Home screen - PIX4Dfields
The Home screen is the first screen that appears when opening the application. It is the starting point to create new projects and to open existing projects.
General aspects of the dashboard
After logging in, the dashboard is the first screen that appears when opening PIX4Dfields, and lists all the projects that have been created.
PIX4Dfields home screen
Example demo datasets are located in these three cards.
PIX4Dfields_examples
Note: These and other examples can also be found in this article: Example use cases - PIX4Dfields.
Projects
This sections lists the projects available on the current device processed with your PIX4D account. Click + New project to create a new project.
New Project
Resources
This section contains a list of links, allowing to have  quick access to the following services:
On the dashboard, click the SETTINGS to see the App settings, Data handling, Account, and More options.
App settings
PIX4Dfields_App_Settings
  • (optional) The Units of the project can be modified by selecting the Metric or Imperial units.
  • (optional) Click on Language to change the language of the application.
    Note: For more information: How to set your language.
  • (optional) PIX4Dfields defaults to a satellite basemap, however a custom tile service basemap can be added.
    Note: For more information: Custom basemaps.
  • (optional) Customize PDF report
Data handling
PIX4Dfields_Data_Handling
  • Click on the Data storage folder to see where the projects are saved/stored.
    • All projects and files generated will be stored in this folder. Several file types will be present
    • The default location is typically under C:\Users\Username\Pix4Dfields.
      To modify the storage location of your projects, select a different folder in the Data storage folder settings.
      changeStorageFoldr
    • Changing your data storage folder will not move existing projects to the new location. To move projects please read: How to manage projects.
Account
PIX4Dfields_Account
More
  • Click Legal to access the TERMS OF USE and PRIVACY POLICY.
  • Click Acknowledgments to check the open-source technologies that PIX4Dfields uses.
Organization management
If the user belongs to more than one organization, the active organization is shown on the Home screen. Click this entry to switch to a different organization.
ChangeOrganization
What does the help and resources buttons show?
  • Click HELP AND RESOURCES at the top right of the window.
  • Information about PIX4Dfields appears as well as the used VERSION of the software.
  • (optional) On LEARN MORE links to video tutorials, webinars, community, knowledgebase, and contact support are available.
Organize all projects
To organize projects based on crop information or project structure
  1. Select ALL projects at the top right of the window.
  2. Click Farms, Clients, Organizations, Crop types, or Crop varieties to organize a project.
  3. The projects will be grouped depending on the category that has been chosen.
To organize projects based on date or name
  1. Click Sort by modification date, Sort by modification date (reversed), Sort by name, or Sort by name (reversed) at the top right of the window.
  2. The projects will be grouped depending on the category that has been chosen.
Individual project settings
What does the project settings show?
  1. Click the project menu at the bottom right of the project.
  2. A sidebar opens, to display information about the project which can be edited to include name, description, crop information, project structure, and data handling.
Note: For more information: Individual project settings.
