SETTINGS | DESCRIPTION |
IMAGE TRIGGER METHOD
Device Pose: Images are triggered based on the movement and rotation of the device.
This option is only available on the iOS version. Toggle to use the overlap to trigger the image capture. Only one is active at a time. The default triggering is based on the device pose. Image Overlap: Images are triggered based on the image overlap.
Advanced Settings
VIEW
MESH COLOR: Allows to adjust the color of the mesh and/or the camera indicators based on the below color bands. The value ranges from 0 to 1.
OTHER
Reset |
Reset all settings to defaults. |
Is there a way to chose the picture's resolution?
I took picture with an iPhone 12 Pro and the maximum image file is 1Mo. How can I increase the quality?
Hello,
Due to the technology we are using for Pix4Dcatch, the resolution is limited by the device hardware and manufacturer provided SDKs, currently the resolution cannot be increased.
Kind Regards
George Brown
