Technical release notes - PIX4Dsurvey
This article summarizes all PIX4Dsurvey versions, including new capabilities, additional updates, and bug fixes.
To download the latest or authorized previous versions of PIX4Dsurvey available for your licenses, log in with your license account. For more information click here.
Version 1.86
Version Release date Release Type Installer
1.86.0 December 2, 2025 Stable Windows Mac
1.86.1 February 16, 2026 Stable Windows Mac
1.86.1
Bug fixes
  • Fix crash when opening native file explorer on Windows
1.86.0
Additional Updates and Improvements
  • Coordinates in the status bar now display the elevation at the hovered location in both display and project CRS units
Bug fixes
  • Fixed an issue where the column format in the import dialogs did not consistently update to reflect the selected columns
  • Fixed an issue where the "Move to layer" options in the context menu and the main Edit menu displayed incorrect layer names and colors
  • Fixed an issue where LandXML files failed to import if the file extension was capitalized (e.g., “.XML”)
  • Fixed an issue to ensure that polylines generated with the offset tool are parallel to the original in all situations
Version 1.85
1.85.0 November 11, 2025 Preview Windows Mac
Disclaimer: The preview version contains new features and bug fixes. Documentation and support are not available. We recommend testing the preview version before using it for production work.
1.85.0
New Capabilities
  • Added the option to import a base surface from a LandXML file for volume computation
  • Added a new dialog to select both the organization and license type after logging in
  • Added an “Ortho mode” button to the section view toolbar to easily toggle 90-degree angle vectorization
  • Added Ukrainian as an available language
  • Added support for two new geoid models:
    • Norway/Svalbard: Svalbard_EGG2015_2024
    • Netherlands/Bonaire: BONGEO2004
  • Changed the "Add keyframe" shortcut to Ctrl+K
  • Updated the user account menu: "Organizations" is now "Organizations & licenses", "Licenses" is now "Plan and licenses", and icons were added for external links
  • Improved the rendering performance of contour lines in the 3D view
Bug fixes
  • Fixed an issue where the sky background would flicker in orthographic mode
Version 1.84
1.84.0 October 20, 2025 Preview Windows Mac
1.84.0
New Capabilities
  • Added support for a new geometry type: arc
  • Updated application icons on macOS to follow the macOS 26 style guidelines
Bug fixes
  • Fixed an issue that could cause the second upload of layers to fail
  • Fixed an issue where the “View project in PIX4Dcloud” links and menu options were not working correctly
Version 1.83
1.83.0 September 30, 2025 Preview Windows Mac
1.83.0
  •  Added a 3-point method for creating circles (by defining three points on the circumference)
  • Added the horizontal projection distortion factor to the information popup for the “Distortion-aware measurements” setting
  • Added an “Open project” option to the project context menu on the welcome page
Version 1.82
1.82.0 September 10, 2025 Preview Windows Mac
1.82.0
  •  The SHIFT key can now be used to extend color selection
  • The side panel can now be moved and docked to new locations by dragging and dropping it to the top or bottom of the sidebars
  • Added warnings for file paths that are considered too long
  • Added elevation labels to contour lines in 3D
Bug fixes
  • Fixed a crash that occurred when importing an unsupported or corrupted LAS file
  • Resolved an issue that prevented projects from being opened from network drives on Windows
Version 1.81
1.81.1 August 27, 2025 Stable Windows Mac
1.81.0 August 13, 2025 Stable Windows Mac
1.81.0
  • Improved performance when adding new layers, placing markers, and creating geometry in projects with a large number of existing layers
  • Improved the zoom behavior in the 3D view when using a touchpad
Bug Fixes
  • Fixed images being non-square in the full-screen view of the image viewer
  • Fixed JPEG compressed TIFF images not being displayed in the image viewer
  • Fixed an issue where layers would stay disabled after editing a vertex
  • Grids and point clouds that are importing or generating no longer show in the content panel until they are finished
  • Fixed the UI freezing when selecting a large closed polyline
1.81.1
Bug fixes and improvements
  • Fixed a crash that occurred when importing an unsupported or corrupted .las file
  • Fixed an issue with opening projects from network drives on Windows
Version 1.80
Version Release date  Release type Installers
1.80.0 July 22, 2025 Preview Windows Mac
1.80.0
What's new
  • Added 2D and 3D area properties to closed polylines
  • Improved the volume calculation experience by disabling it when no point cloud is visible
  • Added link to “Ask Pixie” in the welcome view and “Help” menu
  • Improved usability in the welcome view: projects can now be opened with a double-click
Information
  • Improved the polygon selection tool for quicker vectorization
  • Fixed issues in processing and exports when the path is too long on Windows
  • Fixed an issue where distortion-aware measurements were not correctly exported for volumes CSV export
Version 1.79
1.79.0 July 1, 2025 Preview Windows Mac
1.79.0
What's new
  • Sections can now be created from the 3D viewer toolbar rather than the Section view panel
  • Fixed an issue where the opening time for some projects had increased
  • Fixed an issue where importing WKT would fail if the unit name did not match the expected format
Version 1.78
1.78.0 June 12, 2025 Preview Windows Mac
1.78.0
What's new
  • The TIN color can now be changed from the content panel
  • Added a progress bar in the Dock icon on macOS during processing
  • Fixed an issue where custom color swatches could not be added for content panel color settings
Version 1.77
1.77.0 May 21, 2025 Preview Windows Mac
1.77.0
What's new
  • Added a light theme to improve accessibility for users
  • Added support for using a custom logo when exporting videos
  • Fixed an issue where the CRS was not written when exporting TIN as LandXML
Version 1.76
1.76.1 May 27, 2025 Stable Windows Mac
1.76.0 April 24, 2025 Stable Windows Mac
1.76.1
1.76.0
What's new
  • Added a new geoid model:
    • Japan: JPGEO2024
  • Updated the point cloud point size slider to use a logarithmic scale
  • Fixed an issue where certain sections in the export panel were incorrectly preselected for new projects
  • Fixed the issue where PIX4Dsurvey occasionally uploaded projects to the user's "default" organization instead of the organization chosen via the "Switch organization" tool
Version 1.75
1.75.0 April 4, 2025 Preview Windows Mac
1.75.0
What's new
  • Added actions to restore disabled point cloud points
  • Added a new button in the content panel to focus on point clouds, geometries, and sections in the 3D viewer.
  • Added new geoid models:
    • Hungary: Geoid2014
    • Greece: GR_HEPOS2011
Information
  • Removed share links from the "Share to PIX4Dcloud" upload confirmation dialog. Share links must be generated on PIX4Dcloud
  • Disable the export feature from trials, except for the log files and video animation.
Versions 1.74
1.74.0 March 13, 2025 Preview Windows Mac
1.74.0
  • Fixed a crash when continuing a catenary curve.
Versions 1.73
1.73.0 February 17, 2025 Preview Windows Mac
1.73.0
What's new
  • Available in Czech language
  • Fixed an issue where the join polyline action was visible but the polylines cannot be joined
Versions 1.72
1.72.0 January 27, 2025 Preview Windows Mac
1.72.0
What's new
  • Distances can be converted to and from polylines.
  • The status center text is simplified to avoid elided text.
  • Fixed an issue that prevented the export of large point clouds to LAS 1.4.
Versions 1.71
1.71.0 January 6, 2025 Stable Windows Mac
1.71.0
What's new
  • Improvements related to the point cloud rendering
  • Improved performance for exporting flythrough videos
  • Running and queued tasks can now be canceled in the tree view of the Status center
  • Improved performance on import of LAS point clouds
  • The section box can now be edited in the section view directly and renders on top of objects in the scene
  • The UI elements for coloring the point clouds by elevation are now respecting the display unit
  • Prevent freeze of the application while saving and resetting a view in the Flythrough panel
  • Circles can now be expected in the export section in the Section view panel
  • Fixed a bug when “Color by elevation” didn't respect the ASPRS classes' visibility
  • Fixed an issue where selecting geometry in the Content panel would not clear existing selection
  • Fixed an issue where selecting different geometry types would sometimes not show the simplify and alignment buttons in the Properties panel
  • Fixed an issue that prevented the display unit set by the user from being correctly restored when opening a project
Versions 1.70
1.70.1 November 29, 2024 Preview Windows Mac
1.70.0 November 25, 2024 Preview Windows Mac
1.70.1
  • Stability improvements
1.70.0
What's new
  • Exposed a slider in 3D viewer settings to control the density of the rendered glTF point cloud points
  • Updated the properties panel related to volumes. Volumes can now be computed using the viewer toolbar
  • Added support for importing Trimble CAL files to define CRSs
  • Added support for ESRI’s “Local” projection in CRS definitions
  • Circles can now be created and aligned with the section view
  • Added support for Korean geoid model KNGeoid24 as a user-provided geoid model
  • Fixed a source of crashes that could occur when too many files were open at the same time
Versions 1.69
1.69.0 November 5, 2024 Preview Windows Mac
1.69.0
What's new
  • Added option to compute volumes from the content panel, viewer right-click actions menu and top menu bar
  • The escape shortcut (Esc) will now finalize geometry during geometry creation rather than remove it
  • Improvements to the layout of the section view export to select the content more easily
  • Fixed an issue with the section step size not working properly in non-metric coordinate systems
Versions 1.68
1.68.1 October 22, 2024 Stable Windows Mac
1.68.0 October 15, 2024 Stable Windows Mac
1.68.1
Bug fixes
  • Fixed an issue where the section step size is not working properly in non-metric coordinate systems
1.68.0
What's new
  • Added button in the section view toolbar to allow snapping to point cloud points when creating and editing geometry in the section view
  • Added a recommendation for the users uploading on PIX4Dcloud a point cloud in a deprecated format
Bug fixes
  • Fixed an issue where a geometry was deselected when its vertices were deleted
  • Various other bug fixes
Versions 1.67
1.67.1 October 3, 2024 Preview
1.67.0 September 24, 2024 Preview
1.67.1
Bug fixes
  • Fixed the application hanging when reading images metadata in some cases
  • Fixed issue for some EUM users receiving a "No license available" message
1.67.0
What's new
  • Improvements on internal point cloud format (glTF):
    • Upload larger point clouds to PIX4Dcloud
  • Added remote device deactivation
  • Added on/off toggle for the section view’s grid
  • Added option for smaller section box dimensions and step intervals
  • Added sub-sections to the Settings panel
Versions 1.66
1.66.0 August 29, 2024 Preview
1.66.0
What's new
  • Added option to Help menu to allow resetting the user onboarding experience
Versions 1.65
1.65.0 August 5, 2024 Preview
1.65.0
What's new
  • New geoid models for Austria and New Zealand
  • Snapping window indicating the depth of the objects being snapped to. This enables more accurate and efficient vectorization
  • Various bug fixes
Versions 1.64
1.64.0 July 16, 2024 Preview
1.64.0
What's new
  • Added native ARM application support that speeds up processing significantly on macOS
  • Added a layer template manager to facilitate the handling of multiple layer templates
  • Added a search bar for layers in the content panel
  • Section box rotations snap to 90-degree angles
  • Added a setting to make the application take into account the projection distortion when doing measurements
  • Various bug fixes
Versions 1.63
1.63.1 August 15, 2024 Stable
1.63.0 June 24, 2024 Stable
1.63.1
  • Various bug fixes
1.63.0
What's new
  • Removed Assisted curb detection and Automatic registration features
  • Improvements and bug fixes related to:
    • Section views
    • the import of PIX4Dmatic projects
  • Various improvements and fixes
Versions 1.62
1.62.0 June 3, 2024 Preview
1.62.0
What's new
  • Renamed Profile View to Section View and improved it to support arbitrary orientation and multiple sections. Improved the vectorization within the Section View to snap the vertices to the section plane
  • Draping of the polylines within the section view respects the section box
  • Improved geometry imports with layer color assignment and alphabetical order
  • Added display of release notes to inform on new functionalities after new installation
  • Added user-provided geoid support for Estonia (EST-GEOID2017)
  • Fixed issue of wrong export of video animation when multiple projects are open at the same time
  • Fixed a UI glitch for the default layer templates
  • Fixed support article links
Known issues
  • macOS version may take several minutes for the application to start. PIX4Dsurvey team is working on it
Versions 1.61
1.61.1 May 13, 2024 Preview
1.61.1
What's new
  • Added “Save copy” option to clone a project
  • Added option to have side panels as separated windows
  • Added labels for markers in the 3D view and Video & views panel
  • Added new resolutions for the video flythrough export (720p, 480p)
  • Upgraded to macOS Sonoma (previous version macOS Monterey is not supported anymore)
  • Added Training link to Welcome view
  • Fixed an issue with badly scrambled fonts on specific Windows machines
  • Fixed an issue with the image viewer when the top bar menu disappears while scrolling the image viewer
  • Fixed a half-pixel shift for user-provided geoid model files
Known issue
  • PIX4Dsurvey loses image marks for geometry vertices when importing PIX4Dmatic projects
Versions 1.60
1.60.0 April 29, 2024 Preview
1.60.0
  • Fixed issue with import of Trimble SX10 .las files
  • Fixed issue with the display of images when importing a PIX4Dmapper or PIX4Dmatic project
  • Fixed image viewer issue with point selection in 3D viewer
  • Fixed issue in the profile view
  • Fixed issue with vertex alignment
  • Fixed issue with outdated mechanism for volumes when adding a vertex
Versions 1.59
Version
Release date
Release type
1.59.0
April 8, 2024
Preview
1.59.0
What's new
  • Added Support for the Geoids:
    • Czech Republic: CR-2005
    • Portugal: GeodPT08
    • Corsica: RAC23
  • Project view improvements:
    • Added a dedicated panel for geometries, constraints, and ROI properties
    • Added option to expand layers to view and select their geometries
    • Added option to move the side panels left and right with Drag & Drop
    • Added option to select a layer with a single click, rename a layer with a double click
Versions 1.58
Version
Release date
Release type
1.58.3
April 29, 2024
Stable
1.58.2
March 27, 2024
Stable
1.58.1
March 18, 2024
Stable
1.58.3
  • Various fixes and improvements
1.58.2
  • Fixed bug with wrong volume name in the volume report
1.58.1
What's new
  • Added Apply template menu item for layer templates
  • Added option to import and export layer templates
  • Added collapsible processing panel sections
Versions 1.57
Version
Release date
Release type
1.57.0
February 28, 2024
Preview
1.57.0
What's new
  • Added option to set the Coordinate Reference System (CRS) for an empty project.
  • Added option to allow import of LAS and LAZ point clouds in geographic coordinates.
  • The Vector and Volume layers are now merged into a single layers panel.
  • Added support for the Korean Geoid model (KNGeoid18).
  • Added the possibility to (re)compute all volumes in a layer
  • Fixed crashes in geometry creation.
  • Fixed crash on LAZ file import.
  • Fixed the deletion of volume vertices.
  • Fixed the crash in the volume computation.
Versions 1.56
Version
Release date
Release type
1.56.0
January 31, 2024
Preview
1.56.0
  • Various bug fixes
Versions 1.55
Version
Release date
Release type
1.55.0
January 11, 2024
Preview
1.55.0
  • Various bug fixes
Versions 1.54
Version
Release date
Release type
1.54.2
December 20, 2023
Stable
1.54.1
December 11, 2023
Stable
1.54.0
December 4, 2023
Stable
1.54.2
  • Fixed bug with image viewer not showing geometries after bookmarks or fly-through video was added
1.54.1
  • Fixed bug when importing .las/.laz files
1.54.0
What's new
  • Added video fly-through feature
  • Added persistent distance measurements
  • Added disabled points panel
  • Improvements in the video flythrough feature
  • Fixed various crashes
Known issue
  • Issue when importing a .las/.laz file
Versions 1.53
Version
Release date
Release type
1.53.0
November 16, 2023
Preview
1.53.0
What's new
  • Fixed issue when disabled points were imported from PIX4Dmatic projects
  • Fixed issue when the order of polygons and volumes vertices were broken after another vertex was imported
  • Fixed issue when points belonging to hidden classes could be used for the vectorization
  • Fixed issue when modifying the volume boundary, the "outdated" label is not displayed, and incorrect volume values are exported
Versions 1.52
Version
Release date
Release type
1.52.1
October 30, 2023
Preview
1.52.0
October 17, 2023
Preview
1.52.1
  • Fixed occasional crash when starting application
  • Fixed bug when editing volumes
1.52.0
  • Various bug fixes and improvements
Versions 1.51
Version
Release date
Release type
1.51.1
November 15, 2023
Stable
1.51.0
October 17, 2023
Stable
1.51.0
  • Fixed bug when disabled points were not imported properly from PIX4Dmatic
  • Fixed issue with vertex insertion and volume computation
1.51.0
What's new
  • Available in Turkish language
Versions 1.50
Version
Release date
Release type
1.50.0
September 7, 2023
Preview
1.50.0
What's new
  • Added Layer templates
Versions 1.49
Version
Release date
Release type
1.49.0
August 17, 2023
Preview
1.49.0
  • Various bug and crash fixes
Versions 1.48
Version
Release date
Release type
1.48.0
July 26, 2023
Preview
1.48.0
What's new
  • Added Manual Registration option to align sub-projects based on markers
  • Added optional description for geometries
  • Updates in the UI
Versions 1.47
Version
Release date
Release type
1.47.2
July 12, 2023
Stable
1.47.1
June 26, 2023
Stable
1.47.2
  • Fixed crash when rendering large volumes
  • Fixed the GeoTIFF export for the non-ASCII file names
  • Improvements in Profile view panel layout
1.47.1
  • Import CSV with any column name, regardless of the coordinate system
  • Export markers to CSV with improved description, including layer name as a label
  • Added shortcuts for roof and wall detection
  • Improved CRS handling from PIX4Dmapper
Versions 1.46
Version
Release date
Release type
1.46.0
May 23, 2023
Preview
1.46.0
What's new
  • Added wall detection
  • Added SSO support for subscribed companies
  • Added GCG2016 geoid model (Germany) and SLO_VRP2016/Koper geoid model (Slovenia).
  • Available in the Portuguese language
  • Fixed volume computation speed issue; now the speed is comparable to PIX4Dsurvey 1.33 and prior
  • Fixed issue with One-Time Charge (OTC) educational license handling
  • Several crashes and bug fixes
Other notable
  • Support for macOS Ventura (13.0)
  • Withdraw of support for macOS Big Sur (11.0)
Versions 1.45
Version
Release date
Release type
1.45.2
May 9, 2023
Preview
1.45.1
May 4, 2023
Preview
1.45.2
  • EULA updated in the installer.
  • Added support for the import of projects with many images.
  • Various bug fixes.
Versions 1.44
Version
Release date
Release type
1.44.0
April 12, 2023
Preview
1.44.0
What's new
  • Line draping with simplification. It fits a polyline in the 3D scene or the profile view to the visible point cloud points.
  • Images are sorted again in alphabetical order when a selection is cleared.
Versions 1.43
Version
Release date
Release type
1.43.1
April 06, 2023
Stable
1.43.1
Information: The stable release also includes all features and bug fixes since the previous stable PIX4Dsurvey version 1.39.2.
  • Profile usability improvements.
    • Wider line width when drawing profile.
    • Smaller point size in the profile view.
Versions 1.42
Version
Release date
Release type
1.42.0
March 02, 2023
Preview
1.42.0
What's new
  • Roof detection.
  • Display units are updated in all parts of the user interface when the display units are changed.
  • Geometry names must be unique per layer.
Versions 1.41
Version
Release date
Release type
1.41.0
February 07, 2023
Preview
1.41.0
What's new
  • Export grid of point to CSV.
  • Pole detection added to the automated object detection tools.
  • Display units can be changed by the user. This allows measurement in a unit other than the coordinate system units.
Versions 1.40
Version
Release date
Release type
1.40.0
January 17, 2023
Preview
1.40.0
What's new
  • Export TIN to GeoTIFF.
  • Fixed volume computation from DXF polygon.
Versions 1.39
Version
Release date
Release type
1.39.2
January 24, 2023
Stable
1.39.1
January 05, 2023
Stable
1.39.0
December 19, 2022
Stable
1.39.2
  • Fix the crash when PIX4Dsurvey is closed shortly after opening.
  • Fix the crash when creating a circle geometry.
1.39.1
  • Correction of the grid of points LAS/LAZ export.
1.39.0
What's new
  • Offset a polyline.
  • Manually set the width of the profile display.
  • The display of the licenses belonging to an organization now shows all valid licenses regardless of the expiration date.
  • Addition of Share to PIX4Dcloud button.
Versions 1.38
Version
Release date
Release type
1.38.0
November 17, 2022
Preview
1.38.0
What's new
  • The section now shows a reference grid.
  • The perpendicular profile allows to move the section along a polyline by keeping the profile perpendicular to the polyline.
  • The orientation of the profile can be switched.
  • Projects that are already shared to PIX4Dcloud can be opened directly with a click.
  • Added site localization support and support for .prj files to set the coordinate reference system.
  • Added arcgp-2006-sk geoid (Svalbard).
  • Bookmarks and profile in the status bar are changed from pulldown to tabs.
Versions 1.37
Version
Release date
Release type
1.37.0
October 25, 2022
Preview
1.37.0
What's new
  • It is now possible to step from one section to a parallel one.
  • The boundaries of the data taken into account for the profile are now shown as a box in the 3D view.
  • Added the option to select the organization during login for users with Organization support.
  • Improvements in panning in the 3D scene. The old panning method can still be used using the shift + mouse left-click combination.
  • An option to overwrite or append uploaded data when using the share to PIX4Dcloud tool is used.
  • Improvement of the volume display in the volume report.
  • The minimum point cloud point size is now smaller.
Versions 1.36
Version
Release date
Release type
1.36.0
October 07, 2022
Preview
1.36.0
What's new
  • Added Share to PIX4Dcloud feature.
  • All the points of a selected point cloud can be selected using Select all.
Versions 1.35
Version
Release date
Release type
1.35.0
September 26, 2022
Stable
1.35.0
What's new
  • The Triangular Irregular Network (TIN) can be generated from multiple grids and/or only from terrain vector layers.
  • Image orientation is respected in the image viewer.
  • Section and profile improvements. The height is automatically detected for profile fitting to view
  • Improved display of concave polygon edges for volumes.
Versions 1.33
Version
Release date
Release type
1.33.0
August 25, 2022
Preview
1.33.0
What's new
  • Creation of sections and profiles.
  • Markers can now be exported to CSV format.
  • The elevation histogram is now only calculated when color by elevation is enabled.
  • Circle properties have changed. The elevation of the circle is given.
  • The grid of point layers are moved to the TIN tab.
  • The Automatic registration tool is moved from the processing tab to the content panel.
Versions 1.32
Version
Release date
Release type
1.32.0
August 5, 2022
Stable
1.32.0
  • Various bug and crash fixes.
Versions 1.31
Version
Release date
Release type
1.31.0
July 12, 2022
Preview
1.31.0
What's new
  • Project Management: Input data (photogrammetry projects and point clouds) are now visible in the content bar on the left, where it is possible to toggle on and off the visibility of the data.
  • Added the RAF18b and RAF20 geoid models (France) and the hBG18 geoid model (Belgium).
  • Preview release notifications are deactivated by default, but they can be enabled in the app preferences.
  • Slope values are now shown with a single decimal place for both percent and degrees.
  • The Obscured object visibility slider was removed in favor of a more natural occlusion of geometry by the point clouds.
  • Various bugfixes.
Versions 1.30
Version
Release date
Release type
1.30.0
July 05, 2022
Stable
1.30.0
What's new since the last Stable version
  • Available in the Korean language.
Bug fixes and improvements since the last Stable version
  • Imported text or vector content always goes to the top of the list.
Versions 1.29
Version
Release date
Release type
1.29.0
June 02, 2022
Preview
1.29.0
What's new
  • Import text files for marker creation.
  • Curb extraction based on images.
  • Polyline properties now include slopes.
  • PIX4Dsurvey and PIX4Dmatic are always using the best graphics card by default.
  • Changes in the visibility settings won’t trigger a need to save the project.
Versions 1.28
Version
Release date
Release type
1.28.0
May 11, 2022
Preview
1.28.0
What's new
  • Automatic registration of point clouds.
  • Circle geometry vectorization.
  • Road point cloud classification.
  • Improved usability during quick vectorization.
  • Various bugfixes.
Versions 1.27
Version
Release date
Release type
1.27.0
April 20, 2022
Preview
1.27.0
  • PIX4Dcatch projects will have a small point cloud point size assigned by default for better visualization.
  • Volume base polygon can be exported as DXF, .shp, GeoJSON.
  • Export file names improved (using project name), timestamp or suffix also added.
Versions 1.26
Version
Release date
Release type
1.26.0
March 28, 2022
Stable
1.26.0
What's new
  • Display point cloud by elevation.
    • Includes live histogram for easy data interpretation.
  • Filter images by source (for combined projects).
  • Various bugfixes.
  • Change in the way the terrain filter works.
  • Several performance improvements.
Versions 1.25
Version
Release date
Release type
1.25.0
March 07, 2022
Preview
1.25.0
What's new
  • Stockpile Detection.
  • Assign a single elevation to all parts of a line, polygon, or volume.
  • Combine photogrammetry projects extended to allow projects with different CRS.
  • Fix of several crashes.
  • Correctly importing PIX4Dmapper vertical CRS.
Versions 1.24
Version
Release date
Release type
1.24.0
February 17, 2022
Preview
1.24.0
What's new
  • Project settings are found in the right panel.
  • Bookmarks positions are added in the Project settings in the right panel.
  • Combine multiple Pix4D photogrammetry projects with the same coordinate reference system into a single PIX4Dsurvey project.
  • Bookmarks in the scene.
Other notable
  • Support for macOS Monterey.
  • Withdraw of support for macOS Catalina.
Versions 1.23
Version
Release date
Release type
1.23.0
January 25, 2022
Preview
1.23.0
What's new
  • Camera positions for each viewport are saved when the project is closed.
  • Bookmarks to save a set of views of the 3D scene.
Bugfixes and improvements
  • Status center is now located at the bottom of the window, containing the bookmarks tab.
  • Better handling of options with both grid of points and point cloud points selected.
  • Crash on Windows 11 with Onedrive resolved.
  • Project changes (point cloud size, background color) are saved automatically.
    • Project settings saved in JSON file.
Known issues
  • PIX4Dsurvey fails to open on macOS Monterey.
Versions 1.22
Version
Release date
Release type
1.22.0
December 13, 2021
Stable
1.22.0
What's new
  • Low-pass Grid of points for better lidar compatibility and cleaner grid results.
    • Low-pass grid type added within the Smart Grid of Points.
  • Tin wrapping, allows concave TIN edges.
  • Ability to read PIX4Dmapper point cloud from the .p4b file. The way point cloud displayed in PIX4Dmapper is the same in PIX4Dsurvey.
  • Open in PIX4Dsurvey option is added in PIX4Dmapper.
  • Sorted layers.
  • Available in French and Chinese language.
  • Labels are included in the PDF volume report.
  • Reduced memory consumption when working with large point cloud selections.
Known issues
Versions 1.21
Version
Release date
Release type
1.21.0
November 24, 2021
Preview
1.21.0
What's new
  • Change layer lineweight.
  • Change custom class numeric ID.
  • Ability to assign classes from the top bar.
  • Object detection awareness of terrain class. Warning displayed if terrain layer is not created.
  • Ability to limit shorter contour loops during contour line creation.
Known issues
Versions 1.20
Version
Release date
Release type
1.20.0
November 2, 2021
Preview
1.20.0
What's new
  • Graphical Volume report in:
    • PDF and HTML on Windows.
    • HTML on MacOS.
  • Object detection for manholes and drains using the images.
  • Major and minor contour lines are projected onto the images.
Known issues
Versions 1.19
Version
Release date
Release type
1.19.0
October 12, 2021
Preview
1.19.0
What's new
  • Contour lines generation and export. Interval and color can be adjusted.
  • Net and Total volume included in the volume measurements.
  • Edit object names.
  • Improved vertex editor which allows now editing multiple characters in a single edit.
Versions 1.18
Version
Release date
Release type
1.18.0
September 21, 2021
Stable
1.18.0
What's new
  • Volume measurements:
    • Measure volume between point cloud and a base.
    • Export to LandXML format.
    • Volume report in .csv format.
    • Create volume from Polyline or Polygon selection.
  • Add and remove points from Selection set which is now partially transparent.
  • Invert selection option, to select all the unselected elements.
  • Import of PIX4Dcatch projects created in PIX4Dmatic, including the dense, depth and fused point cloud.
  • Import GeoJSON and Shapefiles (ability to change coordinate system).
  • Convert coordinate system of a project.
  • Imported point clouds use the selected global point cloud size.
  • Updated viewport layouts which are being saved.
  • Available in Spanish language.
  • Improved bounding box for large selections (performance improvement).
  • Improved cleanup of temporary files.
  • Fixed crash when opening the same project in two instances.
Versions 1.17
Version
Release date
Release type
1.17.1
August 27, 2021
Preview
1.17.0
August 25, 2021
Preview
1.17.1
  • Fixed issue when License required warning appears when accessing licenses in PIX4Dsurvey 1.17.0.
1.17.0
What's new
  • Export dialog with more flexible and complete export options. Moved to right side of the application.
  • Set and convert point cloud and .dxf coordinate reference system to projects coordinate reference system.
  • Improved polygon selection tool by adding shortcuts.
  • Fixed issue when using ESC to deselect object selection.
Known issues
  • License required warning appears when accessing PIX4Dsurvey licenses. The issue appears only in version 1.17.0 and affects both trial and paid licenses. Fixed in 1.17.1.
Versions 1.16
Version
Release date
Release type
1.16.0
August 3, 2021
Preview
1.16.0
What's new
  • Polygon selection. To select objects or points using a polygon and assign them to the desired class/ layer or delete them.
  • Application settings. To set the proxy, language and the default project path.
  • Improved Image toolbar by adding more columns.
  • Improved project loading time
  • Fixed crash when importing .las/.laz files with multiple WKT entries.
Versions 1.15
Version
Release date
Release type
1.15.1
July 13, 2021
Preview
1.15.1
What's new
  • Custom classes can be added for the point cloud classification.
  • Grid of point input can be refined by ASPRS class and Terrain class.
  • Polylines are simplified when created using the Road marking tool.
  • Fixed issue when multiple licenses cannot be associated with the same account.
Versions 1.14
Version
Release date
Release type
1.14.0
June 21, 2021
Stable
1.14.0
What's new
  • Color selection - based on the color of the selected point and the color threshold, points in a predetermined radius are selected. These points can then be assigned to a class or deleted.
  • Create markers starting from 2D images.
  • Available in Japanese language.
  • New Pix4D branding.
  • Fixed crash when moving a vertex on a locked layer.
  • Fixed issue when accents in the computer name prevents the license
Versions 1.13
Version
Release date
Release type
1.13.0
June 1, 2021
Preview
1.13.0
What's new
  • Import point cloud classification (ASPRS classes) and classes handling:
    • Reassign selected points between classes.
    • Show/hide individual or all classes.
    • Export a single class.
    • Show classes in monochrome.
  • Unselect point cloud points from a selection by using shift + left-click.
  • Stored 2D image marks from geometry edits.
  • Fixed crash when moving a vertex in images.
  • Exported .dxf file respects layer colors.
Versions 1.12
Version
Release date
Release type
1.12.0
May 10, 2021
Preview
1.12.0
What's new
  • Support of inputs and projects in arbitrary coordinate systems.
  • Export in GeoJSON format.
  • Change color of terrain classes.
  • Fixed bug with compound coordinate reference systems do not import properly in QGIS and in AutoDesk Civil 3D.
Versions 1.11
Version
Release date
Release type
1.11.0
April 20, 2021
Preview
1.11.0
What's new
  • Open logs folder available in the Menu bar.
  • Updated content panel to have tabs per content type.
  • Top view (7) now includes geometries.
Versions 1.10
Version
Release date
Release type
1.10.0
March 30, 2021
Stable
1.10.0
What's new
  • Import 2D dxf files and assign a single elevation to shift the objects.
  • Sky shader and background colors in the 3D view.
  • Project backup and recovery.
  • Slider for object opacity.
  • Orthographic view option.
Versions 1.9
Version
Release date
Release type
1.9.0
March 9, 2021
Preview
1.9.0
What's new
  • Reduce multi-selection by type of object.
  • Transparency of the point cloud changed to give a more realistic view.
  • Join two existing polylines or use existing geometry to continue vectorization.
  • Points in the grid of points can be selected by a rectangle and deleted.
Versions 1.8
Version
Release date
Release type
1.8.1
February 23, 2021
Preview
1.8.0
February 16, 2021
Preview
1.8.1
Bug fixes and improvements:
  • Fixed the vertex editor tool.
1.8.0
What's new
  • Grid of points improvements:
    • A selected point from the grid of points is displayed in images.
    • Delete points from the grid of points.
  • Snapping on existing vertices.
  • Import 3D dxf files.
  • Selected marker indication in the images
  • Road marking keyboard shortcut (R).
  • The global point size slider respects the undo and redo.
Known issues
  • Using Shift and Ctrl blocks zoom on macOS.
Versions 1.7
Version
Release date
Release type
1.7.0
January 26, 2021
Preview
1.7.0
What's new
  • Road marking tool to automatically follow road paint in the point cloud. To trigger the automatic marking, just click the starting point and again to indicate the direction.
  • Export point clouds, terrain classes, or grid of points to .las or .laz.
  • Increase the maximum size of the grid of points and change the default value for better visibility of generated points.
  • Multi-select geometries and then delete them or change layers.
  • Layers can be locked.
  • Unicode characters can be used in project names.
  • Fixed the crash when pressing Delete during 2D edits.
Known issues
Versions 1.6
Version
Release date
Release type
1.6.0
December 15, 2020
Stable
1.6.0
What's new
  • Smart Grid of points. Create and export a grid of points only where changes in terrain occur.
  • Distant outlier filter to detect and remove outliers in the point clouds.
  • Split a polyline at a vertex.
  • Improved point cloud display by loading fewer distant points (LoD).
  • Improved the camera display when using the Split view.
  • Fixed Grid display after point resize.
  • Fixed the point cloud display issue after defining the path of the images.
Versions 1.5
Version
Release date
Release type
1.5.0
November 24, 2020
Preview
1.5.0
What's new
  • Split the 3D view and view the scene from multiple angles simultaneously:
    • Split Horizontal
    • Split Vertical
  • Compatibility with PIX4Dmatic 1.5.0.
  • The point cloud is not redrawn when selecting an object in the 3D view.
  • Changing point cloud settings does not trigger a refresh of the Image Panel.
Versions 1.4
Version
Release date
Release type
1.4.0
November 3, 2020
Stable
1.4.0
  • TIN with Japanese characters loads properly.
  • Outdated TIN files removed from the disk.
  • Point size slider gives the same point sizes in metric or imperial projects.
  • Brought back the global Point size slider for point clouds.
  • Improved Image Panel:
    • Color changes do not trigger a refresh.
    • Vectorizing in the 3D view is not affected by missing images or slow external/network drives.
    • Fixed an issue when geometries are not displayed on images.
  • Added actions to the File and Edit menus.
  • Fixed Grid of points automatic color sequence.
  • Fixed display of long layer names in properties.
  • Improved Context menu when right-clicking on geometry or vertex.
  • Editing geometry using grid points is now possible.
  • Geometry stays selected when vectorizing is complete.
Versions 1.3
Version
Release date
Release type
1.3.0
October 6, 2020
Preview
1.3.0
What's new:
  • Export TIN to LandXML format.
  • Support for .las format version 1.4.
  • After processing a PIX4Dmatic project, click Open in PIX4Dsurvey in PIX4Dmatic to transition to PIX4Dsurvey.
  • Toggle on/off terrain class display by clicking the Enable/Disable filter button.
  • Added Remove Terrain Classification button to remove terrain classes from all point clouds.
  • Manually assign points to terrain classes using the Rectangle selection tool.
  • Fixed coordinates display when hovering over grid points.
Versions 1.2
Version
Release date
Release type
1.2.0
September 22, 2020
Preview
1.2.0
What's new:
  • TIN (Triangular Irregular Network) generation. Creation of a TIN using terrain layers and grid of points.
  • Terrain layer, a new vector layer concept that contains objects that will be used as part of the TIN.
  • The size and color of the points in the grid of points can be adjusted.
  • The size of points in each point cloud can be individually adjusted.
  • Color changes apply instantly.
  • Fixed issue with .bpc files creation for projects with long names.
  • The last folder path is selected as the default project folder.
  • Support for projects with left-handed coordinate systems.
Versions 1.1
Version
Release date
Release type
1.1.1
August 18, 2020
Stable
1.1.1
What's new:
  • New tool: Rectangle point selection and point deletion.
  • Increased Grid of points processing speed.
  • Zoom to selection.
  • User actions disabled during processing.
  • Improved color of the Grid of points and Terrain filter results.
Bug fixes:
  • Fixed bug with long Windows paths.
  • Fixed INSUNITS units in the exported .dxf file.
  • Fixed irregular spacing of Grid of points at edges.
  • Fixed Grid of points crash when using large point clouds.
  • Fixed layer name validator.
  • Fixed proxy authentication issue.
  • Fixed coordinate system display for never classified points.
  • Fixed vectorization unavailability for never classified points.
Known issues:
  • Left-handed coordinate systems are not supported. Left-handed coordinate systems have the horizontal axes defined in the order Northing-Easting, instead of Easting-Northing. E.g. SWEREF99 TM (EPSG 3006), JGD2011 / Japan Plane Rectangular series (EPSG 6669 and following). We recommend to not work with such coordinate systems and use their UTM equivalents instead. Fixed in 1.2.0.
Versions 1.0
Version
Release date
Release type
1.0.7
July 16, 2020
Preview
1.0.6
July 1, 2020
Preview
1.0.2
June 9, 2020
Stable
1.0.1
March 30, 2020
Stable
1.0.0
March 12, 2020
Initial release
1.0.7
What's new
  • Grid of points. Create and export with custom spacing on the original or classified point cloud.
  • Change layer color, save a custom color, persist colors across projects.
Bug fixes
  • Working directory typo.
  • Fixed point size settings.
Known issues
  • If PIX4Dsurvey 1.0.6 is installed, it needs to be manually uninstalled to install PIX4Dsurvey 1.0.7 on Windows.
  • Very large point clouds may crash the software when using the Terrain filter process. Fixed in 1.1.0.
  • If all point clouds are hidden, the Terrain filter process is disabled, although the Input point cloud parameter is set to All. Fixed in 1.1.0.
  • Some proxies that need authentication with username/password might not work. Fixed in 1.1.0.
  • Coordinates are not displayed for the Never classified points. Fixed in 1.1.0.
1.0.6
What's new
  • Terrain classification. Automatic point classification to terrain/non-terrain points.
  • PIX4Dmatic compatibility. PIX4Dmatic projects can be imported in PIX4Dsurvey.
  • Export vectorized objects in Shapefile format (.shp or .zip).
  • Proxy settings, necessary for local network protected by proxies.
  • Coordinate system update to GDAL 3.
Bug fixes
Known issues
1.0.2
Bug fixes
Known issues
  • On macOS, the app sometimes crashes when the app is closed by right-clicking on the icon of the app in the dock and selecting Quit.
1.0.1
Bug fixes
  • Fixed the crash when closing the project tab. Related to Windows Update KB4551762 for Windows versions 1903 and 1909.
  • Fixed the crash when closing an unsaved project tab when multiple tabs are open.
  • Fixed overlapping lines in the console caused by long file names.
Known issues
1.0.0
What's new
  • Seamless import of processed PIX4Dmapper projects (.p4d). Start the vectorization using original images and generated point cloud.
  • Import point clouds created with photogrammetry, laser scanners, LiDAR or other third-party tool in .las or.laz format.
  • Create polylines.
  • Create polygons.
  • Create markers.
  • Create catenary curves.
  • Vectorized objects appear in both 3D in and images.
  • Edit the position of the point by simply dragging it to the desired position in 3D.
  • Take advantage of original images to precisely place points.
  • Enter the desired coordinates of points manually or copy-paste a known position in the Vertex Editor.
  • Zoom in and pan on the images.
  • Manage the vectorized data in layers. Easily move objects between layers.
  • Export of all vectorized objects to .dxf format.
  • Export a single layer to .dxf format.
  • Toggle visibility of layers and point clouds on and off.
  • See properties and measurements of any object.
  • Integrated shortcuts for faster navigation and vectorization.
  • Undo/Redo of actions.
  • The Help section on the welcome screen with the link to Product documentation, Community and example datasets.
  • Works on Windows and macOS.
Known issues
  • PIX4Dsurvey is crashing when closing the project tab. The crash only happens on Windows 10 devices with the Windows Update KB4551762 for Windows versions 1903 and 1909. Fixed in 1.0.1.
