English
Dense point cloud - PIX4Dmatic
This article provides detailed information on generating point clouds using PIX4Dmatic, including processing options, quality settings, and export settings.
Pix4Dmatic raycloud icon
Calibrate
Pix4Dmatic point cloud icon
Point cloud
Mesh
Pix4Dmatic dsm icon
DSM
Pix4Dmatic orthomosaic icon
Dense point cloud
The Dense point cloud step generates a dense point cloud from images.
Access:
  • Click Process processing_options.png.
  • On the Menu bar, click Process > Dense point cloud...
It allows users to change the following processing options:
dense_pcl_2.0
Algorithm
This option allows switching between the densification algorithms:
  • Hardware accelerated (Default): The densification will be computed using a GPU-capable algorithm. This option can contribute to reduced processing time.
  • Standard: The densification will be computed using the standard algorithm.
Note: The Hardware accelerated algorithm is automatically selected if a compatible GPU is installed (any NVIDIA GPU that supports OpenGL 4.1 or higher). Check here on How to verify the supported OpenGL versions of the graphics card.
Note: The Hardware-accelerated algorithm was tested on Windows 10 and compared to the Standard algorithm. Results showed that densification processing time is, on average, 52% faster with the Hardware-accelerated algorithm. Additionally, a slight increase in the number of densified points was observed.
Image scale
Image Scale defines the scale of the images at which additional 3D points are computed.
  • 1/1 (Original image size, Slow): The original image size is used to compute additional 3D points. This option requires four times more RAM and processing time than processing with the default value 1/2, and it usually does not significantly improve results.
  • 1/2 (Half image size, Default): Half-size images are used to compute additional 3D points. It is the recommended image scale.
  • 1/4 (Quarter image size, Fast): Quarter-size images are used to compute additional 3D points. Fewer points are computed than with the 1/2 image scale, and the processing time is reduced. This option can generate more points when processing vegetation areas.
  • 1/8 (Eighth image size, Tolerant): Eighth-size images are used to compute additional 3D points. Fewer points are computed than with the 1/2 or 1/4 image scale, and the processing time is further reduced. This option can generate more points when processing vegetation areas.
Multiscale
Multiscale (default): When this option is activated, additional 3D points are computed on multiple image scales, starting with the selected Image scale and going down to the 1/8 image scale.
Example: If 1/2 image scale is selected, additional points are computed on images with 1/2, 1/4, and 1/8 image scale.
Tip: Enable the Multiscale option when:
  • Computing points in vegetation areas and preserving details in non-vegetated areas.
  • Filling holes in low-texture regions, such as uniform walls.
The Multiscale option may generate additional noise. Disable the Multiscale option when:
  • There is noise along building edges.
  • Reconstructing thin elements, such as cell tower structures.
Density
This parameter defines the density of the point cloud:
  • Optimal (Default): A 3D point is computed for every 8th pixel of the original image. This is the recommended point cloud density.
  • High: A 3D point is computed for every 2nd pixel of the original image. It results in an oversampled point cloud that requires up to 4 times more processing time and RAM than Optimal density. Typically, this point cloud option does not significantly improve the results compared to Optimal density.
  • Low: A 3D point is computed for every 32nd pixel of the original image. The final point cloud is computed up to 4 times faster and uses up to 4 times less RAM than Optimal density.
Note: The point Density has an impact on the processing time and the number of 3D points generated.
Minimum matches
Minimum Number of Matches (2-6, 3 default) represents the minimum number of valid re-projections of this 3D point to the images. For example, when using the Minimum Number of Matches 3 (default), each 3D point has to be correctly re-projected in at least 3 images.
Tip: We recommend using the Minimum Number of Matches:
  • 2: For projects with a small overlap, but it may result in more noise and artifacts.
  • 4, 5, or 6: To reduce noise and improve point cloud quality, though fewer 3D points may be computed in the final output.
Noise filter
The Noise filter option cleans point clouds for datasets with oblique images. It removes points that are far from the images, such as features visible in the images but distant on the horizon, preventing their reconstruction.
Example: When the Noise filter is enabled for a cell tower project, points that are far away from the images do not get reconstructed.
PIX4Dmatic noise filter enabled
PIX4Dmatic noise filter disabled
Sky filter
The Sky filter removes points associated with the sky in a dense point cloud. This feature is particularly useful for datasets containing sky in images, such as:
  • Terrestrial datasets acquired with PIX4Dcatch.
  • Inspection datasets of bridges or towers.
PIX4Dmatic sky filter
Important: The Sky filter option can significantly increase processing time. It is recommended to use it only for datasets with substantial sky content in the images.
Mask-aware
Masks improve the quality of dense point clouds and meshes by removing selected elements from the scene. Specify the layers to be used in the Dense Point Cloud and Mesh steps under the Mask-aware setting.
Mask aware setting PIX4Dmatic
Reoptimization
Starting from version 1.69.0, PIX4Dmatic enables the option for Reoptimization of the Dense point cloud.
Access:
  • In the menu bar, click Process > Dense point cloud.. > Reoptimization
  • Or select the Reoptimization button refresh after enabling the Dense point cloud step and click Start.
    reop_DensePCL_1.75
This process reprocesses the dense point cloud more quickly and efficiently when a different value for Min. Matches are set.
Exports
From the Exports section, the following point clouds can be exported after processing the Densify and Mesh step:
  • Dense point cloud (available after processing Densify step)
  • Point cloud from mesh .laz (available after processing Mesh step)
PIX4Dmatic export point clouds
Dense point cloud
To export the point cloud automatically during the Densify step:
  • In Exports, select the Dense point cloud .laz option.
  • (Optional) Click the file icon Pix4Dmatic folder and specify the desired path and filename.
Note: The Dense point cloud .laz option is disabled by default. It is possible to export the point cloud without re-running Densify step:
  • On the Menu tab, click File > Export dense point cloud .laz...
  • Specify the desired path and filename.
  • Click Save.
Pointcloud from mesh (.laz)
PIX4Dmatic allows the generation and export of point clouds from a mesh. You can select the default or a custom Density (pts/m³) when exporting. The expected point cloud size and total number of points are displayed during export. This ensures the creation of point clouds even for areas not directly reconstructed, eliminating holes in the final point cloud. The exported point cloud is in .laz format.
Note: The Point cloud from mesh is expected to have a much bigger size than the point cloud that is generated during the Densify step.
PIX4Dmatic export pointcloud from Mesh
