation on macOS
2. Drag and drop the PIX4Dmatic logo into Applications.
Pix4Dmatic macOS install
3. Navigate to Finder and click on the tab Applications.
4. Double-click PIX4Dmatic to run the program.
5. (optional) If the pop-up appears, click Open.
Can PIX4Dmatic run on AWS or Microsoft Azure?
PIX4Dmatic is not tested for use in remote or virtualized environments such as Amazon Web Services (AWS) or Microsoft Azure. As a result, these configurations are not officially supported.
While it may be possible to run and process projects successfully in these environments, behavior and performance cannot be guaranteed. Pix4D technical support is unable to assist with setup, configuration, or troubleshooting related to AWS or Azure deployments.
