Previous | Next |
Inputs
Extension | Description |
.jpg, .jpeg | JPEG images |
.tif, .tiff | Monochromatic TIFF Multi-band TIFF (RGB / Infrared / thermal) 1 layer (no pyramid, no multi-page) 8, 10, 12, 14, 16 bit integer, floating point |
.p4r |
Whole map which contains map files used for importing into PIX4Dreact on another computer. |
Outputs
PIX4Dreact can export these outputs which can be used outside the software or shared with external stakeholders:
- Share to PIX4Dcloud: A platform for easy-to-share 2D maps for enhanced collaboration. For more information visit the Share to PIX4Dcloud support documentation page.
- Layers (GeoTIFF): 2D visual or elevation map generated by blending multiple orthophotos. The orthomosaic is color balanced and georeferenced. Export options include the ability to reduce the image size (MB). This includes a reduced image scale for a lower a megabyte image in addition to using overviews (image pyramids). Overviews provide a more responsive viewing experience in third-party image applications, but require extra disk space.
- Markers (GeoJSON, Shapefile (.zip)): Vector files which include the geometry features Point, Line, and Area.
- PDF Report (.pdf): Low-resolution version of the orthomosaic which contains an overview of the map. Optionally, the surface model and markers can be exported and displayed together or individually.
- Snapshot (.jpeg, .png): Image of orthomosaic with or without markers and basemap.
- PIX4Dreact map (.p4r): Map files used for importing into PIX4Dreact on another computer. These files include a .p4r file which contains information about the map, a snapshot of the orthomosaic (.png), the orthomosaic (GeoTIFF), the surface model (GeoTIFF) and the markers (GeoJSON).
- Log files: Text files which show useful information about the processing of the project. They describe the steps and substeps of processing, the actions taken, the warnings and the errors during the processing. Log files are needed when experiencing a problem, and when requested by technical support.
Export menu.
怎么不支持?
Hi,
This camera is not supported at the moment.
Cheers,
Teodora
Two problems arised while using pix4d react in disaster simulation at Dolalghat, Nepal.
1.There is no any lat long value while exporting markers in geojson format.We had to manually calculate geometry in arcgis.
2.The markers were hard to mark may be due to laptop screen brightness.We avoided increasing brightness due to lack of power supply.Is there anyway to make this app workable in bright day light?
3.The orthomosaic were not stitched correctly somewhere like building edges were not matched.How can it be improved?
Hi Subash,
You should have the lat and long value for the markers when you export them. If that is not the case, you can forward the GeoJSON file and we can verify it on our side.
Thank you for your feedback. I would forward it as a suggestion to the developer team. However, the easy fix would be increasing the brightness of your laptop or using a monitor hood to block the direct sunlight.
Pix4Dreact provides a quick overview for emergency situations so you might have some distortion on building edges or so on. I would recommend you to use the Pix4Dmapper for fewer or no distortions.
