Technical release notes (1.XX) - PIX4Dmatic
This article summarizes PIX4Dmatic version 1.0 through 1.86. This includes new capabilities, additional updates, and bug fixes.
Download the latest or authorized older PIX4Dmatic versions from the Download page after signing in with your license account. For more information click here.
Version 2.0
To access PIX4Dmatic 2.0 technical release notes please visit: Technical release notes (2.XX) - PIX4Dmatic
| Version | Release date | Release Type | Installers |
| 1.86.0 | December 2, 2025 | Stable | Windows | Mac |
1.86.0
Additional Updates and Improvements
- The “Process in PIX4Dcloud” workflow now uses the current coordinates from the camera table, enabling the processing of images where geolocation was imported (e.g., via CSV) or modified
- Added undo/redo support for vertex placement when drawing geometries and ortho patches in the 2D view
- Unified the behavior of the Esc and Enter keys across all 2D creation tools (ROI, orthomosaic patches, polylines, and polygons) and selection modes
- Coordinates in the status bar now display the elevation at the hovered location in both display and project CRS units
- Views in the custom report now preserve the original projection mode (perspective or orthographic)
- Automatic tie points (ATPs) are no longer affected by Terrain or ASPRS class coloring and visibility settings
Information
- Small GeoTIFF files are exported again in a standard TIFF format compatible with mainstream viewers.
Bug fixes
- Fixed an issue where a backup file created by a newer version of the software was incorrectly deleted when opening the project in an older version
- Fixed an issue where invalid coordinate or orientation accuracies were not replaced by default values when importing OPF or PIX4Dmapper projects
- Fixed an issue where importing image geolocation reset the position accuracy to default values if the imported file did not contain accuracy data
- Fixed an issue where orthomosaic patches could be misplaced in certain cases when the orthomosaic was generated using a region of interest
- Fixed an issue where measurement labels in the 2D view did not update when changing the display unit
- Fixed an issue where the region of interest (ROI) interfered with drawing polylines in the 2D view
- Fixed the color of the polygon preview in the 2D view when the active layer is hidden
- Fixed an issue where the DSM was hidden and displayed incorrect elevations when reopening projects with non-metric units
- Fixed an issue where “Process in PIX4Dcloud” incorrectly geolocated projects using left-handed coordinate systems
- Fixed an issue where the column format in the import dialogs did not consistently update to reflect the selected columns
- Increased the size of the scale constraint input field to accommodate up to 6 digits
- Fixed an issue that caused LAS and XYZ point cloud exports to be empty when filtering by an ASPRS class
- Fixed an issue where the image viewer did not correctly sort images to show those with marks on top when selecting a marker
- Fixed an issue that prevented inserting a vertex on a polyline edge between two vertex tie points (VTPs) in the 2D view
- Improved the logic for the auto-selection of point cloud inputs in the processing panel to prevent invalid configurations when applying templates
- Fixed an issue where the progress bar would run from 0% to 100% twice during DSM creation when using automatic tie points (ATPs) as the input
- Fixed an issue where uncalibrated cameras were not correctly displayed as input cameras after removing the project calibration
- Fixed an issue where moving a polygon between layers could result in duplicate polygon names
- Fixed an issue related to the minimum and maximum values in the exported DSM, which made it incompatible with some third-party software.
- Fixed an issue where non-fatal internal errors could cause the densification process to fail
- Fixed a crash that could occur during mesh generation when estimating the point cloud scale
- Fixed an issue where PIX4Dcloud project links, generated after sharing or processing, would not open a web browser
| 1.85.0 | November 11, 2025 | Preview | Windows | Mac |
Disclaimer: The preview version contains new features and bug fixes. Documentation and support are not available. We recommend testing the preview version before using it for production work.
1.85.0
New Capabilities
- Added a new dialog to select both the organization and license type after logging in
- Custom ASPRS classes can now have their id set manually
- The orthomosaic generation now respects the region of interest (ROI), allowing the orthomosaic area to be restricted without regenerating the DSM
- Added an “Ortho mode” button to the section view toolbar to easily toggle 90-degree angle vectorization
- Added Ukrainian as an available language
- Split processing options in the processing panel, moving advanced settings under a new "More options" button
Updated the processing option logic in the PIX4Dcloud "Process" tab:
The "PIX4Dcatch" option is now disabled for drone-only projects
Mixed (drone + PIX4Dcatch) projects now default to "Nadir" and display a warning, as this combination is not officially supported. The "Oblique" and "PIX4Dcatch" options remain enabled
- Added a validation to block project uploads to PIX4Dcloud if the horizontal and vertical CRS units do not match
- Improved the mesh generation to avoid gaps between adjacent tiles
- Improved the mesh generation for merged projects to better handle varying point cloud densities
Made several improvements to the orthomosaic editor:
The visibility of patch borders can now be controlled independently from the patch content
Patches are now always rendered as flat horizontal polygons in the image viewer
- Added an option to export the orthomosaic without transparency to improve compatibility with third-party software
- Updated the drag-and-drop behavior for folders: project files (e.g.,
.opf) are now detected and opened directly, which also allows for opening multiple projects in one operation - Improved camera support:
Added more robust focal length reading from EXIF data
Included support for Skydio-specific GPS accuracy
Refined minimum GPS accuracy for DJI cameras
- Updated project calibration behavior to properly integrate GCPs for georeferencing when input DJI RTK imagery is tagged with too-high geotag accuracies
- Added new menu options to the ASPRS class panel to toggle class visibility, switch between RGB/monochrome view, and remove classification
- Polygon vertex tie-points are now rendered in the 2D view
- The quality report now correctly displays the DSM interpolation strategy
Added support for two new geoid models:
Norway/Svalbard: Svalbard_EGG2015_2024
Netherlands/Bonaire: BONGEO2004
- Changed the "Add keyframe" shortcut to Ctrl+K
- Updated the user account menu: "Organizations" is now "Organizations & licenses", "Licenses" is now "Plan and licenses", and icons were added for external links
- Improved the error message when trying to re-upload to a project with a different CRS
Bug fixes
- Fixed a crash that could occur when exporting an orthomosaic with large empty regions into multiple tiles
- Fixed an issue where DSM generation could get stuck or crash when using the “Expand area” option if all point cloud points were above the cameras
- Fixed an issue that prevented users from entering certain characters in the custom report input fields
- Fixed an issue where the sky background would flicker in orthographic mode
Fixed several issues related to mesh generation:
Corrected an issue that could cause the surface to be trimmed too aggressively in datasets with very different point cloud densities
Addressed a rare issue where the mesh generation algorithm could spend considerable time estimating the point cloud density
Resolved an issue that caused long processing times during mesh generation for non-axis-aligned corridor projects
| 1.84.0 | October 21, 2025 | Preview | Windows | Mac |
1.84.0
New Capabilities
- Added the FBX mesh export format
- Added support for the visualization, creation and edition of polygons in the 2D viewer
- Added a new “Expand area” option to the DSM generation, which extends the surface model to cover the full area visible by the cameras and maximizes orthomosaic coverage
- Added vertex editing tools (move, insert, delete) for patches in the orthomosaic editor, enabling more precise adjustments before applying changes
- Improved the usability and visual feedback of the orthomosaic editor with better image sorting, component visibility, and processing indicators
- Accelerated the export of Cloud Optimized GeoTIFFs and the sharing of DSM and Orthomosaic outputs to PIX4Dcloud, with gains of up to 300x for certain project types like corridors
- Renamed the “Share” button to “PIX4Dcloud” to reflect that the dialog now supports both “Share” and “Process” options
- Updated application icons on macOS to follow the macOS 26 style guidelines
- Improved the error message displayed in the processing panel when the "Start" button is disabled due to a missing point cloud selection for the DSM, outlier removal, or mesh steps
Bug fixes
- Removed the maximum width restriction for the side panels
Fixed an issue that could cause the second upload of layers to fail
Fixed an issue where the “View project in PIX4Dcloud” links and menu options were not working correctly
- Fixed an issue in the orthomosaic editor where applying a patch could create repeating tile artifacts
Fixed several issues in the point cloud registration process:
The dialog now correctly remembers previously selected markers when it is reopened
Trajectories and sensor positions are now correctly handled during registration
- Fixed an issue where the animated logo did not display in the 2D view when opening large projects
- Fixed an issue where opening and then immediately closing a project could prevent it from being reopened
- Fixed an issue where timeouts could occur during hardware-accelerated orthomosaic generation
| 1.83.0 | September 30, 2025 | Preview | Windows | Mac |
1.83.0
New Capabilities
- Added a new Orthomosaic Editor to manually refine and correct artifacts in the orthomosaic
- When processing on PIX4Dcloud, Gaussian splatting now supports drone and other non-fisheye datasets
- Added the ability to choose the destination (folder, site, or existing project) when uploading a project to PIX4Dcloud
- Projects processed on PIX4Dcloud now produce a scalable mesh
- Added a 3-point method for creating circles (by defining three points on the circumference)
- The Oblique processing template is now automatically selected when a project is detected as an oblique dataset (i.e., more than half the images have a nadir angle over 20 degrees)
- Renamed the "Image pre-processing" step to "AI tools" and moved it to after the Orthomosaic step in the processing panel
- Merged the “Share to PIX4Dcloud” and “Process in PIX4Dcloud” dialogs into a single, unified “PIX4Dcloud” dialog.
- Added support for hardware acceleration for orthomosaic generation on Intel Arc GPUs
- Added the horizontal projection distortion factor to the information popup for the “Distortion-aware measurements” setting
- Added an “Open project” option to the project context menu on the welcome page
Bug fixes
- Fixed a texturing issue that could cause visible seams along mesh tile boundaries in some datasets
- Fixed an issue where marking a checkpoint caused the project to become outdated
- Fixed an issue where orthomosaic generation with hardware acceleration could unexpectedly abort just before finishing
- Fixed an issue where an incorrect file extension was displayed for Quality report exports when importing a processing template that contained multiple report formats
| 1.82.0 | September 09, 2025 | Preview | Windows | Mac |
1.82.0
New Capabilities
- Added site localization for projects in an arbitrary coordinate reference systems (CRS) with GCPs, by adding an “Image-based site-localization” in the “File ->Export” menu
- The properties panel now opens automatically when you select a different object. This behavior can be disabled in the preferences dialog
Added support for new camera models:
SHARE SLAM S20 (LiDAR)
DJI Mini 4 Pro
DJI Air 3S
Fujifilm GFX100S II
- Added the ability to change the size of the automatic tie points (ATPs) in the 3D view
- The SHIFT key can now be used to extend color selection
- The side panel can now be moved and docked to new locations by dragging and dropping it to the top or bottom of the sidebars
- The label column in the tie point table can now be sorted alphabetically or numerically
- Hovering the cursor over an object in the 2D view now displays its coordinates
Improved handling of projects with excessively long file paths:
A warning is now displayed when a file path is too long
To improve stability, processing steps (e.g., calibration, DSM, and orthomosaic) and exports are automatically disabled for projects located in long file paths
- Hovering over or selecting a calibrated camera in the camera table now also highlights it in the 2D and 3D views
- Increased the stability of the densification process by preventing crashes from insufficient GPU memory
Bug fixes
- Fixed an issue where cameras that were uncalibrated then calibrated still appeared as uncalibrated in the 2D view
- Fixed a crash that occurred when importing an unsupported or corrupted LAS file
- Addressed a stability issue that could cause a crash when opening certain projects
- Resolved an issue that prevented projects from being opened from network drives on Windows
- Corrected the display of the orthoplane in the section view
- Fixed incorrect filenames when exporting a mesh to Cesium format from a project containing special characters in its name
- Resolved a rendering issue where the point cloud would not display correctly after adjusting the minimum number of matches setting
- Fixed an issue with the vertical CRS (Coordinate Reference System) for DJI M3D datasets
- Addressed an issue that could occur when recalibrating a project after images had been removed
| 1.81.1 | August 27, 2025 | Stable | Windows | Mac |
| 1.81.0 | August 13, 2025 | Stable | Windows | Mac |
1.81.0
New Capabilities
- Faster mesh generation: Mesh generation is 20% faster in version 1.81 when compared to earlier versions.
- Polygons passed to the DSM generation are now used to estimate the automatic region of interest
- The mesh quality setting is now saved in the processing template
- Improved densification normals quality for some datasets, mostly drone datasets with larger GSD.
- Better point cloud completeness for mixed aerial and terrestrial datasets
- Improved performance when adding new layers, placing markers, and creating geometry in projects with a large number of existing layers
- Improve the zoom behavior in the 3D view when using a touchpad
Bug Fixes
- Paths have been removed from processing templates
- Bug fixes in DSM generation
- Fixed an issue where some onboardings in the toolbar would be shown again after confirmation
- Fixed "Import images from folder" not working
- Fixed bad GCP matches being added by default to the merge projects dialog
- Fixed pixels being non-square in the full-screen view of the image viewer
- Fixed an issue where automarking would fail to properly center images in full-screen mode
- Fixed some UI components being disabled after a failed import of a PIX4Dmapper project
- Fixed JPEG compressed TIFF images not being displayed in the image viewer
- Fixed an issue where the Welcome view did not suggest a project CRS based on the imported images when a default CRS was set and the corresponding checkbox was unchecked
- Fixed some issues related to the inventory snapshots of the custom report:
- Volumes are now rendered with the volume tin
Circles are now always fully visible
- Fixed an issue where the point cloud registration onboarding would be hidden if the content panel is docked to the right or as a window
- Fixed an issue where the export image geolocations & orientations dialog would truncate text for some languages
- Fixed an issue where closing some projects while they are currently loading could cause a crash and data loss.
- Fixed a crash that would occur when creating geometries in the 2D view if automatic tie points were not loaded
- Fixed an issue where layers would stay disabled after editing a vertex
- Layers, point clouds, and orthomosaics that are importing or processing no longer show in the content panel until they are finished
- Fixed the UI freezing when selecting a large closed polyline
1.81.1
Bug fixes
- Fixed a crash on project opening
- Fixed a crash that occurred when importing an unsupported or corrupted .las file
- Fixed an issue with opening projects from network drives on Windows
- Fixed an issue where the orthoplane was not displayed in the Section view
- Fixed an issue where successfully calibrated cameras were incorrectly displayed as uncalibrated in the 2D view
- Fixed an issue where projects not using meters would show incorrect metrics in the report panel
- Fixed an issue with incorrect file names when exporting the mesh in Cesium format from a project with special characters in its name
Version 1.80
| Version | Release date | Release type | Installers | |
| 1.80.0 | July 22, 2025 | Preview | Windows | Mac |
1.80.0
What's new
- Added the ability to import images without any EXIF tags
- Added a polygon-aware setting to the DSM generation to better fill sparse areas of the input point cloud and reduce noise
- Added the estimated project area after calibration in the UI and quality report
- Added 2D and 3D area properties to closed polylines
- Improved outlier removal processing step by adding a neighbors count parameter
- Significantly improved import speed for images with EXIF tags
- Added the CSV and LandXML export formats for volumes
- Added options to export the scalable mesh as a single OBJ file and to select the exported level of detail
Improved geometry import and export:
File → Export → Layers has been renamed to Geometries
Exporting markers as CSV now allows a custom format to be set and includes a new column option ‘Layer’
Importing markers as CSV now allows selecting ‘Layer’ as a column option. Markers will be imported into new layers based on the column values
- Added export of CAM and SSK files to the export of undistorted images for stereo photogrammetry
- Improved the volume calculation experience by disabling it when no point cloud is visible
- Added link to “Ask Pixie” in the welcome view and “Help” menu
- Improved usability in the welcome view: projects can now be opened with a double-click
- Improved disk space indicator to show the available space instead of the used disk space
Information
- Made the mesh upload in OBJ format optional for “Share to PIX4Dcloud”, which allows downloading it from PIX4Dcloud
- Improved the polygon selection tool for quicker vectorization
Bug fixes and improvements
- Fixed an issue with the region of interest’s vertical extent when importing projects from Pix4Dmapper or OPF
- Fixed “Share to PIX4Dcloud” not working for mesh uploads on Windows
- Fixed an issue where the new project CRS panel was incorrectly aligned for some languages
- Fixed issues in processing and exports when the path is too long on Windows
- Fixed an issue where the section view onboarding was no longer connected to the section view creation buttons
- Mitigated an issue where very long uploads could fail due to AWS token expiration
- Fixed an issue where the DSM generation could fail due to a tile split logic error
- Fixed an issue where lines would appear in unexpected locations in the 3D view
- Fixed the disk space indicator now shows the correct values when creating a new empty project
- Fixed the “Create clipping box from selection” action crashing in the presence of imported point clouds
Version 1.79
| 1.79.0 | July 1, 2025 | Preview | Windows | Mac |
1.79.0
What's new
- Added support for mesh and DSM/Orthomosaic generation from multiple point clouds
- Sections can now be created from the 3D viewer toolbar rather than the Section view panel
- Improved project loading time. For large projects, an animated logo is now shown in the 3D view while opening
- Added export of undistorted images
- Added disk space usage indicator to the processing panel
- Added support for importing Markers from point files (csv, txt, xyz) through File > Import menu
Various fixes and improvements for the quality report:
Extended CRS-related information is available in the quality report when exporting it as JSON
- Added tooltips in the content panel explaining why something is outdated
- Automatic tie points are not automatically selected when generating a DSM
- Added the ability to send notification emails to users
Added a new geoid model:
FIN2023N2000
Information
- Orthomosaic KML export with JPEG compression is no longer supported
- Exporting in multiple files is now restricted to KMZ format only
- Fixed an issue where the incorrect image was shown when switching tie points in the full-screen image viewer
- Fixed an issue where the opening time for some projects had increased
- Fixed generation of dense point cloud for merged PIX4Dcatch and drone projects
- Improved dense point cloud normals, particularly in drone projects
- Fixed unit values between the properties panel and the exported CSV file when exporting markers with different units for XY and elevation
- Fixed an issue where cancelling the LiDAR import would close the project
- Fixed an issue where importing WKT would fail if the unit name did not match the expected format
- Fixed polygon vertices moving much more than expected upon editing a vertex
Version 1.78
| 1.78.0 | June 12, 2025 | Preview | Windows | Mac |
1.78.0
What's new
Added support for importing PIX4Dmapper 4.x projects with a standard camera, including calibration and dense point cloud
- Currently not supported:
Projects that combine an arbitrary vertical and a well-known horizontal CRS for the output coordinate system
- Projects with a specified non-zero geoid height over the ellipsoid
- Added support for exporting and importing animation trajectories
- Improved the visibility of geometries by bringing them to the foreground and ensured the mesh reacts to the “objects occlusion” viewing option
- Added the export of the region of interest (ROI) as KML
Removed some limitations for the “Gaussian splat” in the “Process in PIX4Dcloud” dialog:
Removed the restriction requiring a minimum of 50 images
Removed the requirement to have depth and confidence data
- Added support for importing SBET LiDAR trajectories
Enhanced point cloud export options:
Multiple point clouds can be selected and merged into a single export
Points can be filtered by ASPRS class for export
- Added the ability to rename imported point clouds in the content panel
- Input cameras without orientation are now rendered as cuboids in the 3D view, distinguishing them from cameras with orientations
- Added a progress bar in the Dock icon on macOS during processing
Improved the triangulation method for tie point and vertices, as well as the computation of the reprojection errors
Expanded auto-mark functionality to support not only calibrated cameras but also input cameras, with activation possible after a single mark in most cases
Sorting images by reprojection error works for all types of geometries
- The position of marked MTPs and GCPs is now globally optimized by the calibration and reoptimize processing steps rather than triangulated afterwards. This method of computation is generally more accurate
- Added support for importing point clouds in arbitrary CRS into a project with a global CRS
- Fixed an issue with mesh generation when the path is too long on Windows
- Fixed an issue where tie points were no longer shaded in the 3D view
- Fixed an issue where custom color swatches could not be added for content panel color settings
- Fixed an issue where the user could not create a mask when the layer was empty
- Fixed an issue when importing geometries wouldn’t work for right-handed and non-isometric coordinate systems
Version 1.77
| 1.77.1 | May 23, 2025 | Preview | Windows | Mac |
| 1.77.0 | May 21, 2025 | Preview | Windows | Mac |
1.77.1
- Fixed an issue where point clouds filtered with the Outlier removal could not be used in processing
- Fixed tie point shading in the 3D view
1.77.0
What's new
- Removed the standard mesh pipeline; mesh generation now uses a quality setting with “Preview” and “Detailed” options
- Re-enabled SLPK export for scalable meshes
- Added support for multiple viewports to view the scene from various angles simultaneously
- Improved calibration performance on macOS
- Added a new option to the context menu to create a clipping box from the selected point cloud or geometry
- Added section direction indicator
- Added a new “Settings” entry to the menu bar
- Added a light theme to improve accessibility for users
- Added an easier way to remove multiple cameras: select them in the 3D view and press Delete (also available from the Edit menu)
- Added support for using a custom logo when exporting videos
A sensor model for DJI cameras can now be extracted from the EXIF if available
Updated support for ILX-LR1 cameras (all lenses), ILCE-7RM4 and Wingtra RGB61
Updated default parameters for ILX-LR1 24, 35, 50 and 70mm lenses
- Fixed several issues related to exporting the custom and quality reports on macOS
- Fixed a crash on project closure
- Fixed a crash when calibrating some merged projects
- Fixed a crash when reoptimizing and rematching some fisheye camera projects
- Fixed an issue where the manual point cloud registration dialog did not correctly store and restore the chosen markers
- Fixed an issue where the MSE registration error in the manual point cloud registration window would not correctly update when removing markers
Fixed various issues with the Image Viewer full-screen mode:
The toolbar is now always shown at the top
The global zoom slider and key shortcut Alt+MouseWheel now correctly work
The global zoom level is now used when opening or switching images in full-screen mode
Fixed an issue where the zoom would incorrectly reset when marking MTPs
- Fixed an issue where GPS time was not correctly included when exporting point clouds in LAS 1.2 format
- Fixed an issue where the CRS was not written when exporting TIN as LandXML
- Bug fixes and improvements for the densification and mesh generation
Version 1.76
| 1.76.1 | May 27, 2025 | Stable | Windows | Mac |
| 1.76.0 | April 24, 2025 | Stable | Windows | Mac |
1.76.1
What's new
- Geometries are now displayed above the 3D textured mesh
- Fixed the link to the support article in point cloud import dialog
- Fixed a small display issue affecting the ATP reprojection mark in the image viewer
- Fixed an issue where the manual point cloud registration dialog did not correctly store and restore the chosen markers.
Toolbar is now always shown at the top
The global zoom slider and key shortcut Alt+MouseWheel now correctly works
When opening or switching images in full-screen mode it will now use the global zoom level
1.76.0
What's new
- User confirmation is now requested before canceling a point cloud import
Japan: JPGEO2024
- Point clouds without normals can no longer be selected as input for the mesh generation
- Saving a copy of the project (File>Save copy…) now also saves a copy of the unsaved active processing template (template.json)
- Updated the point cloud point size slider to use a logarithmic scale
- The point cloud import dialog can now be resized
- The quality report is now available in German
- Added an onboarding GIF for the point cloud manual registration tool
- When a user cancels a project upload and the corresponding PIX4Dcloud project was not previously created, it will be removed
- Fixed an issue where tie points could not be marked on uncalibrated images in projects using an arbitrary CRS
- Restored the section line display in the image viewer when selecting a section geometry node
- Fixed an issue that prevented the dense point cloud generation in a merged project created in versions 1.74 or 1.75
- Fixed the update of the reprojection errors in the tie point table when importing marks while calibration is running
- Fixed the issue with automatic processing template and settings selection failing for projects in ft or ftUS
- Fixed an issue that prevented point clouds from becoming outdated when adding/editing tie points
- Resolved an issue preventing the drag-and-drop functionality for LAS/LAZ files within a project
- Fixed orthoplane issues:
The orthoplane pixel size now updates correctly when switching display units
Resolved an issue where the orthoplane pixel size used an incorrect value for processing when display units were set to feet
Fixed a rendering issue affecting small, low-resolution orthoplanes in the section view
- Fixed an issue where mesh generation was incorrectly enabled when no calibrated cameras were available
- Processing templates will now store and restore export paths relative to the project folder
- Fixed the issue where the "Gaussian Splat" upload option was occasionally incorrectly enabled or disabled due to a bug in detecting whether the cloud "credits" feature was active in the user’s account
- Fixed the issue where PIX4Dmatic occasionally uploaded projects to the user's "default" organization instead of the organization chosen via the "Switch organization" tool
- Fixed an issue where "Process in PIX4Dcloud" sometimes uploaded inconsistent tie point accuracy values, leading to processing failures in PIX4Dcloud
Known issues
- The SLPK mesh export format was temporarily removed for scalable meshes due to exporting issues
Version 1.75
| 1.75.0 | April 4, 2025 | Preview | Windows | Mac |
1.75.0
What's new
- Added a new workflow to import LiDAR point clouds for the mesh, DSM, and orthomosaic generation and which includes the following features:
New menu option to import point clouds (LAS/LAZ format).
Laser scanner trajectory file support in CSV format.
Normals calculation upon point cloud import.
Imported point cloud properties include the following LAS attributes: timestamps, acquisition type, and normals.
Imported point cloud rendering by normal or by acquisition time.
Point cloud manual registration.
Mesh, DSM, and orthomosaic generation from an imported point cloud.
Share an imported point cloud to PIX4Dcloud.
Export an imported point cloud.
- Added a point cloud outlier filtering step.
- Added actions to restore disabled point cloud points.
- Set the scalable mesh pipeline as the default for the mesh generation.
- Added Gaussian splat as an output option when uploading a project to PIX4Dcloud for processing.
- Added the export of automatic tie points (ATPs).
- Added support for arbitrary and user-imported image CRS.
- Added support for orientations in the omega-phi-kappa (OPK) format for camera import and display in the camera table.
Improved support for Skydio drones
Added support for GPS accuracies and GPS CRS Exif tags for Skydio X10 payloads.
Added support for the wide and narrow camera options of all Skydio X10 payloads.
- Added a new button in the content panel to focus on point clouds, geometries, sections, and constraints in the 3D viewer.
- Added a context menu (right-click) in the 2D view.
- Added a new option to choose a blending setting for orthomosaic texture generation.
- Added a feature that provides default values when internal camera parameters are missing.
- Lowered the minimum permissible GSD for orthoplane generation to 0.01 mm.
Added new geoid models:
Hungary: Geoid2014
Greece: GR_HEPOS2011
- Polygons with more than 50 vertices are now rendered in the image viewer.
Information
- Removed share links from the “Share to PIX4Dcloud” upload confirmation dialog. Share links must be generated on PIX4Dcloud.
- Disabled the export feature from trials, except for the quality report, log files, video animation, tie points, and camera parameters.
- Fixed an issue that caused projects created in PIX4Dmatic 1.73 (and before) to not calibrate correctly in later versions (as of 1.74).
- Fixed an issue preventing the sharing of scalable meshes to PIX4Dcloud.
Known issues
- The SLPK mesh export format was temporarily removed for scalable meshes due to exporting issues.
Versions 1.74
| 1.74.0 | March 13, 2025 | Preview | Windows | Mac |
1.74.0
What's new
- Exported geometries can now be saved as markers in DXF, SHP, GeoJSON, and CSV formats.
- Orthomosaic KML export is now a selectable format in both the processing panel export and File menu export dialogs.
- Improved dense point cloud generation by filtering noise on edges.
- Improved mesh trimming for the scalable mesh pipeline.
- Added export of the quality report in JSON-format.
Added the possibility to select how external camera parameters are optimized by the calibration.
Improved PIX4Dcatch and Interior scene calibration templates.
- Improved processing time when generating orthomosaic with masked with hardware acceleration.
- Various fixes and improvements for the quality and custom report.
- Added locking layer feature.
Added usage of masks for dense point cloud generation as well as for mesh generation, either standard or scalable pipeline.
Renamed “Apply to 3D” to “Measure in 3D”. Added algorithm presets for improved measurement results based on project characteristics.
- Added import of camera geolocalization with orientation defined as Omega, Phi, Kappa
- Improved video flythrough in orthographic mode when zoom is changed.
- Various fixes and improvements for the point cloud rendering.
Removed the Density slider from the 3D viewer’s settings and replaced it with the "Max Points" option in the Application Preferences, located under the Graphics tab.
Fixed point density that could cause visual flickering while navigating around the scene.
Fixed issues with point cloud detail in Orthographic mode.
Fixed point cloud points appearing too small on very large projects.
Fixed unexpected rendering flickering that occurred when using rectangle/polygon selection.
Fixed the blinking of the point cloud when changing a point cloud attribute.
- Added circles to customer report.
- Added a filtering tool for the selection modes.
- Added an action to continue a polyline.
- Upload to PIX4Dcloud combines RGB images with depth data (such as depth and confidence maps) when available.
- Resolved an issue where tie points have incorrect CRS or positions during uploads to PIX4Dcloud.
- SSO login session is automatically refreshed beyond 48 hours
- Added Support for new camera models:
Sony ILX-LR1 9504x6336 with 35mm lens for Freefly
DJI Mini 3 6.7 4000x3000
DJI Matrice 4T wide angle lens RGB camera 6.7 4032x3024
- Added Support for IMU data from Skydio drones
- Fixed an issue which prevented image metadata from being read correctly when importing images.
- Fixed issues with sub-processes affecting a limited number of users.
Versions 1.73
| 1.73.0 | February 17, 2025 | Preview | Windows | Mac |
1.73.0
What's new
- Added a classification selector in the toolbar
- Added an action to split a polyline.
- Added an action to join two polylines.
Sony ILX-LR1 9504x6336 with 24mm, 50mm and 75mm lenses for Freefly
DJI Matrice 4 Enterprise 12.3 5280x3956
DJI Zenmuse L1 EP800 8.8 5472x3648
- Improved quality of the generated orthomosaic when using Masks.
- Added a new selection tool to select points from the point cloud based on their color.
- Upload to PIX4Dcloud for processing: Added a new dialog that allows to upload and process a project with PIX4Dcloud.
- Lines are correctly shown on the fish-eye images.
- Improved geometries visualization. Polylines with more than 50 vertices are now shown in the Image Viewer.
- ‘Drape polyline’ is now available in the 3D view context menu when a polyline is selected.
- Available in Czech language
- Fixed an issue where the outdated icon sometimes did not appear for point clouds in the content panel.
- Fixed merging into a new project not working.
Versions 1.72
| 1.72.0 | January 27, 2025 | Preview | Windows | Mac |
1.72.0
What's new
- Google tiles and KML/KMZ formats were added to the orthomosaic TIFF export.
- Circles can be created with a dedicated vectorizing tool in the 3D view. In 3D, circles will be drawn flat. In a section view, circles will be automatically aligned with the section.
- The project CRS is displayed and can be edited when a new project is created by drag-and-dropping images into the interface.
- Distances can be converted to and from polylines.
- The status center text is simplified to avoid elided text.
- Improved the performance of the image viewer.
- Reduced the number of cases that cause project elements to become outdated after adding or editing tie points.
- Fixed the unexpectedly long preparation of the DSM and orthomosaic before sharing to PIX4Dcloud.
- Fixed an issue that prevented the DSM and orthomosaic from being outdated after modifying the image masks or adding new input images.
- Fixed an issue that prevented the export of large point clouds to LAS 1.4.
- Fixed an issue where the image viewer would not correctly center on the selected object when selecting or changing global zoom.
- Fixed an issue where editing the camera internal parameters of a fisheye camera would not set the correct polynomial type.
Versions 1.71
| 1.71.0 | January 1, 2025 | Stable | Windows | Mac |
1.71.0
What's new
- Improvements related to the point cloud rendering
- Improved performance for exporting flythrough videos
- Running and queued tasks can now be canceled in the tree view of the Status center
- Improved performance for creating dense, depth, and fused point clouds, with significant speed-ups for very large datasets
- The section box can now be edited in the section view directly and renders on top of objects in the scene
- Reduced noise in the DSM generated based on automatic tie points, particularly near the border
- Export camera image geolocation and orientation file with 4 decimal places or more
- The UI elements for coloring the point clouds by elevation are now respecting the display unit
- Prevent freeze of the application while saving and resetting a view in the Flythrough panel
- KML ROI import now supports files with multi-geometry and multi-polygons. Only the first polygon found will be used
- Prevent freeze of the application while Auto marking
- Fixed a bug when “Color by elevation” didn't respect the ASPRS classes' visibility
- Fixed the export to OPF for projects containing point clouds in the legacy point cloud format
- Fixed a bug when fused point cloud points coming from the depth point cloud could not be selected in certain cases
- Fixed an issue that prevents importing vector files with a geographic CRS
- Fixed an issue where selecting geometry in the Content panel would not clear existing selection
- Fixed an issue where selecting different geometry types would sometimes not show the simplify and alignment buttons in the Properties panel
- Fixed an issue where creating an invalid polygon would permanently lock its layer in the Content panel
- Fixed an issue with determining a project CRS based on a right-handed geographic CRS
- Fixed an issue that prevented the display unit set by the user from being correctly restored when opening a project
- Fixed an issue that prevented the export of the mesh as LAZ when the system partition was almost full
- Fixed instability when removing marks from vertex tie points (VTPs)
- Fixed an issue that caused spare point clouds in the inventory snapshots of the custom report
Versions 1.70
| 1.70.1 | November 29, 2024 | Preview | Windows | Mac |
| 1.70.0 | November 25, 2024 | Preview | Windows | Mac |
1.70.1
- Stability improvements
1.70.0
What's new
- Added option to allow passing image masks to the DSM and Orthomosaic generation for filtering out parts of the project
- Exposed a slider in 3D viewer settings to control the density of the rendered glTF point cloud points
- Updated the properties panel related to volumes. Volumes can now be computed using the viewer toolbar
- Removed requirement for the image masks used in the mesh generation to be identical to the masks used in the dense point cloud generation
- Added new “Absolute” camera internals confidence option to the Calibration and Reoptimization steps, causing them not to change the camera internal parameters
- Added an option not to optimize the camera internals together with tie points, preventing overly strong adjustments to account for position errors
- The camera internals editing dialog now supports modeling cameras using only radial distortion parameters or no distortion parameters at all
- Added support for importing Trimble CAL files to define CRSs
- Added support for ESRI’s “Local” projection in CRS definitions
- Tie points with less than 2 marks are displayed in orange to help mark them
- Camera location and zoom is now saved to the project settings and restored on project load
- Improved Orthoplane generation when using the Standard algorithm (CPU only)
- Added support for Korean geoid model KNGeoid24 as a user-provided geoid model
- Added the option to remove input camera geotags (position & orientation) in the Cameras table
- Distance (measurements) can now be exported as polylines in DXF, SHP, and GeoJSON formats
- New auto-mask feature: propagate existing masks to other images automatically
- OPF import: Masks can now be imported from opf in Matic.
- Custom report improvements:
- Added volume names as labels to the overview plan
- Added full volumes report to the inventory
- Quality report improvements:
- Included number of point cloud points in summary
- Included “Dense point cloud: Readjustment” processing settings and duration
- Fixed an issue where some settings for the Mesh settings in the Processing panel were not correctly applied by the processing template
- Fixed an issue where the ASPRS classes visibility was ignored when coloring by relative confidence was enabled in the Settings
- Fixed an issue where computed volumes would not load correctly when opening a project
- Fixed an issue preventing Orthoplanes from being exported as JPG
- Fixed a source of crashes that could occur when too many files were open at the same time
Versions 1.69
1.69.0
What's new
- Added option to reoptimize a dense point cloud
- Added option to compute volumes from the content panel, viewer right-click actions menu and top menu bar
- It is now possible to convert between polygons, polylines, and volumes
- Volumes can be created from the toolbar option. They can be modified, computed and their base shape exported
- Added option to include volumes in the custom report
- Added option to generate the DSM and Ortho using the automatic tie points (sparse point cloud)
- The escape shortcut (Esc) will now finalize geometry during geometry creation rather than remove it
- Added rotation handles to all sides of the clipping box, allowing for the creation of clipping boxes that are not parallel to the XY plane
- Added option to export Markers as CSV files, with various CSV column formats to choose from
- Added a load indicator to the mesh content panel entry, displaying if a scalable mesh is currently still loading nodes of higher quality
- Improvements in the logic for which nodes of a scalable mesh to display, causing it to fall back to low-detail nodes less often
- Improvements in the speed of the OBJ and PLY exports of scalable meshes
- Improvements to the layout of the section view export to select the content more easily
- Fixed an issue with the section step size not working properly in non-metric coordinate systems
- Fixed an issue with mesh texture generation failing in the standard pipeline for texture size 32768 x 32768
- Fixed the issue of importing geometries from a left-handed coordinate system not placing them in the correct location
Versions 1.68
| 1.68.1 | October 22, 2024 | Stable | Windows | Mac |
| 1.68.0 | October 15, 2024 | Stable | Windows | Mac |
1.68.1
Bug fixes
- Fixed an issue when processing with the welcome view or another project tab active
- Fixed an issue of importing geometries from a left-handed coordinate system not placing them in the correct location
- Fixed performance regression affecting DSM generation
- Fixed an issue where the section step size is not working properly in non-metric coordinate systems
1.68.0
What's new
- Added button in the section view toolbar to allow snapping to point cloud points when creating and editing geometry in the section view
- Added search bar to the tie point table to allow filtering by the tie point labels
- Added a recommendation for the users uploading on PIX4Dcloud a point cloud in a deprecated format
Bug fixes
- Improved stability of the image viewer
- Fixed quality issues with large meshes generated with the scalable pipeline when viewed from afar
- Fixed scalable mesh not being rendered correctly when exporting a video flythrough
- Fixed PIX4Dcloud upload failing for projects containing orthoplanes
- Fixed custom report export failing for projects containing orthoplanes
- Fixed issues related to the display unit in the quality report
- Improved the inventory snapshot generation in the custom report for small projects
- Fixed an issue where the marks on images of markers were still visible even if the containing layer was hidden
- Fixed an issue which prevented Auto-marking after importing image marks
- Fixed an issue where a geometry was deselected when its vertices were deleted
- Fixed an issue where polygon faces couldn’t be created depending on how the face vertices were added
- Removed artifacts in the orthomosaic shared to PIX4Dcloud
- Fixed the DSM border not matching the orthomosaic border after exporting or sharing to PIX4Dcloud
- Various other bug fixes
Versions 1.67
| 1.67.1 | October 3, 2024 | Preview |
| 1.67.0 | September 24, 2024 | Preview |
1.67.1
Bug fixes
- Fixed the application hanging when reading images metadata in some cases
- Fixed issue for some EUM users receiving a "No license available" message
- Fixed issue with the image viewer crashing in some cases when marking tie points
- Fixed issue with the Mesh generation crashing in some cases when the manual ROI was not defined
- Fixed issue with the Custom Report generation failing when projects contained orthoplanes
- Fixed issue with the Share to PIX4Dcloud upload failing when projects contain orthoplanes
Known issues
- Scalable mesh not rendered correctly when exporting a video flythrough
- Scalable mesh is not rendered correctly when first shared to PIX4Dcloud, repaired only after zooming in
1.67.0
What's new
- Added a new scalable mesh pipeline to generate more detailed meshes for large projects
- Added processing templates to save and share customized processing steps
- Selected processing options are restored when a project is reopened
- Added remote device deactivation
- Added geometries for the Share to PIX4Dcloud feature
- Improvements on internal point cloud format (glTF):
- Upload larger point clouds to PIX4Dcloud
- Faster OPF import and export
- Added Reoptimization settings and duration to the Quality Report
- Added sub-sections to the Settings panel
- Added option to snap a vertex to an existing polygon edge, when creating polygons
- Added tool in the properties panel for Polygons, polylines, and measurements to align all vertices to their average, highest, or lowest vertex height, or set a custom height value
- The valid faces of a polygon are now rendered even if they are connected to invalid ones
- Improved quality of orthofacades with interpolation enabled
- Added on/off toggle for the section view’s grid
- Added option for smaller section box dimensions and step intervals
- Updates on the street tiles of the 2D basemap
- Improvements on the application stability:
- Calibration and Dense point cloud are run as separate processes
- Improvements in the support for various camera models
- Compute and use object-aligned or Z-axis-aligned measurement boxes from masks (Apply to 3D)
- Added new onboarding panel for the Create image mask tool
- Added new settings to adjust the size of the marker and masks in the 3D view
Bug fixes
- Fixed issue preventing the import of camera models from the user database
- Fixed issue with Share to PIX4Dcloud for large orthomosaics
- Fixed issue with incorrect vertex hovering during polygon face creation
- Fixed issue with the Quality Report export when an orthoplane was in the project
Known issues
- Share to cloud fails in the presence of orthoplanes
- Custom report fails with orthoplane
Versions 1.66
| 1.66.0 | August 29, 2024 | Preview |
1.66.0
What's new
- Added to the Quality Report:
- Absolute geolocation variance histograms
- Vertex Tie Points
- Added option to Help menu to allow resetting the user onboarding experience
- Added Vertex Tie Point conversion toggle to Reoptimization
- Added Orthoplane generation, visualization in the section view and the option to export as .JPG
- Added options to expand, duplicate, modify, and rename export settings in the processing panel
- Improvements in support for various camera models
Bug fixes
- Fixed a crash when sharing a DSM or Orthomosaic to PIX4Dcloud
- Fixed a crash when merging projects with arbitrary and non-arbitrary CRS
- Fixed a crash when generating the DSM
- Fixed issues with Vertex tie points
- Fixed issue with unexpected failure on the polygon tool
- Fixed issue when the polygon tool sometimes was not rendered in image viewer
- Fixed issue when the Image mark removal did not remove mark
- Fixed issue with the removal of Image mark not working
Versions 1.65
| 1.65.0 |
August 5, 2024 |
Preview |
1.65.0
What's new
- New geoid models for Austria and New Zealand
- Sped-up OPF export of dense point clouds
- Improved processing time and disk space usage of depth maps
- Improved camera internals usage in reoptimize
- Added option to disable uncertainties calculation for challenging merged datasets
- Added inventory of geometries to the custom report
- Added a slider to settings allowing hiding cloud points with few matches
- Added ability to convert geometry vertices into vertex tie points. They can be seen in the tie point table and are used in calibration
- Snapping window indicating the depth of the objects being snapped to. This enables more accurate and efficient vectorization
Known issues
- Context menu content might be wrong when selecting or unselecting a mask object
- In some cases image viewer doesn’t show polygons
- Positions of vertex tie points are shown in the tie point table
- Planarity toggle is disabled if one of polygon vertices is a vertex tie point
- Reprojection error for vertex tie point computation might produce wrongly large values
- A toggle to convert vertices to vertex tie points is missing for the Reoptimize step
- Re-calibration of a project with a section view that has a marked polygon might fail
- In certain cases creating polygons by snapping to existing ones fails
Versions 1.64
| 1.64.0 |
July 16, 2024 |
Preview |
1.64.0
What's new
- Added native ARM application support that speeds up processing significantly on macOS
- Importing existing GCPs prompts to replace, keep both, or ignore the import
- Added a layer template manager to facilitate the handling of multiple layer templates
- Mark section geometries in images for more accurate geometry creation
- Shift+click in the section view when vectorizing to draw strictly vertical or horizontal lines
- Section box rotations snap to 90-degree angles
- Improved tie points table (sorting, navigation, data copy,…)
- Added a search bar for layers in the content panel
- Added a setting to make the application take into account the projection distortion when doing measurements
- Various UI interaction improvements
- Various bug fixes
Versions 1.63
| 1.63.1 |
August 15, 2024 |
Stable |
| 1.63.0 |
July 2, 2024 |
Stable |
1.63.1
- Improvements and bug fixes related to:
- Fixed various crashes
- Image viewer
- Videos & views
1.63.0
What's new
- Added a new option to select the angle convention when exporting images' geolocation and orientation
- Added option to edit geometry vertices' position in the properties panel
- Section views
- Quality report
- Camera table and the image CRS picker
- Image viewer
- Videos & views
- Selection of Objects
- Masks
- Improvements to the detection and handling of crashes related to unreachable resources
Various improvements and fixes
Versions 1.62
| 1.62.0 |
June 3, 2024 |
Preview |
1.62.0
What's new
- Added Section View to facilitate the creation of road sections or floorplans
- Update the positions of marked geometry vertices after reoptimization
- Added 2D measurements in the 2D view
- Added camera overlap map to the quality report
- Added an overview plan option with scale bar and north arrow to custom reports exports
- Improved geometry imports with layer color assignment and alphabetical order
- OPF projects can now be opened directly by double-clicking on them in the file explorer/finder
- Added masks functionality for improvements in densification and mesh
- Changed background color of exported ortho jpg files to white
- Added JPEG compression option to geotiff export for about 10x smaller export size
- Exposed the option to select GPU for algorithms
- Added user-provided geoid support for Estonia (EST-GEOID2017)
- Added the ability to import a PIX4Dmapper site calibration file into PIX4Dmatic
- Added display of release notes to inform on new functionalities after new installation
- Fixed issue of wrong export of video animation when multiple projects are open at the same time
- Fixed a UI glitch for the default layer templates
- Fixed certain crashes for the orthomosaic processing step
- Fixed support article links
Known issues
- macOS version may take several minutes for the application to start. PIX4Dmatic team is working on it
Versions 1.61
| 1.61.1 | May 13, 2024 | Preview |
1.61.1
What's new
- Added “Save copy” option to clone a project
- Added option to hide the Clipping box while it is applied
- Added option to have side panels as separated windows
- Added a custom report export from views
- Added the option to remove results from a project
- Added a mesh .obj export with the coordinates in the project coordinate reference system
- Improved image viewer sorting to show the most relevant images for the selected geometry vertex
- Added labels for markers in the 3D view and Video & views panel
- Added new resolutions for the video flythrough export (720p, 480p)
- Added option to drag and drop geometry files into an open PIX4Dmatic project
- Changed the default to ellipsoidal heights for unknown camera models
- Upgraded to macOS Sonoma (previous version macOS Monterey is not supported anymore)
- Added Training link to Welcome view
- Fixed an issue with badly scrambled fonts on specific Windows machines
- Fixed a half-pixel shift for user-provided geoid model files
- 2D Improvements:
- Added Polyline Creation and Editing in 2D view
- Added hovering and selection of Tie points & Cameras in 2D view
- Added the 2D rayCloud (hovering and selection of points on the DSM)
Known issue
- The match plot in the quality report on macOS might contain rendering artifacts
Versions 1.60
| 1.60 | April 29, 2024 | Preview |
1.60.0
What's new
- Added the import of geometries as DXF, SHP, and SHP ZIP files
- Added marker creation and editing in the 2D view
- Added Support for the Geoids:
- Singapore: SGeoid09
- Lituania: LIT20G (user-provided geoid)
- Added the export and upload of COG GeoTIFF to PIX4Dcloud to remove size limits and enable immediate display after upload on PIX4Dcloud
- Added the wireframe view style for geometries
- Added vertex insertion on edge for polygons
- Improvements to geometries export
- Improved interactions with the content panel
- Fixed issue of reorganization frames for the Videos & views panel
- Fixed issue with the merge project workflow when a sparse point cloud failed to open
- Fixed issues with geometries exports containing holes
- Fixed wrong Pix4D logo on macOS installer
Versions 1.59
1.59.0
What's new
- Added option to create (3D view) and edit (3D view and Image viewer) Markers
- Added option to create and edit Polylines in 3D and image viewer
- Added option to export Markers, Polylines, and Polygons as DXF, Shapefiles, and GeoJSON
- Added option to Auto-mark Markers, Polygon, and Polyline vertices
- Czech Republic: CR-2005
- Portugal: GeodPT08
- Corsica: RAC23
- Project view improvements:
- Added a dedicated panel for geometries, constraints, and ROI properties
- Added option to expand layers to view and select their geometries
- Added option to move the side panels left and right with Drag & Drop
- Added option to select a layer with a single click, rename a layer with a double click
- Improvements for the upload of Mesh to PIX4Dcloud (Cesium 3D tiles)
- Improved message to the users if all cameras exceed the maximum nadir angle
- Fixed bug when the image viewer focuses on the selected polygon vertex when zooming
- Fixed bug when exported DSM GeoTIFF tiles rendering as 0s in some third-party software
- Fixed deletion of polygon vertex marks bug
- Various UI improvements
Versions 1.58
1.58.2
- Fixed issue when selecting Manual Tie points
- Fixed issue with 0 tiles instead of nodata in the DSM export
- Fixed issue with mouse cursor
- Fixed issue when creating a video layer
- Fixed issue with the image viewer and the zoom focus
- Fixed issue with the Region of Interest in the 2D and 3D view
- Fixed issue with the Side panel split views
- Improved information message when the Share to PIX4Dcloud feature fails
1.58.1
What's new
- Added collapsible processing panel sections
- Fixed bulk edition of camera external parameters
- Fixed crash when exporting planes as OPF
- Fixed a crash during 3D Mesh texturing
- Fixed issues with the Share to PIX4Dcloud feature
- Fixed issues with the video flythrough
- Fixed issues in the 3D Region of Interest (ROI)
- Fixed occasional crashes during geometry creation or edition
- Improvements in the Merge feature
- Improvements to the Quality Report export
- Improvements to connected polygons
- Improvements in the CRS picker dialog
Versions 1.57
1.57.0
What's new
- Added option to view, create, and edit a Region of Interest (ROI) in the 3D viewer with control on the height of the ROI
- Added option to export connected polygons as a .DXF file for CAD compatibility
- Added option to import a Region of Interest as a .kml file
- Added support for the Korean Geoid model (KNGeoid18)
- Added the option to merge two or more tie points (MTPs, GCPs, CPs, mITPs,...)
- Added .ply export for the mesh
- Added the option to convert a measurement to a scale constraint in the Edit menu
- Added tie point positions plot and improved display of plot axes in the Quality Report
- Improvements to the merge and register workflow
- Improved mesh texture quality
- Improvement to the AutoGCP detection algorithm
- Faster processing in calibration for challenging and big dataset
- Various improvements
- Fixed issue with hover interactions (delete, full screen) on image viewer
Versions 1.56
1.56.0
What's new
- Added connected polygon geometries and related actions
- Enabled multi-selection operations for tie points
- Added option to save/overwrite an existing OPF file
- Added option to automatically open and load an OPF project
- Improved orthomosaic settings for merged drone and PIX4Dcatch projects and multiple other improvements to the orthomosaic
- Fixed an incorrect image scale value appearance in the quality report
- Fixed occurrences of densification crashes
- Fixed an occasional crash with image embeddings
- Fixed multiselection of cameras
- Fixed truncation of numbers in tables
Versions 1.55
What's new
- Added “move geometry to layer” action
- Added custom point cloud classes and classes color
- Added the position error column in the register step
- Added export time of quality report in the status center
- Added rendering of blocks for matches plot in the quality report
- Improved scroll bars
- Improved performance for mesh texturing
- Improved mesh texture for merged aerial and terrestrial projects
- Fixed an occasional crash for DSM generation
- Fixed display of characters in the quality report
- Fixed issues related to register and merge
Versions 1.54
1.54.3
- Fixed occasional crash in DSM generation
- Fixed issue of losing GCP data for duplicated GCPs after merging
- Fixed occasional number rounding issue in the tie point table and camera table
- Fixed occasional crash in image preprocessing
- Fixed occasion crash in GPU densification (CUDA setup)
- Fixed camera table edition truncating values with 1-digit
- Fixed occasional crash when editing camera internal parameters
- Fixed incorrect image scale values in the quality report
1.54.2
- Fix performance regression in the dense point cloud generation
1.54.1
- Fixed crash upon startup for usernames with non-ASCII characters
- Fixed bug when source camera information in generated dense point cloud was missing.
- Fixed bug when arbitrary CRS was blocked from selection in the UI
Known issues
- Issue during densification
1.54.0
What's new
- Added option to select a geoid height even if there are geoids available
- Added Find more matches by name option to the merge dialog
- Improvements to the polygon tool
- Improvements and bug fixes related to the Quality Report as PDF export
- Improvements in the video flythrough feature
- Improvements to the camera internals dialog
- Improvements to the merge dialog
- Various improvements and fixes
Known issues
- PIX4Dmatic crashes upon startup
- Missing yellow tracks in Dense point cloud
Versions 1.53
What's new
- Added video fly-through feature
- Added planarity constraint for polygons
- Added hole creation tool for polygons
- Added smoothing toggle for Mesh generation
- Added new and improved Quality Report
- Quality Report is available on macOS as PDF
- Added Object selection tool
- Added option to export the point cloud as LAS 1.2
- Added Invert selection action
- Added group export options and other menu improvements
- Enabled the option for images uploaded to PIX4Dcloud to be seen with the PIX4Dcloud Virtual Inspector
- Added disabled point panel
- Added ASPRS classification
- Added Color by relative confidence settings
- Added option to convert a distance measurement to a scale constraint
- Added option to hide GCPs, MTPs, Checkpoints, and mITPs individually
- Added the distance measurements in images for display and editing
- Added option to delete the mark of Tie points by pressing a key while hovering over the image
- Added support for the geoids:
- Argentina | SRVN16 height - EPSG:9255 | GEOIDE-Ar16
- Poland | EVRF2007-PL height - EPSG:9651 | PL-geoid-2021
- Improved satellite images in many parts of the world
- Improvements on the Merge Projects feature
- Fixed issue when using special characters in paths
- Fixed issue when reoptimize was significantly longer on certain projects
- Fixed issue when disabled point clouds were exported
Versions 1.52
1.52.1
- Fixed occasional crash when starting application
1.52.0
What's new
- Added persistent distance measurement tool
- Added option to export Tie point marks
- Fixed bug when merging projects with shared GCPs
Known issues
- Quality report as .pdf is not available on macOS
- Application installation path containing special characters causes issues
- Performance issues during Calibration and Reoptimization
Versions 1.51
1.51.1
- Fixed issue when using special characters in the project path
1.51.0
What's new
- Available in Turkish language
- Fixed bug with the 2D viewport when reopening a project
- Fixed Processing Panel bug, where the image scale and the processing template were set incorrectly
- Fixed bug when hovering in the 3D view
- Various bugs and improvements
Known issues
Versions 1.50
1.50.0
What's new
- Added option to edit Camera internal parameters
- Added multi-selection of point cloud points and point cloud editing
- Added support for .xyz format for point cloud export
- Existing results will remain visible during re-processing
- Added new geoid models:
- Taiwanese geoid model TWGEOID2018h (vCRS: EPSG:8904)
- Latvian geoid model LV14 (EPSG:4661+7700) Latvia 2000 height
- Finnish geoid models: FIN2000 (EPSG:4258+5717) N60 height and FIN2005N00 (EPSG:4258+3900) N2000 height
- Added option to reset camera externals from EXIF data
- Added vector layers and vector layer templates
- Added export GCP option
- Added multiselection for geometries
- Added support for multiple cameras in the same project
- Improvements in the conversion of MTP to GCP
- Improvements in Calibration
- Improvements in the DSM
- Improvements in the aITP (automatic intersection tie points) detection
- Improvements in the Orthomosaic
- Fixed crash on geometry creation
- Fixed reoptimize failure after adding an image
- Fixed reoptimize failure after editing image position accuracies
- Fixed application freeze after editing image orientation
- Fixed issue with reopening projects containing images without geotags
- Fixed crashes during ortho generation
Known issues
- Quality report as .pdf is not available on macOS.
- Default processing templates have incorrect settings leading to processing issues.
Versions 1.49
Disclaimer: The preview version contains new features and bug fixes. Documentation and support are not available. We recommend testing the preview version before using it for production work.
1.49.0
What's new
- Added Cameras table showing external camera parameters
- Polygon Selection - Allows for multiselection of input cameras
- Improved the size slider for the image accuracy ellipsoid display and added the display to the 2D view
- Added a selection for display measurement units
- Fixed failed reoptimize after adding MTPs due to uncalibrated images with marks
- Fixed Auto-mark failure with an unknown error
- Fixed incorrect outdated status of the mesh related to planes generation
- Fixed a crash in constraint creation
- Fixed the issue of merging projects with the same name
- Fixed esc key behavior for scale and orientation constraints
- Fixed geoid model height user input being ignored
- Fixed macOS touchpad scrolling issues in the content panel
- Improvement to the mesh texturing and the point cloud processing speed
Known issues
Versions 1.48
1.48.0
What's new
- Added option for a Default Coordinate Reference System (CRS)
- Added Clipping box in 3D viewer
- New content and processing panels
- Added ellipsoids for input camera accuracies in 3D viewer
- Added support for camera models:
- Oblique D2M camera from Quantum Systems
Known issues
Versions 1.47
1.47.1
What's new
- Enable mesh export to SLPK for projects with ellipsoidal heights
- ShareUAV 202S Pro
- Fixed issue with timeout error in the PDF quality report for Windows
- Improvements in OPF exports
- Improvements in the Scale and Orientation constraints feature
- Improvements in site localization workflow
- Improvements in 3D viewer
- Fixed 2D map zoom level after merging into an empty project
Known issues
Versions 1.46
1.46.0
What's new
- Public release of Open Photogrammetry Format (OPF) 1.0
- Added image Coordinate Reference System (CRS) picker
- Added GCG2016 geoid model (Germany) and SLO_VRP2016/Koper geoid model (Slovenia)
- Added SSO support for subscribed companies
- Available in Portuguese language
- WINGTRA RGB61_FE24mmF2.8G_24.0_9504x6336
- DJI M3M_4.3_2592x1944
- Legacy internals JSON camera database (derived from the PIX4DMapper database) to retrieve internals for generic models
Fixed issue with One-time Charge educational license handling
- Fixed an issue where the DSM was failing for certain projects
Other notable
- Support for macOS Ventura (13.0)
- Withdraw of support for macOS Big Sur (11.0)
Known issues
- Unexpected slowdown for the calibration in certain large PIX4Dcatch projects
Versions 1.45
1.45.1
- Fixed a UI issue with offline licensing
1.45.0
What's new
- Added scale and orientation constraints
- Added support for projects with a higher amount of images
- ShareUAV 102S Pro
- SONY ILCE-7RM5_FE35mmF2.8ZA_35.0_9504x6336
- SONY ILCE-7RM5_FE24mmF2.8G_24.0_9504x6336
- Updated the End-User License Agreement (EULA)
- Fixed a bug when reopening large projects (15.000+ images)
- Added an .aux.xml file for geolocation of the Orthomosaic as .jpg export in QGIS and ArcGIS
- Fixed Bad optional access error when generating Planes
Known issues
Versions 1.44
1.44.0
What's new
- Added offline licenses. Contact sales for more information
- Improvements on the Auto-mark functionality for Intersection Tie Points (ITPs)
Known issues
Versions 1.43
1.43.2
What's new
- Added the Merge projects feature at the calibration level, for accurately geolocated projects
- Removed the logic of setting the Internals confidence parameter automatically to High in the Calibrate step when the camera is in the camera database
- Improvements in the Intersection Tie Points (ITPs)
- Improvements in the polygons
- Fixed Share to PIX4Dcloud for projects with site calibration
- Improved exports for the orthomosaic as .jpg and the mesh as .slpk
- Improved the object occlusion slider
Known issues
Versions 1.42
1.42.0
What's new
- Added the Intersection Tie Points (ITPs) for Calibration
- Added automatic generation, manual creation, and the option to edit planes for meshes
- Added Back-face culling option in 3D viewer
- Added object occlusion slider
- Added plane normals toggle
Known issues
- HW accelerated orthomosaic generation crashes on specific GPU models.
Versions 1.41
1.41.0
What's new
- Improved 3D viewer
- Improved information in the processing options window
- Unified export paths
- Changed DJI Mavic 3 Enterprise pixel size from 3.39449 to 3.3 in the Camera Database
- Fixed issue when Automatic Tie Points (ATPs) reprojections were missing in the image viewer
- Fixed incorrect camera orientations when importing image geolocations in a projected coordinate reference system
Known issues
Versions 1.40
1.40.0
What's new
- Modified orthomosaic export options to have larger tiles (~2Gb) for better third party compatibility and less files at export.
- Added option to choose between .LAS and .LAZ for the point cloud export
- Updated camera parameters for Parrot ANAFI Ai.
- Available in traditional Chinese language.
- SOTEN CX-GB100.
- DJI Mavic 3 Enterprise.
- Skydio 2+.
- Skydio 2.
- Fixed crash during calibration for images with orientation but no geolocation.
- Fixed bug with the quality report export when using the Connector.
- Fixed issue when reopening site localization projects.
- Improved consistency of path separators in the status center.
Known issues
Versions 1.39
1.39.0
What's new
- Improvements on Share to PIX4Dcloud feature
- Added Share button in the processing panel to access the Share to PIX4Dcloud dialog.
- Improved reporting progress of Share to PIX4Dcloud command to have a single progress bar for all assets.
- Project name displayed on the Share to PIX4Dcloud dialog.
- Added .las file format for the point cloud alongside .laz file format.
- Marking is now only allowed inside the image in the full-screen image viewer.
- Improved log file information, in case of errors, when generating a mesh, computing depth maps or exporting a mesh as a point cloud.
- Fixed log-in dialog launcher button on the log-in required dialog.
- Fixed busy indicator on the auto-mark button.
- Fixed 2D scene viewer issue to show the same viewport when reopening PIX4Dmatic.
- Fixed crash when coloring DSM.
- Fixed crash when picking a point in the point cloud while processing is running.
- Fixed unnecessary regeneration of depth maps when generating a mesh.
- Added information about memory requirements for JPG exports.
- Fixed crash when canceling mesh export under SLPK and Cesium 3D Tile formats.
- Fixed crash when calibrating images without geolocation.
- Fixed crash when clicking on 3D viewer.
- Fixed crash in scene transform.
- Fixed issues in the image viewer.
- Use of signed values for position errors following ASPRS convention.
- Fixed crash when closing PIX4Dmatic on Windows.
- Added WKT XML to DSM and Ortho exports.
- Removed mesh folder when project is not saved.
- Improved information in the status center when generating the sparse point cloud step in the calibration sequence.
Known issues
Versions 1.38
1.38.0
What's new
- Added site localization support and support for .prj files to set the coordinate reference system.
- Added Cesium 3D tiles (.b3dm, .json) export for the Mesh.
- Added .SLPK export for the Mesh for ESRI compatibility.
- Added Mesh export as point cloud for Revit users.
- Enabled Organization support for the Share to PIX4Dcloud functionality.
- Changed point cloud format from .las to .laz when uploading with Share to PIX4Dcloud to speed up upload times and reduce storage size.
- Improved point cloud and Digital Surface Model (DSM) quality.
- Added arcgp-2006-sk geoid (Svalbard).
- DJI Mavic AIR 2.
- Sony ILCE-7RM4 (Alpha 7R IV).
- DJI Zenmuse P1 24mm.
- Fixed crash when interacting with the software during calibration.
- Fixed calibration issue in Arbitrary CRS for Trusted location and orientation or Low texture planar pipelines.
Known issues
Versions 1.37
1.37.0
What's new
- Improved navigation in 3D view for terrestrial projects.
- Added .laz file format as default point cloud output.
- Added smaller point size option for point clouds.
- Improvements on Share to PIX4Dcloud feature.
- Added option to choose the organization during log-in for users with Organization support.
- Fixed number of marks displayed in maximized image viewer.
- Fixed images displayed at the top in the imager viewer when switching between GCPs.
- Fixed crash during sparse point cloud colorization.
- Fixed point selection when selecting tie point from the tie points table after selecting point from the point cloud.
- Fixed mesh display issues in the history panel and in the content panel.
- Fixed .p4m file type not being recognized by Windows.
Known issues
Versions 1.36
1.36.0
What's new
- Added Share to PIX4Dcloud feature.
- Enabled Deghosting option when selecting the Hardware accelerated algorithm for orthomosaic generation.
- Changed the default algorithm to Hardware Accelerated for the orthomosaic generation.
- Added orthographic view for 3D scene.
- Enabled the visualization of source cameras for point cloud points in the 3D view and image viewer.
- Changed ANAFI Ai height reference to Ellipsoid.
- Reduced dense point cloud file size.
Known issues
Versions 1.35
1.35.0
- Added average GSD information in the PDF quality report.
- Fixed distortion of thumbnails on the welcome view.
- Fixed crash when running the AutoGCP marking.
- Improvements to mesh generation and interactions.
- Fixed specific issues with calibration and reoptimize.
- Improved display of warning and error messages.
- Fixed automatic fill of the Geoid height in the Coordinate Reference System dialog.
- Fixed rotation in 3D for images without orientation data.
- Fixed resizing behavior of point size when a point is selected.
- Modification of default folder path only in Preferences.
- Display improvements in the content panel.
- Improvements in automatic processing settings selection.
- Improvements in 2D view and alignment of outputs.
- Fixed column count between the minimized and maximized image viewer.
- Fixed export of the quality report before the mesh is processed.
- Improvements on the GCP file import dialog.
Known issues
Versions 1.34
1.34.0
What's new
- Added GCP file import and preview dialog for additional flexibility.
- Outlier marks are displayed on the image viewer and on rays in the 3D view.
- Added triangulated position for GCPs and Checkpoints in the 2D and 3D view.
- Improvements of the rays displayed in the 3D view.
- Improved Texture for the Mesh.
- Removed position and orientation requirements for input images.
- Improved speed of the point cloud colorization in the Calibrate step.
- Fixed mesh inputs display in the processing options.
- Fixed performance issue in the image viewer.
Known issues
Versions 1.33
1.33.1
What's new
- Added Mesh viewer to the 3D view with Textured or Shaded options.
- Added Rematch and Reoptimize option in the menu and processing options.
- Added indication of geographic or projected coordinate reference systems (CRS) in the CRS selection dialogs.
Known issues
Versions 1.32
1.32.0
What's new
- Added slider to set the size of the MTPs, GCPs and Checkpoints.
- Added status of an item in the content panel.
- Added RAF18b and RAF20 geoid models (France) and hBG18 geoid model (Belgium).
- Added hardware accelerated orthomosaic generation with projects that contain images with different resolutions.
- Improved orthomosaic quality for oblique projects when using the hardware accelerated orthomosaic generation option.
- Preview release notifications are deactivated by default, but they can be enabled in the app preferences.
- Added new global processing options template for PIX4Dcatch data. Automatically detected and applied for PIX4Dcatch inputs.
- Internals Confidence parameter for the Calibrate step is set to High when a camera from the official Camera Database is detected in the project.
- Image Scale setting of the Calibrate step is set based on the resolution of images in the project.
- Upgraded the .las file format to version 1.4 to support larger files.
- Replaced algorithm behind the Standard densification algorithm.
- Enabled AutoGCP algorithm to work on Checkpoints.
Known issues
Versions 1.31
1.31.1
What's new
- Added more information to the log file.
- Fixed behavior of the image viewer when clicking on an ATP.
- Improved coordinate reference systems search functionalities.
- Improved color of GCP positions in grey instead of orange, to avoiding confusion with warnings.
- Various improvements to the Menu and Processing options panel.
- Fixed Ctrl + 2 (⌘ + 2) shortcut.
- Updated third-party dependencies with Sentry SDK.
- Various improvements to the Content panel.
- Fixed display of the last allowed version when Support & Upgrades expires for One-time Charge licenses.
- Fixed generation of high texture sizes of the Mesh.
- Reusing the already generated depth maps for the Mesh generation for time-saving.
- Fixed crash happening during colorization of the point cloud during calibration.
- Fixed the display of the DSM color bar setting
- Fixed crash happening when removing MTPs during calibration.
- Camera rays are now correctly updated when clicking on nearby ATPs.
- Selected ATPs are preserved when clicking on cameras in 3D.
- Fixed behavior of the point selection when zooming in a lot.
Known issues
Versions 1.30
1.30.0
What's new
- Improved Mesh generation.
- Improvements to the content panel.
- Added initial and optimized camera internal parameters to the quality report.
- Changed to rolling shutter type for Anafi AI camera model.
- Available in Korean language.
- Reading of altitude reference taken from EXIF.
- Support of camera models:
- Autel Robotics XT705.
- DJI Hasselblad L2D20c.
- Fixed offset for the JPG file in comparison to the TIFF in the Orthomosaic.
- Fixed issue in the Status center with duplicated Initialize entry for the Calibrate step.
Known issues
- Image viewer does not update correctly when clicking on ATPs.
Versions 1.29
1.29.0
What's new
- Added new mesh algorithm and mesh processing options templates.
- Added .tif import to the welcome view.
- Added notification linking to the download page for preview and stable releases.
- Changed HW accelerated to Hardware accelerated in the processing options for clarity.
- Portrait images taken with PIX4Dcatch are correctly rotated and displayed in the image viewer.
- Fixed regression for the Depth point cloud generation when the project path contained Unicode characters.
- Improved progress reporting and various bug fixes for the .jpg and .jwg export.
- Fixed regression for the compressed GeoTIFF DSM and Orthomosaic export files that were being exported uncompressed.
Known issues
Versions 1.28
1.28.0
What's new
- Added new HW accelerated Orthomosaic generation algorithm.
- Export of orthomosaic as .jpg with .jgw for geolocation.
- Added information about setting the project coordinate reference system.
- Fixed issue with the calibration PIX4Dcatch template in an Arbitrary coordinate reference system.
- Fixed crash when opening an existing project.
Known issues
Versions 1.27
1.27.0
What's new
- Added support of the geoid PL-geoid-2011 for Poland.
- Added support of .tif images as input.
- Added onboarding animation for the Region of interest (ROI).
- Content panel is open by default.
- Fixed issues and made improvements for the Region of interest.
- Improved alignment of the Depth point cloud with the Dense point cloud.
- Fixed an issue occurring when MTPs were added during processing.
- Decreased RAM requirements for Depth & dense fusion.
- Fixed crash when the special character # was used in the .las export path.
- Fixed display of GCPs in the 2D view while AutoGCP is running.
- Improved Auto-mark functionality.
- Added multiple tooltips for better access to information and shortcuts.
Known issues
Versions 1.26
1.26.0
What's new
- Added Region of interest (ROI) tool for speeding up processing, reducing used disk space and cleaner outputs.
- Added information message when zooming and marking images in the image viewer.
Known issues
Versions 1.25
1.25.0
What's new
- Added new calibration pipelines and templates.
- Improved Auto-mark functionality for oblique projects.
- AutoGCP functionality is improved and independent of the target size.
- 2D & 3D viewer settings are saved for a project.
- Improved densification results with noise filter and sky filter.
- Support of macOS Monterey, withdrawal of support for macOS Catalina.
- Improved translations.
Known issues
Versions 1.24
1.24.0
What's new
- Various improvements to the software architecture to lay the foundations for new features.
Known issues
Versions 1.23
1.23.0
What's new
- Added an offset.xyz file for the mesh export to enable mesh visualization with additional outputs in PIX4Dcloud
- Adapted the default zoom level in the 2D viewer.
- Improved reporting in the log file for the Orthomosaic algorithm.
- Improved the setting for usage of depth maps in the Calibrate step.
- Fixed a crash when manually marking on images while Auto-Mark is running.
- Fixed certain cases when the quality report could not be exported.
- Fixed failure of depth point cloud generation when the file path contains special characters.
- Fixed the display consistency of the Import marks... item between the menu and Tie Point table.
- Improved the default scale for projects in arbitrary coordinate systems in ft or ftUS.
- Fixed the zip archive permissions for the project logs export on macOS.
- Fixed an issue where it was not possible to reoptimize an existing project.
- Fixed the display of GCPs initial positions when importing GCP marks.
- Fixed the rendering of mesh textures with the size of 16384px.
- Fixed missing project thumbnails in the welcome page if saving in the 2D viewer mode.
- Fixed a silent crash during densification when there is not enough memory available.
- Various bug fixes and improvements in the coordinate reference system (CRS) dialog and interaction with the CRS picker.
- Various improvements for the DSM display and settings.
- Various bug fixes for the 2D viewer and the base maps integration.
- Removed the fused point cloud as input for Mesh and DSM generation in case the fused point cloud is empty.
Known issues
Versions 1.22
1.22.0
What's new
- Added Map and Satellite base maps in the 2D view.
- Added range slider and opacity controls for the DSM.
- Support of Mexican geoid model GGM10.
- Support of South African geoid model SAGEOID2010.
- Available in French and Chinese language.
- Reoptimize processing option is moved from the Processing Options panel to the menu bar Process - Reoptimize.
- Depth maps can be used in calibration for projects in ftUS.
- Fixed issues that slow down the UI of PIX4Dmatic.
- Fixed an issue where the 2D map was not correctly initialized if cameras were off, then turned on in the 2D view.
Known issues
Versions 1.21
1.21.1
What's new
- Added the possibility to export and import Manual Tie Points (MTPs) marks.
- Added the display of cameras and tie points (GCP, Checkpoint, MTP) in the 2D view.
- Set the display of the DSM with transparency on top of the Orthomosaic by default.
- Changed the mesh texture from .png to .jpg.
- Fixed the Mesh texture support in case the project name contains white spaces.
- Fixed the Mesh export to make it viewable on default mesh viewers on macOS.
Known issues
Versions 1.20
1.20.0
What's new
- Distance measurement tool.
- Relocate multiple folders at once.
- Added the option to export .tfw and .prj files for DSM and Orthomosaic.
Known issues
Versions 1.19
1.19.0
- Improvements of coordinate reference systems dialog.
- Improvements of tie points marking.
- Improvements of the status center.
- Improvements in the 3D view
- Improvements in the processing.
- Improvements in the processing options.
- Improvements in the exports.
- Fix a crash when opening a project from root.
- Fixed a bug for high texture size.
- Fixed the quality export issue.
Known issues
Versions 1.18
1.18.0
What's new
- Added dense and depth point cloud fusion for PIX4Dcatch projects with LiDAR and RGB images.
- Added a Sky filter option in the densify step to automatically remove the sky from the dense point cloud.
- Added 3D Textured Mesh generation and export.
- Added the option to select what point cloud is used to create the DSM and 3D Textured Mesh for PIX4Dcatch projects with LiDAR and RGB images.
- Support of Swiss geoid CHGeo2004.
- Support of Norwegian geoid HREF2018b.
- Improved progress report for calibrate and reoptimize.
- Reduced the size of the Windows installer.
- Fixed a bug with Auto-Mark failing when marking on uncalibrated cameras.
- Fixed the display of rays on dense and depth point clouds.
- Fixed the DSM display on macOS.
Known issues
Versions 1.17
1.17.0
What's new
- Auto-Mark button in the image viewer to enable automatic marking of images for a tie point (MTP, GCP, Checkpoint) once two marks were added manually.
- Added proxy server support.
- Added application settings to set the proxy and language.
Bug fixes and improvements
- Improved initial camera and point sizes for PIX4Dcatch projects.
- Improved the display of cameras when a point is selected is extended from a subset of cameras to all cameras in the 3D view.
- Improved the error reporting for the HW accelerated densification.
- Fixed issue of calibration failing with “Unknown error” in case there were no geolocation accuracy values available when importing a .csv file for images geolocation and orientation data.
- Fixed issue of holes in the DSM and Orthomosaic by adding a region of interest algorithm to the DSM generation to enable a full interpolation.
- Fixed the “hide all panels” shortcut to include the content panel.
Known issues
- DSM display is broken on macOS, but it does not affect the quality of the export. Fixed in 1.18.0.
Versions 1.16
1.16.0
What's new
- PIX4Dcatch compatibility for RGB images and LiDAR.
- New processing options for oblique projects.
- ESRI coordinate systems support.
- Content panel moved to the left side of the interface for better accessibility.
- Support of Parrot ANAFI Ai camera.
- Improvements in the .pdf quality report.
- Fixed issue with the calibration sequence indicated as running in the status center even though calibration is finished.
- Fixed issue of wrong camera orientation for certain PIX4Dcatch projects.
- Fixed link for buying licenses in the pop-up that appears when saving without a valid license.
- Fixed export error of the quality report when setting GCP coordinate system without importing GCPs.
Known issues
Versions 1.15
1.15.0
What's new
- Quality report export in .pdf format on Windows.
- Available in Japanese language.
- New Pix4D branding.
- Improvements to the arbitrary coordinate systems support.
- Improvements to HW accelerated densification and setting this as default densification option.
- Improvements to AutoGCP algorithm.
- Improvements to tie points table selection.
- Improvement in processing when the Calibrate step is rerun.
- Improvement in the quality report export to include information from all processing steps.
- Improvements to the log file:
- Add the versions of dependencies.
- Improvement of how the camera model is written in the log file.
- Fixed issue where the locale of a computer had an impact on the .las export.
- Fixed a crash that happened when selecting the wrong coordinate reference system for a GCP file at import.
Known issues
Versions 1.14
1.14.0
What's new
- Support of the DJI Zenmuse P1 camera.
- Improvements in the status center by filtering out messages from the log to only show notifications.
- Fixed issue, non-unicode characters can now be used in project names.
Versions 1.13
1.13.0
What's new
- Arbitrary coordinate systems support.
- Sort image viewer by distance, reprojection error, or image path.
- Output file names get the project name appended by default.
- Fixed the export time estimation for the quality report in the status center.
- Fixed a crash when canceling densification at about 20%.
- Fixed the default sorting of tie points by error metrics in the tie points table. Now the highest error is shown at the top.
- Fixed the transformation issue when converting from a compound coordinate reference system to another coordinate reference system with a different ellipsoid.
Known issues
- Non-unicode characters cannot be used in project names. Fixed in 1.14.0.
Versions 1.12
1.12.1
What's new
- Algorithm for hardware accelerated densification.
- AutoGCP functionality to automatically detect a certain types of targets.
- Slider to adjust the size of image thumbnails in the 3D view.
- Deghosting option for the Orthomosaic that removes moving objects.
- Add the quality report as an export checkbox in the processing options.
- Fixed issue where holes were created in the dense point cloud.
- Fixed issue that cleared selection when changing 3D view settings.
- Improved behavior for canceling processing.
Known issues
Versions 1.11
1.11.0
What's new
- Color consistency of rays in the 3D and marks in the image viewer.
- Improved picking of points and objects in the 3D view.
- Improvements in the 3D view.
- Improved the performance in the 2D view for macOS.
- Improvements in the Tie points table.
- Improvements for full-screen image view
- Improvements for the image geolocations and orientations import.
- Improvements in the GCP file import.
- Improvements for GCP coordinate system selection.
- Improvements in the status center.
- Improvements in the behavior when opening a project.
- Fixed the image filter in the maximized image viewer.
- Fixed bug where Alt+tab would deactivate the possibility to mark in the image viewer.
- Fixed bug where relocating images would mark all processing steps as outdated.
- Fixed the bug where the message on hover “Right click to find your images” blocks the right click on the message area
Versions 1.10
1.10.0
What's new
- Status center for more information about what happens in PIX4Dmatic when processing and working in the software.
- Text file import (.csv/.txt) for image geolocation and orientation.
- Sky shader and background colors in the rayCloud view.
- Improved image viewer:
- Display up to 6 columns in the image viewer in the rayCloud view.
- Increase the default size of the image viewer to 1/4 of the screen for better viewing of image content.
- Improved marking of tie points:
- New tie point marking toolbar above the image viewer.
- Sorting of images by distance to the point.
- The image list is not resorted after clicking “Add and mark a new tie point”.
- Images that are used to create the point are added at the top of the list.
- The right sidebar with panels is moved to the top and the image viewer is a tab. This provides more space for the 3D and image viewer.
Versions 1.9
1.9.1
- Improvements in full screen image marking.
- Improvements in the image viewer.
- Fixed bug when changing the tie point type is not taken into account.
- Fixed bug when the accuracy of images is reset to default values when saving projects.
1.9.0
What's new
- New marking workflow enabled directly in the rayCloud view.
- Images can be viewed full screen to provide better context for marking
- New shortcuts for navigation in the full screen (space bar, navigation arrows).
- Images can be displayed in nine columns in full screen marking
- Delete all marks of a tie point.
- Sort columns in the tie points table to improve the quality assessment during marking or after calibration. For example, tie points can be sorted by position or reprojection error.
- Performance improvements in image viewer.
- Improvements in images displayed when marking.
- Improvements in tie points table editing.
- Improvement in point cloud rendering.
Known issues
- Changing the tie point type is not taken into account. Fixed in 1.9.1.
- The accuracy of images is reset to default values (5 and 10 m respectively) when saving projects. As a workaround, we recommend updating PIX4Dmatic, and removing and reimporting the images after reopening projects. Fixed in 1.9.1.
Versions 1.8
1.8.0
What's new
- Keep the same images and zoom level between the image viewer and the marking mode.
- Facilitate panning in images by making the CTRL key optional.
- Improve the marking experience by adding new shortcuts.
- Improve the marking of GCPs and checkpoints by showing all cameras in case there are no reprojections found.
- Facilitate marking of manual tie points by creating reprojections after the first mark is added.
- Performance improvement for marking. The marking is instantaneous, even when there are many marks.
- Undo can be used when editing the tie points table.
- Adapt the point size in the rayCloud.
- Coordinate system selection popup remembers the coordinate selection when one wants to edit it.
- Delair UX11.
- Parrot Anafi USA.
- DJI Zenmuse X5S.
- DJI Zenmuse X7.
- Removed the limit of 0.1 feet on the resolution of the DSM and orthomosaic. The new minimum is 0.001 feet.
- Unicode characters can be used in project names.
- Improved visibility of uncalibrated cameras.
Versions 1.7
1.7.0
What's new
- Added Checkpoints for the accuracy assessment of the reconstruction.
- Improved picking of Automatic Tie Points in the 3D view.
- Faster zooming in images, 3D and 2D views.
- Improved number formatting in the quality report.
Known issues
- Marking of Tie Points is slow on Windows when images are fully zoomed in. Fixed in 1.8.0.
- Images viewer loses selection when entering marking mode. Fixed in 1.8.0.
- There is a limit at 0.1 feet for the DSM resolution in the processing options panel. Fixed in 1.8.0.
Versions 1.6
1.6.0
What's new
- Added Manual Tie Points (MTPs).
- Marking mode improvement with mark propagation based on the position of marks clicked on images.
- Extended camera support with a generic camera model based on required EXIF/Xmp tags availability.
- A backup mechanism for projects.
- Information message when a new version is available.
- Support of images acquired using iPad with PIX4Dcatch.
- Fixed bug when calibration fails if the project name contains non-ASCII characters.
Versions 1.5
1.5.0
- Speed improvements on DSM for corridor projects.
- Performance improvement for the image list for large projects.
- Fixed cases where a partial Orthomosaic was created in PIX4Dmatic version 1.4.0.
- The DSM resolution is correctly displayed in the processing panel.
Versions 1.4
1.4.0
What's new
- Menu action to open the project in PIX4Dsurvey.
- Added dense point cloud, DSM, and Orthomosaic export duration time to the log file.
- Added available disk space to the log file.
- Removed the error icon in the project tab after the Orthomosaic processing is canceled.
- The processing steps are not selected by default.
Known issues
- In certain cases, the Orthomosaic has missing parts. We recommend using a previous version if you encounter this issue. Fixed in 1.5.0.
Versions 1.3
1.3.0
What's new
- Support of the RTK/PPK workflow.
- Support new EXIF tags recognition for automatic identification of horizontal (HorizCS) and vertical (VertCS) coordinate system for the images.
- Adjust the accuracy of the image geolocation based on the values in the EXIF of the images.
- Added new information to the quality report such as processing settings, number of points in the point cloud, resolution of results, time for processing.
- GeoTIFF location is now correct for left-handed coordinate systems.
- Improved export file size estimation for DSM and Orthomosaic.
- Improved display in the Home screen of existing projects.
- Added GPU, CPU, RAM, and OS information to the log file.
Versions 1.2
1.2.1
What's new
- DSM generation.
- Orthomosaic generation.
- Export of the DSM and Orthomosaic in GeoTIFF.
- Export settings for DSM and Orthomosaic: Compression (LZW), tiles, and image scale.
- 2D viewer for the DSM and Orthomosaic.
- Support of Sony UMC-R10C camera.
- Support of Japanese geoid GSIGEO2011 v2.1.
- Fixed ordering of projects on the Home screen.
- Fixed handling of projects with non-ASCII characters.
- Fixed GCP panel display.
- Fixed left-hand side coordinate systems.
- Changed default image folder location.
- Improved log file.
- Improved coordinate system information during the GCP import.
- Improved visibility of the Start button.
Known issues:
- The EXIF image geolocation accuracy is not taken into account. A default image geolocation accuracy is set for processing. Fixed in 1.3.0.
Versions 1.1
1.1.0
- Fixed handling of Ground Control Points (GCPs):
- Fixed GCP table scroll bar alignment.
- Fixed GCP marking in the marking mode.
- Fixed UI notification when importing GCP files.
- Fixed history panel.
- Fixed crashes when opening a previously unfinished project.
Known issues
- Left-handed coordinate reference systems and non-isometric compound coordinate reference systems are not properly supported and should not be used. Whereas the calibration and densification may succeed and appear correct, the data exports include an incorrect offset which makes them unusable in other software. This includes the importing of PIX4Dmatic projects in PIX4Dsurvey. Fixed in 1.2.1.
Versions 1.0
1.0.1
What's new
- Compatible with Windows 10 and macOS Catalina
- Calibration and Densification of photogrammetric projects with linearly scalable processing
- Optimized calibration for corridor and large projects
- Processing Options for Calibration and Densification
- Easy and user-friendly GCP workflow
- Support of the latest coordinate systems
- Support of horizontal grid corrections and transformations
- Geoid model support for GCPs.
- Generation and export of high-quality dense point clouds (.bpc, .las)
- Generation and export of the Quality Report
- Native compatibility and integrated workflow with PIX4Dsurvey
- Support of most commonly used DJI, Parrot, senseFly, and Wingtra cameras. For more information see PIX4Dmatic supported cameras article.
- Dynamic viewing of large datasets for a smooth experience
- Integrated keyboard shortcuts for faster navigation
- Undo/Redo of actions
- Visible history of actions
- Log file generation for self-help and troubleshooting
Known issues
