Supported cameras - PIX4Dmatic
PIX4Dmatic can process images captured by practically any camera provided the images contain the necessary EXIF/XMP (metadata) tags.
Note: Multispectral, thermal, and 360-degree cameras are currently not compatible with the PIX4Dmatic.
PIX4Dmatic does not impose a limit on the size or resolution of imported images.
If image geolocation and orientation (yaw, pitch, roll) are missing from the metadata, this information can be imported using either a .txt or .csv file. To import the image geolocation and orientation with a .csv or .txt file, please see the Image geolocation and orientation import format article.
Important: Starting from version 1.34.0, PIX4Dmatic can import and process images without requiring geolocation and orientation values in the metadata.
Information: PIX4Dmatic uses one of the following camera models when images are successfully imported:
- The precalibrated internal camera parameters for images captured with a camera that is in the internal camera model database.
 - The EXIF-driven generic camera model for images that are captured with a camera that is not in the camera model database that has the Required (
) and Required for Exif-driven generic camera model (
) tags. See the EXIF and XMP tag information for project creation article for reference. - A generic camera model for images that are captured with a camera that is not in the camera model database that has the Required (
) and at least one of the following sets of tags:
Exif.Photo.FocalPlaneResolutionUnitandExif.Photo.FocalPlaneXResolutionorExif.Photo.FocalPlaneYResolutionorExif.Photo.FocalLengthandExif.Photo.FocalLengthIn35mmFilm.
Every camera model is optimized during the Calibration step to calculate optimal camera parameters for each project.
Precalibrated camera models
| Manufacturer | Camera | Syntax |
| Apple | iPad with PIX4Dcatch | Apple_Pix4Dcatch.iPad8.9_1920x1440 |
| Delair | Delair UX11 | DJI_UX11-3B_12.0_5048x4228 |
| DJI | Mavic Air 2 | FC3170_4.5_4000x3000 |
| Mavic Pro | FC220_4.7_4000x3000 | |
| Mavic 2 Pro | L1D-20c_10.3_5472x3648 | |
| Mavic 3 | L2D-20c_12.3_5280x3956 | |
| Phantom 3 Professional | FC300X_3.6_4000x3000 | |
| Phantom 4 | FC330_3.6_4000x3000 | |
| Phantom 4 Pro | FC6310_8.8_4864x3684 FC6310_8.8_5472x3648  |
| Phantom 4 Pro V2 | FC6310S_8.8_4864x3648 FC6310S_8.8_5472x3648  |
| Phantom 4 RTK | FC6310R_8.8_5472x3648 | |
| Zenmuse P1 | ZenmuseP1_24.0_8192x5460 ZenmuseP1_35.0_8192x5460 | |
| Zenmuse X4S | FC6510_8.8_5472x3648 | |
| Zenmuse X5S | DJI_FC6520_15.0_5280x3956 | |
| Zenmuse X7 | DJI_FC6540_24.0_6016x4008 | |
| Parrot | ANAFI | Anafi_4.0_4608x3456 Anafi_4.0_5344x4016  |
| ANAFI Ai | ANAFIAi_5.3_4000x3000 ANAFIAi_5.3_8000x6000  |
| ANAFI USA | Parrot_AnafiUSA_4.0_4608x3456 | |
| senseFly | Aeria X | senseFlyAeriaX_18.5_6000x4000 |
| S.O.D.A. | S.O.D.A._10.6_5472x3648 | |
| S.O.D.A. 3D | S.O.D.A._10.6_5472x3648 | |
| S.O.D.A. Corridor | S.O.D.A._10.6_5472x3648 | |
| Sony | Alpha 7R IV | ILCE-7RM4_FE24mmF2.8G_24.0_9504x6336 |
| Cyber-shot DSC-RX1RM2 | DSC-RX1RM2_35.0_7952x5304 | |
| Cyber-shot DSC-WX220 | DSC-WX220_4.4_4896x3672 | |
| UMC-R10C | UMC-R10C_E15mmF4.5_15.0_5456x3632 UMC-R10C_E20mmF2.8_20.0_5456x3632  |
| Autel | Autel Evo II Pro 6K | XT705_10.6_5472x3648 |
| Fujifilm | GFX100SII | GFX100SII_GF45mmF2.8RWR_45.0_11648x8736 GFX100SII_GF30mmF3.5RWR_30.0_11648x8736  |
