Radiometric correction - PIX4Dfields
Why radiometric correction?
Radiometric correction is required to be able to compare multispectral imagery taken at different points in time under different weather conditions, and to compute reliable index values.
The pixel values from the images depend on the lighting conditions and the camera sensor settings, among other variables, which usually change between flights. The correction solves that problem by compensating for external variables in order to estimate a physical property of the field. This is the reflectance factor.
The reflectance factor or more specifically, the hemispherical-directional reflectance factor, is a quantitative measure of the light reflection by an object which is illuminated by direct and indirect sunlight, like the crop. Because it does not depend on external variables, it should not change between flights unless there is a physical change in the crop.
What is radiometric correction?
In technical terms, radiometric correction refers to the process of computing an estimation of the at-object reflectance factor from images, by taking into consideration the scene illumination and sensor properties.
In the context of agriculture, it is the process of eliminating the effect of variable external factors, like weather conditions and camera sensor, to have a more precise indirect measurement of the physical properties of the crop.
This process is implemented in PIX4Dfields by an algorithm that corrects each pixel value based on a physical model of the image acquisition process, in particular, a model of light reaching the sensor. Many factors are involved in this process including but not limited to:
  • Sensor settings: shutter speed, ISO, and aperture.
  • Sensor properties: light transmission in the optics, sensing and digitisation in the chip.
  • Scene conditions: incoming sunlight, camera location, and orientation.
How does PIX4Dfields perform radiometric correction?
PIX4Dfields performs radiometric corrections in a way that is very similar to PIX4Dmapper, which is explained in: Radiometric Correction in PIX4Dmapper.
PIX4Dfields performs different types of radiometric correction, depending on the availability of the following sources of information:
Image EXIF tags. PIX4Dfields scans the image EXIF tags, where most of the information required by the radiometric correction can be found.
Sunshine sensor. The use of a sunshine sensor improves the overall correction results by including more information about the illumination on the field (sun irradiance and, when supported by the hardware, sun angle). For supported camera models, this information is stored in the image EXIF tags and automatically detected by PIX4Dfields.
Reflectance targets. The use of a radiometric calibration target (also called calibration panel) enables PIX4Dfields to calibrate and correct the images to reflectance according to a measurement given by the reflectance target. When using reflectance targets, the images must be imported for processing, like regular images, in order to be used for radiometric correction.
Thermal profile. The Parrot Sequoia+ camera creates a sequoia_therm.dat thermal profile file containing information that is used for radiometric correction. This file must be stored in the same folder as the images and is automatically taken into account.
Weather condition during capture. When required, PIX4Dfields will prompt the user for this information. It is therefore important to observe and save the weather condition during which a dataset was acquired.
The input images are radiometrically corrected individually before they are composed into the orthomosaic.
Note: Camera, Sun Irradiance, and Sun Angle using Illumination Model infers that PIX4Dfields uses the DLS2 model information.
For which cameras is radiometric correction performed?
Currently, the following cameras are supported for radiometric correction in PIX4Dfields:
  1. Parrot Sequoia and Sequoia+.
  2. Micasense RedEdge, RedEdge-M, RedEdge-P, RedEdge-MX, Altum and Altum-PT.
  3. Sentera 6x and Sentera 6x Thermal.
  4. DJI P4 multispectral (P4M) and Mavic 3 multispectral (M3M) :
    • These cameras are not fully radiometrically calibrated, only a relative calibration is done by the manufacturer: All bands are calibrated against the standard NIR band. Therefore, the cameras will not provide reflectance factors, but only relative values proportional to reflectance.
    • A reflectance target is required to obtain reflectance factors. Only Micasense and Sentera targets are compatible with the DJI P4 multispectral and Mavic 3 multispectral.
    • Without such a target, only self-normalizing indices produce meaningful results, i.e. indices that don't depend on the absolute value. Examples of such indices are NDVI, NDRE, VARI, SIPI2, LCI, BNDVI, and GNDVI. Not self-normalizing are TGI and MCARI.
    • The orientation of the sunshine sensor for the P4M is not provided by the manufacturer. Therefore, the sun angle cannot be accounted for, and only the correction type "Sun Irradiance" can be applied. Hence, weather condition is not required when processing.
  5. La Quinta DB2-Vision.
  6. Sentera NDRE/NDVI: Note that this camera does not provide a sun sensor, therefore the output is proportional to at-sensor radiance and a reflectance target is required to obtain reflectance factors.
  7. SenseFly modified Canon S110 NIR/RE: Note that this camera does not provide a sun sensor, therefore the output is proportional to at-sensor radiance and a reflectance target is required to obtain reflectance factors.
  8. Other modified cameras that provide the required radiometric information: See the camera requirements article for more information.
Why do I need to specify the weather conditions?
Weather and sun are significant factors that influence multispectral imagery. Cloud cover and solar position should be accounted for in order to minimize the effect of measurement errors caused by changes in ambient light. PIX4Dfields allows users to specify cloud cover with either overcast or clear sky options. In addition, if the camera is equipped with a sunshine sensor a sun angle correction will be performed under any weather conditions.
Important: If the weather conditions are not specified, then a sun angle correction cannot be performed. This will result in a less accurate radiometric correction.
Why do I have holes in my orthomosaic?
If certain pixels cannot be radiometrically corrected, they are marked internally, and not displayed (i.e. they are transparent). Such pixels appear as holes in the orthomosaic or index images.
Pixels cannot be radiometrically corrected if they are over or underexposed. This happens most often for highly reflective objects, such as cars or roofs.
What reflectance targets does PIX4Dfields support?
PIX4Dfields supports the following reflectance targets. Please note that not all targets are suited for all cameras:
  • Airinov Aircalib.
  • Parrot.
    Parrot reflectance panel
  • MicaSense targets are compatible with most camera brands and models.
    Micasense Panels Supported
  • Sentera targets are compatible with most camera brands and models.
    • Sentera has released new target models that will be supported starting from PIX4Dfields 2.13 and PIX4Dfields 2.14.
      Sentera target Supported 1Sentera target Supported
How to create good images of reflectance targets is described here: Radiometric calibration targets
It is not possible to manually add other brands of reflectance panels in PIX4Dfields. If you need to process a reflectance panel from a different manufacturer, please contact our support team and provide details about your specific situation.
How do I create reflectance target images?
The use of a radiometric calibration target enables PIX4Dfields to calibrate and correct the images to reflectance according to the values given by the reflectance target. Therefore, if the camera is not calibrated to allow a targetless workflow, the use of reflectance target images generally improves the accuracy of the radiometric correction.
How do I know if the reflectance target was used?
PIX4Dfields automatically detects supported reflectance targets when the images are imported. Detection at import and use during radiometric correction are confirmed in the following places:
  1. Import. After importing a multispectral dataset, the IMPORT DETAILS in the left sidebar display a message stating whether reflectance targets could be found. For more information: How to import files and start processing.
  2. Layer information. After processing, click the orthomosaic to display the Radiometric Correction Type that was applied. For more information: How to use the advanced layer visualization. The correction type that was used can also be found in the report.
  3. Log file. When a reflectance target is used, the project log contains a NOTICE entry that starts with Using reflectance target. Example:
NOTICE: Using reflectance target /path/to/IMG_0335_1.tif of type MicaSense for 0,0: Reflect area [ (618, 652) (691, 644) (700, 717) (627, 724) ], corrected value [ 0.340046 ] +/- [ 0.00656462 ], nominal reflectance [ 0.468375 ], sensitivity [ 0.726012 ]
Note: A message that some reflectance targets were not found means that radiometric correction continues without the reflectance target information.
To export the log files: How to export log files.
What is the best method to demonstrate that radiometric calibration was done correctly?
The recommended method is to use independent radiometric control points (also called radiometric checkpoints). These are known-reflectance surfaces placed in the field and not used as the calibration target. After processing, the reflectance values in the orthomosaic at those locations are compared with the known values of the control points. That comparison verifies the integrity of the reflectance values in the final orthomosaic.
A reflectance target is used to calibrate the images. Radiometric control points are used to validate the result. Using the same panel for both calibration and validation does not demonstrate that the correction was done correctly.
For a published example of this assessment method: Assessment of the radiometric accuracy in a target-less workflow using PIX4D software (IEEE). Full text: ResearchGate.
What’s the difference between PIX4Dfields and PIX4Dmapper regarding radiometry?
In principle, PIX4Dfields uses the same radiometric correction as PIX4Dmapper. However, there are a few slight differences in its usage:
  1. In PIX4Dmapper, the correction type can be chosen by the user. For ease of use, PIX4Dfields does not let the user choose, but automatically determines the best possible correction type from the data, taking into account the weather condition if applicable. Unlike PIX4Dmapper, PIX4Dfields can also do sun angle correction for overcast conditions. The correction type that was used can be found in the report.
  2. PIX4Dfields uses a different, faster and less accurate way than PIX4Dmapper to compute the camera position and orientation and to stitch the images. Since that information is used in the radiometric correction, the reflectance values computed by PIX4Dfields can be slightly different to the ones by PIX4Dmapper due to minor differences in the computed camera orientation.
Try PIX4Dfields now
Register for a free 15-day trial to test radiometric correction in PIX4Dfields.
