Other resources
Example projects - real photogrammetry data
Get started with real photogrammetry sample data acquired with drones or UAV and create 2D and 3D outputs.
Download any of these projects for free* and explore Pix4D’s desktop functionalities with a real dataset.
Important: *These datasets may only be used for personal or professional training. For commercial or promotional use, “Courtesy of Pix4D / pix4d.com” must be displayed and all the text linked to pix4d.com. For more information on usage, contact our marketing team.
Using real data demonstrates what Pix4D software can do and will help you understand what’s needed when collecting your own data.
Not sure where to begin? Follow the instructions below each data set to create your first project.
For more inspiration, check out our Community Hall of Fame.
LOGO_KB_Demo_Projects_Mapper.pngPIX4Dmapper example projects
Quarry
Download dataset or view in PIX4Dcloud
The goal of this project is to generate a DSM and an Orthomosaic of a quarry using an eBee drone with a SenseFly S.O.D.A.
General project information
Project
Location Switzerland
Average Ground Sampling Distance (GSD) 5.40 cm / 2.13 in
Area covered 0.5776 km2 / 57.7565 ha / 0.223 sq. mi. / 142.79 acres
Output coordinate system CH1903 / LV03
Geoid Height Above Bessel 1841. Ellipsoid = 0 meters
Image acquisition
UAV eBee Classic (senseFly)
Image acquisition plan 1 flight, double grid flight plan
Camera senseFly S.O.D.A.
Images
Number of images 347
Image size 5472x3648
Image geolocation coordinate system WGS84
GCPs
Number of GCPs 9 3D GCPs
GCPs coordinate system CH1903 / LV03
Download project files
The dataset can be downloaded here and can be found processed on PIX4Dcloud here.
  • images: RGB images in JPG format
  • inputs/gcp_overview: images that help to identify each GCPs
  • inputs/gcpPositionsXYZ_EPSG21781.csv: GCP input geolocation file.
  • example_quarry_2.p4d: project file that can be opened in PIX4Dmapper.
Instructions
Process the dataset using the included .p4d project file
This section describes how to process the dataset in order to generate the DSM and the Orthomosaic of a quarry.
1. Open the project example_quarry_2.p4d.
2. On the menu bar, click View > Processing. The Processing bar opens at the bottom of the main window.
Note: As the goal of this project is to generate the DSM and the Orthomosaic, and as it has been taken using aerial nadir images, the template used for the Processing has been set to 3D Maps. This can be seen in Process > Processing Options....
3. On the Processing bar, click Start to start the processing.
Process the dataset creating a new project
This section describes how to create and process a project in order to generate the DSM and the Orthomosaic of a quarry.
A) Create a new project:
1. Start PIX4Dmapper.
2. On the Menu bar, click Project > New Project....
3. The New Project wizard opens.
4. In Name: Type a name for the project. In this example type example_quarry_2.
5. (optional) In Create In: click Browse..., and in the Select Project Location pop-up, navigate to select the folder where the project and results will be stored and click Select Folder.
Note: When the project is created, a folder named after the project name typed in the Name field will be created in the selected folder and will store all the results. The .p4d project file will also be stored in this folder.
6. (optional) Select the check box Use As Default Project Location to save all new projects in the selected folder.
7. In the section Project Type, keep selected the default option New Project.
8. Click Next.
The New Project wizard displays the Select Images window.
9. Click Add Directories... and select the images folder to add the images to the project.
10. Click Next.
The New Project wizard displays the Image Properties window. The image geolocation is automatically loaded from the image EXIF data and is given in WGS84 (latitude, longitude, altitude) coordinates with vertical coordinate system given by a Geoid Height Above WGS 84 Ellipsoid of 0 meters. The camera model is loaded from the camera model database (S.O.D.A._10.6_5472x3648 (SI002001AA7C00213) (RGB).).
11. Click Next.
The New Project wizard displays the Select Output Coordinate System window. By default the last output coordinate system selected in the software is selected.
12. Select Known Coordinate System CH1903 / LV03.
13. Select Advanced Coordinate Options and under Vertical Coordinate System select Geoid Height Above Bessel 1841 Ellipsoid. Set the value to 0.
14. Click Next.
The New Project wizard displays the Processing Options Template window.
15. Click 3D Maps to select the template.
Note: As the goal of this project is to generate the DSM and the Orthomosaic, and as it has been taken using aerial nadir images, the template to be selected is the 3D Maps.
16. Click Finish to finish the wizard and create the project. The Processing bar opens at the bottom of the main window.
B) Introduce and mark the GCPs:
1. On the Menu bar, click Project > GCP/MTP Manager....
2. Click Import GCPs....
8. On the Import Ground Control Points window, under Coordinates Order, select X, Y, Z option.
9. On the Import Ground Control Points windows, click Browse, select the GCP file gcpPositionsXYZ_EPSG21781.csv from the inputs folder and click OK.
10. On the Import Ground Control Points windows, click OK.
The GCPs and their coordinates are imported and can be visualized in the GCP/MTP Manager window.
11. On the GCP/MTP Manager window click OK.
12. On the Processing bar select 1. Initial Processing, deselect 2. Point Cloud and Mesh and 3. DSM, Orthomosaic and Index.
13. On the Processing bar, click Start to start the processing.
When step 1. Initial Processing is finished the rayCloud opens.
14. Mark the GCPs using the rayCloud following instructions 2. to 11. as described here How to import and mark ground control points (GCPs). The images in the folder inputs/gcp_overview help to identify the GCPs should be marked.
C) Generate the DSM and Orthomosaic
When the GCPs are marked and the project is re-optimized.
1. On the Processing bar, deactivate 1. Initial Processing and activate 2. Point Cloud and Mesh and 3. DSM, Orthomosaic and Index.
2. On the Processing bar, click Start to start the processing.
Building
The goal of this project is to generate the 3D model of a building taken by an AscTec Falcon 8 UAV.
Project
Location Germany
Average Ground Sampling Distance (GSD) 1.89 cm / 0.7 in
Area covered Undefined
Output coordinate system WGS84 / UTM zone 32N
Vertical Coordinate System: MSL egm96
Image acquisition
UAV AscTec Falcon 8 UAV (Ascending Technologies)
Image acquisition plan 1 flight, circular flight around the building
Camera Sony NEX-5 (RGB)
Images
Number of images 36
Image size 4592x3056
GCPs
Number of GCPs None
GCPs coordinate system None
  • images: RGB images in JPG format.
  • example_building.p4d: project file that can be opened in PIX4Dmapper.
Instructions
To process the dataset in order to generate the 3D model of a building:
1. Open the project example_building.p4d by double clicking it.
2. On the Menu bar, click View > Processing. The Processing bar opens at the bottom of the main window.
Note: As the goal of this project is to generate only the 3D model (no DSM and orthomosaic), the template used for the processing has been set to 3D Models. This can be seen in Process > Processing Options... .
This section describes how to create and process a project in order to generate a 3D model of a building.
4. In Name: Type a name for the project. In this example type example_building.
8Click Next.
10. Click Next.
The New Project wizard displays the Image Properties window. The image geolocation is automatically loaded from the image EXIF data and is given in WGS84 (latitude, longitude, altitude) coordinates with vertical coordinate system given by MSL egm96. The camera model is loaded from the camera model database (NEX-5_E16mmF2.8_16.0_4592x3056 (RGB)).
11.Click Next.
12. Under Unit, select m.
13. Select Auto Detected.
14. Select Advanced Coordinate Options and under Vertical Coordinate System select MSL > egm96.
Note: As the goal of this project is to generate only the 3D model (no DSM and orthomosaic), and as it has been taken using terrestrial images, the template to be select is the 3D Models template.
15. Select the 3D Models template.
B) Process the project:
1. On the Processing bar, click Start to start the processing.
Cadastre
The goal of this project is to generate the DSM and the Orthomosaic of a village using a Canon IXUS 120IS.
Project
Average Ground Sampling Distance (GSD) 5.1 cm / 2 in
Area covered 0.2128 km2 / 21.2822 ha / 0.0822 sq. mi. / 52.6167 acres
Vertical Coordinate System: Geoid Height Above WGS 84 Ellipsoid = 0 meters
Image acquisition
UAV swinglet CAM (senseFly)
Image acquisition plan 1 flight, grid flight plan
Camera Canon IXUS 120IS (RGB)
Images
Number of images 68
Image size 4000x3000
GCPs
Number of GCPs None
  • example_cadastre.p4d: project file that can be opened in PIX4Dmapper.
Instructions
This section describes how to process the dataset in order to generate the DSM and the Orthomosaic of a village.
1. Open the project example_cadastre.p4d.
Note: As the goal of this project is to generate the DSM and the Orthomosaic, and as it has been taken using aerial nadir images, the template used for the processing has been set to 3D Maps. This can be seen in Process > Processing Options....
This section describes how to create and process a project in order to generate the DSM and the Orthomosaic of a village.
4. In Name: Type a name for the project. In this example type example_cadastre.
5. (optional) In Create In: Click Browse, and in the Select Project Location pop-up, navigate to select the folder where the project and results will be stored and click Select Folder.
8. Click Next.
10. Click Next.
The New Project wizard displays the Image Properties window.  The image geolocation is automatically loaded from the image EXIF data. The coordinate system is automatically set to WGS84 with vertical coordinate system given in MSL egm96. As the image geolocation is given in WGS 84 with vertical coordinates system in Geoid Height Above WGS 84 Ellipsoid = 0, the coordinate system has to be changed.
11. On the Image Geolocation > Coodinate System clickEdit....
12. On the Select Image Coordinate System window, select Known Coordinate System with coordinate system WGS 84.
13. On the Select Image Coordinate System window, select Advanced Coordinate Options, and under Vertical Coordinate System select Geoid Height Above WGS 84 Ellipsoid. Set the value to 0.
14. On the Select Image Coordinate System window, click OK.
In the Image Properties window, the camera model is loaded from the camera model database (CanonDIGITALIXUS120IS_5.0_4000x3000 (RGB)).
15. Click Next.
16. Select Auto Detected.
17. Select Advanced Coordinate Options and under Vertical Coordinate System select Geoid Height Above WGS 84 Ellipsoid. Set the value to 0.
18. Click Next.
19. Click 3D Maps to select the template.
Note: As the goal of this project is to generate the DSM and the Orthomosaic, and as it has been taken using aerial nadir images, the template to be selected is the 3D Maps template.
20. Click Finish to finish the wizard and create the project. The Processing window opens at the bottom of the main window.
Construction dataset
Download dataset
The goal of this project is to get an orthomosaic and a 3D point cloud of construction site.
Project
Average Ground Sampling Distance (GSD) 1.83 cm / 0.72 in
Area covered 0.1326 km2 / 13.2612 ha / 0.0512 sq. mi. / 32.786 acres
Image acquisition
UAV eBee Classic
Camera S.O.D.A 10.2 (RGB)
Images
Number of images 197
GCPs
Number of GCPs None
The dataset can be downloaded here.
  • bim_dataset.p4d: project file that can be opened in PIX4Dmapper
Instructions
This section describes how to process the dataset in order to generate an orthomosaic.
A) Process the project:
1. Open the project bim_dataset.p4d by double clicking on the file.
2. On the menu bar, click View > Processing. The Processing window opens at the bottom of the main window.
Note: As this project's goal is to generate an orthomosaic for a construction site, the 3D Maps template has been selected.
3. On the Processing window, click Start to start the processing.
This section describes how to create and process a project in order to generate an orthomosaic for the whole project.
2. On the menu bar, click Project > New Project....
4. In Name: Type a name for the project. In this example type bim_dataset.
5. (Optional) In Create In: Click on Browse, and on the Select Project Location pop-up window, navigate to select the folder where the project and results will be stored and click Select Folder.
Note: When the project is created, a folder with the same name as the project name typed in the Name field will be created in the selected folder and will store all the results. The .p4d project file will also be stored in this folder.
6. (Optional) Activate the check box Use As Default Project Location to save all new projects in the selected folder.
8. Click Next.
10. Click Next.
The New Project wizard displays the Image Properties window. The image geolocation it is already set in the Image Properties window under section Image Coordinate System and does not need to be changed. The image geolocation is loadedThe camera model is loaded from the camera model database (S.O.D.A_10.2_5472x3648 (RGB)).
11. Click Next.
12. On the left of the window, select the 3D Maps template.
13. Click Next.
14. Under Unit, select m.
15. Select Auto Detected.
16. Select Advanced Coordinate Options and under Vertical Coordinate System select Geoid Height Above WGS 84 Ellipsoid. Set the value to 0.
17. Click Finish to finish the wizard and create the project. The Processing window opens at the bottom of the main window.
1. On the menu bar, click Process > Processing Options... to open the Processing Options window.
2. On the Processing window, click Start to start the processing.
Once processing is finished, the Orthomosaic can be visualized and modified in the Mosaic Editor.
Eagle statue – Handheld camera
Download dataset
The goal of this project is to generate the 3D model of the statue of an eagle by taking images from the ground using a Canon EOS 7D with perspective lens.
Project
Average Ground Sampling Distance (GSD) Undefined
Output coordinate system Arbitrary
Image acquisition
UAV None
Image acquisition plan 2 walks around the statue, each at a different altitude
Camera Canon EOS 7D (RGB)
Images
Number of images 44
Image size 5184x3456
Image geolocation coordinate system None
GCPs
Number of GCPs None
  • example_eagle.p4d: project file that can be opened in PIX4Dmapper
Instructions
This section describes how to process the dataset in order to generate the 3D model of the statue of an eagle.
1. Open the project example_eagle.p4d by double clicking it.
Note: As the goal of this project is to generate only the 3D model (no DSM and Orthomosaic), and as it has been taken using terrestrial images, the template used for the Processing has been set to 3D Models. This can be seen in Process > Processing Options...
This section describes how to create and process a project in order to generate the 3D model of the statue of an eagle.
4. In Name: Type a name for the project. In this example type example_eagle.
5. (optional) In Create In: Click on Browse, and on the Select Project Location pop-up, navigate to select the folder where the project and results will be stored and click Select Folder.
8. Click Next.
10. Click Next.
The New Project wizard displays the Image Properties window. No image geolocation is detected. The camera model is loaded from the camera model database (CanonEOS7D_EF-S15-85mmf/3.5-5.6ISUSM_15.0_5184x3456 (RGB)).
11. Click Next.
12. Select Arbitrary Coordinate System with Unit meters.
13. Click Next.
Note: As the goal of this project is to generate only the 3D model (no DSM and orthomosaic), and as it has been taken using terrestrial images, the template to be selected is the 3D Models.
14. Select the 3D Models template.
15. Click Finish to finish the wizard and create the project. The Processing bar opens at the bottom of the main window.
1. On the Processing bar, select 1. Initial Processing, and deselect 2. Point Cloud and Mesh.
When Initial Processing finishes, the rayCloud opens.
3. Use the rayCloud to define a Processing Area to remove noisy points from the background and to keep only points of the statue. For more information about how to draw a Processing Area with the rayCloud: How to use a processing area in PIX4Dmapper Desktop.
Note: The Processing Area used:
4. Edit the Processing Area such that the height adjusts to the height of the statue. For more information about how to edit a Processing Area with the rayCloud: How to edit a processing area in the rayCloud.
Note: In the above Processing Area, the Maximum and Minimum Altitude are set to 50.00 [m] and -100.00 [m] respectively.
5. On the Processing bar, deselect 1. Initial Processing, and select 2. Point Cloud and Mesh.
6. On the Processing bar, click Start to start processing.
Forensic
Download dataset
The goal of this project is to generate the Point Cloud and the 3D Textured Mesh of a forensic scene.
Project
Location USA
Average Ground Sampling Distance (GSD) 0.24 cm / 0.09 in
Output coordinate system WGS84 / UTM zone 17N
Image acquisition
UAV DJI Phantom 3 Advanced
Image acquisition plan 1 flight, circular flight around the scene
Camera FC300 X (RGB)
Images
Number of images 69
GCPs
Number of GCPs None
  • example_forensic.p4d: project file that can be opened in PIX4Dmapper.
Instructions
This section describes how to process the dataset in order to generate the 3D model of a building.
1. Open the project example_forensic.p4d by double clicking it.
Note: As the goal of this project is to generate the point cloud and the 3D model (no DSM and orthomosaic) and as it has been taken using oblique images, the template used for the processing has been set to 3D Models. This can be seen in Process > Processing Options... .
8Click Next.
10. Click Next.
The New Project wizard displays the Image Properties window. The image geolocation is automatically loaded from the image EXIF data and is given in WGS84 (latitude, longitude, altitude) coordinates with vertical coordinate system given at Geoid Above Ellipsoid=0 m. The camera model is loaded from the camera model database (FC300X_3.6_4000x3000 (RGB)).
11.Click Next.
14. Select Advanced Coordinate Options and under Vertical Coordinate System select Geoid Above Ellipsoid=0.
Note: As the goal of this project is to generate the point cloud and the 3D model (no DSM and orthomosaic), and as it has been taken using oblique images, the template to be select is the 3D Models template.
Indoor mapping – Spherical camera
Download dataset
The goal of this project is to generate the 3D model of a church taken by an NCTech iSTAR spherical camera.
Project
Location "The Church of Santiago", located in Betanzos (A Coruña, Spain)
Output coordinate system Arbitrary Coordinate System
Image acquisition
UAV None
Image acquisition plan 2 walks in the church
Camera NCTech iSTAR
Images
Number of images 8
Image size 10000x5000
Image geolocation coordinate system Arbitrary Coordinate System
GCPs
Number of GCPs None
  • example_spherical.p4d: project file that can be opened in PIX4Dmapper.
Instructions
1. Open the project example_spherical.p4d by double clicking it.
Note: As the goal of this project is to generate only the 3D model (no DSM or Orthomosaic), the template selected for processing is 3D Models. This can be seen in Process > Processing Options... .
4. In Name: Type a name for the project. In this example, type example_spherical.
8Click Next.
10. Click Next.
The New Project wizard displays the Image Properties window. No image geolocation is detected.  The camera model is loaded from the camera model database (iSTAR_2.7_10000X5000(RGB)).
11.Click Next.
13. Click Next.
Note: As the goal of this project is to generate only a 3D model (no DSM or orthomosaic), the template selected for processing is 3D Models.
C) Improve the project:
To improve the results of the Densified Point Cloud and the 3D Textured mesh, the following Processing Options can be selected:
1. On the Menu bar click Process > Processing Options...
2. Select the processing step 1. Initial Processing.
3. Select the tab General.
4. In the section Keypoints Image Scale, select Custom and from the drop down list select 1 (Original Image size).
Note: This selection allows to extract the keypoints using the original image size.
5. In the Processing Options window click 2. Point Cloud and Mesh.
6. Select the tab Point Cloud.
7. In the Point Cloud Densification section click the drop-down list Image scale and select 1 (Original Image size, Slow) and from the drop-down list Point Density select High (Slow).
Note: The original image size is used to compute additional 3D points. More points are computed especially in areas where features can be easily matched. By selecting High Point Density, a 3D point will be computed for every Image Scale pixel. For more information about the Processing Options: Menu Process > Processing Options... > 2. Point Cloud and Mesh > Point Cloud.
8. Click OK.
9. On the Processing bar, click Start to start the processing.
Industrial building – Parrot Bebop 2
The goal of this project is to get a 3D model of industrial building. Images were acquired with Parrot Bebop 2 using PIX4Dcapture.
Project
Location Nantes, France
Average Ground Sampling Distance (GSD) 9.25 cm / 3.64 in
Area covered 0.0113 km2 / 1.13 ha / 0.0043 sq. mi. / 2.79 acres
Output coordinate system WGS84 / UTM zone 30N
Image acquisition
UAV Parrot Bebop 2
Image acquisition software PIX4Dcapture
Image acquisition plan Grid Mission and Circular Mission
Camera Bebop 2 camera
Images
Number of images 138
Image size 4096x3320
  • example_bebop2_industrial_building.p4d: project file that can be opened in PIX4D Desktop.
Instructions
This section describes how to process the dataset in order to generate a 3D textured mesh of the building using Parrot Bebop 2.
1. Open the project example_bebop2_industrial_building.p4d.
Note: As the goal of this project is to generate the 3D textured mesh (no DSM and orthomosaic),  the template used for the processing has been set to 3D Models. This can be seen in Process > Processing Options...
3. On the Processing bar, click Start to start processing.
This section describes how to create and process a project in order to generate a 3D mesh of a house.
1. Start PIX4D Desktop.
4. In Name: Type a name for the project. In this example type example_bebop2_industrial_building.
8. Click Next.
9. Click Add Directories... and select the images folder to add the images to the project. The folder contains the images of the grid mission and circular flight. Click Choose.
10. Click Next.
The New Project wizard displays the Image Properties window. The image geolocation is automatically loaded from the image EXIF data and is given in WGS84 (latitude, longitude, altitude) coordinates with vertical coordinate system given by MSL = egm96. The camera model is loaded from the camera model database (Bebop2_1.8_4096x3320 (RGB)).
11. Click Next.
12. Select Known Coordinate System and Advanced Coordinate Options. Click From List... button, select World Geodetic System 1984 datum and  WGS 84 / UTM zone 30N coordinate system, click OK.
13. Under Vertical Coordinate System select MSL. Set the value to egm96.
14. Click Next.
15. Click 3D Models to select the template. Click Finish to finish the wizard. The Processing bar opens at the bottom of the main window.
16. On the Processing bar select 1. Initial Processing and deselect 2. Point Cloud and Mesh.
17. On the Processing bar, click Start to start processing.
Note: PIX4Dmapper automatically detects the sky in the images of Bebop2 and improves the Densified Point Cloud.
For more information about the Processing Options: Menu Process > Processing Options... > 1. Initial Processing > Calibration.
18. Use the rayCloud to define a Processing Area to remove noisy points from the background and to keep only points of the building. For more information about how to draw a Processing Area with the rayCloud: How to use a processing area in PIX4Dmapper Desktop.
19. Edit the Processing Area to focus on the area of interest. For more information about how to edit a Processing Area with the rayCloud: How to edit a processing area in the rayCloud.
Note: In the above Processing Area, the Maximum and Minimum Altitude are set to 50.00 [m] and -10.00 [m] respectively.
20. On the Processing bar, deselect 1. Initial Processing, and select 2. Point Cloud and Mesh.
21. On the Processing bar, click Start to start processing.
Office building – DJI
The goal of this project is to get a 3D model of buildings using a DJI Phantom 4 and acquiring the images with PIX4Dcapture.
Project
Average Ground Sampling Distance (GSD) 1.67 cm / 0.65 in
Image acquisition
UAV DJI Phantom 4
Image acquisition plan Circular mission, 4° angle between images, 30m above ground.
Camera Phantom Vision FC330
Images
Number of images 85
  • images: RGB images in JPG format. The image's resolution is half the original image resolution.
  • dji_demo.p4d: project file that can be opened in PIX4Dmapper.
Instructions
This section describes how to process the dataset using the included .p4d project file in order to generate a 3D mesh of buildings.
1. Open the project dji_demo.p4d.
Note: As the goal of this project is to get a 3D Model, the template used for the processing has been set to 3D Model. This can be seen in Process > Processing Options.... .
Thermal
Download dataset
The goal of this project is to generate a thermal map using a FLIR Zenmuse XT thermal camera.
Project
Average Ground Sampling Distance (GSD) 9.24 cm / 3.64 in
Area covered 0.035 km2 / 3.4685 ha / 0.01 sq. mi. / 8.5753 acres
Image acquisition
UAV DJI Inspire 1
Image acquisition plan 2 flights, grid flight plan (90%-90% overlap)
Camera FLIR Zenmuse XT (Thermal)
Images
Number of images 152
Image size 640x512
GCPs
Number of GCPs No GCPs
  • images: Thermal images in RJPG format
  • thermal.p4d: project file that can be opened in PIX4Dmapper.
 Note: Information on how to process thermal images can be found: here
Instructions
This section describes how to process the dataset in order to generate the thermal map of the area.
1. Open the project thermal.p4d
Note: As the goal of this project is to generate the thermal map, the template used for the Processing has been set to Thermal Camera. This can be seen in Process > Processing Options....
Please make sure you also check the thermal_ir index:
This section describes how to create and process a project in order to generate the thermal map.
4. In Name: Type a name for the project. In this example type thermal.
8. Click Next.
10. Click Next.
As the images are RJPG, the software will automatically convert them to thermal TIFF images and they will be stored in a folder called Converted. Those are the images that the software will use for processing.
The New Project wizard displays the Image Properties window. The image geolocation is automatically loaded from the image EXIF data and is given in WGS84 (latitude, longitude, altitude) coordinates with vertical coordinate system given by a Geoid Height Above WGS 84 Ellipsoid of 0 meters. The camera model is loaded from the camera model database (FLIR Zenmuse XT (Thermal)).
11. Click Next.
12. Select Auto Detected.
13. Select Advanced Coordinate Options and under Vertical Coordinate System select Geoid Height Above WGS 84 Ellipsoid. Set the value to 0.
14. Click Next.
15. Click Thermal camera to select the template and check the thermal_ir index to be generated.
17. Run Step1, Step2 and Step3
18. Check/Visualize the thermal map. We recommend using Equal Spacing and 24 number of classes:
LOGO_KB_Demo_Projects_Matic.pngPIX4Dmatic example projects
Industrial zone and agriculture area
Download dataset
The goal of this project is to:
  • Import images into PIX4Dmatic.
  • Import and mark ground control points (GCPs).
  • Process the project and generate the dense point cloud, DSM, and orthomosaic.
This dataset with 1469 images (senseFly, AeriaX) and 8 GCPs contains an industrial zone, suburban houses, and the surrounding agriculture area. The dense point cloud, images, and GCPs are displayed in the 3D view.
Information: The example project of 1469 images is a subset of a larger dataset of 10615 images. The image acquisition of the whole dataset was done using 4 eBee X - senseFly drones flying simultaneously. The flight planning software eMotion was used.
To download the whole dataset contact the Pix4D Support team (a valid license of a Pix4D product is required, a trial license is considered valid).
Project
Average Ground Sampling Distance (GSD) 2.28 cm / 0.9 in
Area covered 1.154 km2 / 115.4 ha / 0.446 sq. mi. / 285.3 acres
Output coordinate system WGS 84 / UTM zone 32N - EPSG 32632, WGS 84 ellipsoid
Image acquisition
UAV eBee X (senseFly)
Image acquisition plan 4 flights, single grid flight plan
Camera senseFly AeriaX
Images
Number of images 1469
Image size 6000 x 4000 pixels
Image geolocation coordinate system WGS84 - EPSG 4326, WGS 840 ellipsoid
Ground control points (GCPs)
Number of GCPs 8
GCPs coordinate system WGS84 - EPSG 4326, WGS 84 ellipsoid
The dataset can be downloaded here (14.7 GB).
The downloaded compressed .zip file contains the following files and folders:
  • Images_subset_1469: RGB images in .JPG format.
  • root.p4m: PIX4Dmatic project file.
  • Pix4Dmatic_example_GCPs_EPSG_4326_ellipsoid.txt: GCP input geolocation file.
Instructions
Open the .p4m PIX4Dmatic project file
This section describes how to open the .p4m project.
Access: To download PIX4Dmatic click here.
  1. Open PIX4Dmatic.
  2. Click File on the menu bar.
  3. Click Open...
  4. On the pop-up Open Project, specify the location of the root.p4m file and click Open.
  5. (Optional) If images are not displayed in the Image panel:
    • Right-click on the image in the Image panel.
    • Click Find images...
    • In the Missing images dialog, click Find, specify the location of the image folder, and click Select folder.
Once the project is successfully imported, the images and GCPs appear in the 3D view.
Download processed results
A zipped folder containing the processed results can be downloaded here (16GB).
Trial licenses are prevented from exporting outputs.  Download the processed results to import into third-party software.
Urban area
Download dataset
The goal of this project is:
Pix4Dmatic demo dataset 100 images
The dataset with 100 images (senseFly, AeriaX) and 3 GCPs was flown over a town. The dense point cloud, images, and GCPs are displayed in the 3D view.
Information: The example project of 100 images is a subset of a larger dataset of 10615 images. The image acquisition of the whole dataset was done using 4 eBee X - senseFly drones flying simultaneously. The flight planning software eMotion was used.
Project
Average Ground Sampling Distance (GSD) 2.41 cm / 0.95 in
Area covered 0.0214 km2 / 2.14 ha / 0.008 sq. mi. / 5.3 acres
Image acquisition
Image acquisition plan 1 flight, single grid flight plan
Images
Number of images 100
Image geolocation coordinate system WGS84 - EPSG 4326, WGS 84 ellipsoid
Number of GCPs 3
Type of GCPs
  • cp12 - Tip of the arrow (parking lot)
  • cp19 - Checkered pattern GCP-1
  • cpe003 - Checkered pattern GCP-1
The dataset can be downloaded here (0.99 GB).
  • Images_subset_100: RGB images in .JPG format.
  • Pix4Dmatic_example_100_GCPs_EPSG_4326_ellipsoid.txt: GCP input geolocation file.
Instructions
  1. Open PIX4Dmatic.
  3. Click Open...
A zipped folder containing the processed results can be downloaded here (4.6GB).
PIX4Dcatch project
Download dataset
  • Import project into PIX4Dmatic.
  • Utilize available LiDAR depth data.
  • Process the project and generate a fused dense point cloud, DSM, and orthomosaic.
PIX4Dmatic processed PIX4Dcatch dataset results
The dataset contains 300 image files, plus LiDAR depth data (Confidence.tiff and DepthMap.tiff files) capturing a rainwater harvesting installation. The Dense/Depth/Depth & dense fusion point clouds and camera positions are displayed in the 3D view.
Project
Average Ground Sampling Distance (GSD) 0.3 cm / 0.13 in
Area covered 175 m2 / 0.0175 ha / 0.043 acres
Image acquisition
Device iPad Pro 11"
Image acquisition plan Terrestrial, circular
Camera iPad Pro w/LiDAR
Images
Number of images 300
Image size 1920 x 1440 pixels
The dataset can be downloaded here (367 MB).
  • PIX4Dmatic_example_300_images_LiDAR_inputs: RGB images in .jpg format. Confidence and DepthMap files in .tiff format.
Instructions
Open the .p4m Pix4Dmatic project file
  1. Open PIX4Dmatic.
  3. Click Open...
To process the project, it is necessary to Find images... first:
    • Click the Image viewer icon Image_viwer_icon_PIX4Dmatic_blueBG.jpg in the upper right.
    • Right-click on any blank image in the Image viewer.
    • In the Find images dialog, click the Find button find_button.jpg to specify the location of the PIX4Dmatic_example_300_images_LiDAR_inputs folder, and click Select folder.
    • Click OK.
For more information: How to process PIX4Dcatch datasets in PIX4Dmatic.
A zipped folder containing the processed results can be downloaded here (902MB).
LOGO_KB_Demo_Projects_Fields.pngPIX4Dfields example projects
Rostock Sequoia multispectral
Download dataset
The goal of this project is to get an NDVI index map of a field using the Sequoia camera that captures Green, Red, Red edge and NIR wavelengths.
Project
Location Germany
Average Ground Sampling Distance (GSD) 10.0 cm / 3.94 in
Area covered 0.449 km2 / 44.9 ha / 0.173 sq. mi. / 110.95 acres
Output coordinate system WGS84 / local Transverse Mercator
Image acquisition
UAV eBee (senseFly)
Image acquisition plan 1 flight, grid flight plan, 106 meters flight height
Camera Sequoia (Green, Red, Red edge, NIR)
Images
Number of images 1804
Image size 1280x960
  • Images: Red, Green, Red edge and NIR images in TIFF format.
  • Boundary: project file that can be opened in PIX4Dfields.
Start a new project in PIX4Dfields
To begin processing the dataset, follow the guide My first vegetation index map - PIX4Dfields
Rostock S.O.D.A. RGB camera
Download dataset
The goal of this project is to get an VARI index map of a field using the S.O.D.A camera that captures Red, Green, Blue wavelengths.
Project
Location Germany
Average Ground Sampling Distance (GSD) 2.80 cm / 1.10 in
Area covered 0.483 km2 / 48.3 ha / 0.186 sq. mi. / 119.35 acres
Image acquisition
UAV eBee (senseFly)
Image acquisition plan 1 flight, grid flight plan, 119 meters flight height
Camera S.O.D.A. (Red, Green, Blue)
Images
Number of images 374
  • Images: Red, Green, Blue images in JPG format.
To begin processing the dataset, follow the guide My first vegetation index map - PIX4Dfields.
LOGO_KB_Demo_Projects_Survey.pngPIX4Dsurvey example projects
PIX4Dmapper project with terrestrial laser scans
Download dataset
  • Use the project processed in PIX4Dmapper and vectorize it in PIX4Dsurvey.
  • Use a combination of photogrammetry and a terrestrial laser scanner.
  • Organize the vectorized objects in layers.
Project
Average Ground Sampling Distance (GSD) 2.39 cm / 0.94 in
Area covered 0.0441 km2 / 4.41 ha / 0.017 sq. mi. / 10.90 acres
Output coordinate system CH1903+ / LV95
Vertical Coordinate System: Geoid Height Above Bessel 1841 Ellipsoid = 0 meters
Image acquisition
Image acquisition plan 2 flight, single grid flight plan
Images
Number of images 101
Terrestrial laser scans
Laser scanner Leica RTC360 3D Laser Scanner
Number of scans¹ 2
Number of points² 3,549,517 - Bridge
5,327,201 - Village
Laser point cloud coordinate system CH1903+ / LV95, Bessel 1841 Ellipsoid
¹ In total 12 laser scan stations were used to fully capture 2 scenes and to generate 2 final point clouds.
² The number of points after cleaning the point cloud and reducing the resolution of the point cloud.
The dataset can be downloaded here (1.6 GB).
  • pointclouds: point clouds in a PIX4Dsurvey point cloud format (.bpc).
  • Pix4Dsurvey_Demo_Rivaz.p4s: PIX4Dsurvey project file.
Instructions
Open the .p4s Pix4Dsurvey project file
This section describes how to open the .p4s project to set it up for vectorization.
Access: To download PIX4Dsurvey click here.
  1. Open PIX4Dsurvey.
  2. Drag and drop Pix4Dsurvey_Demo_Rivaz.p4s on the screen. More options in the Project management article.
Once the import is completed both the point clouds and calibrated images will be displayed. You are ready to start vectorizing the project.
Suburban area
Download dataset
  • Vectorize buildings, roofs, roads, curbs, green areas, and parking lots.
Project
Location Denver, Colorado, US
Average Ground Sampling Distance (GSD) 1.13 cm / 0.44 in
Area covered 0.041 km2 / 4.1 ha / 0.02 sq. mi. / 10.17 acres
Output coordinate system NAD 1983 StatePlane Colorado Central FIPS 0502 Feet
Vertical Coordinate System: EGM 96
Image acquisition
UAV DJI Phantom 4 Pro
Camera DJI Phantom 4 Pro
Images
Number of images 188
  • Pix4Dsurvey_Suburban_Area: PIX4Dsurvey project file.
Instructions
  2. Drag and drop PIX4Dsurvey_Suburban_Area on the screen. More options in the Project management article.
LOGO_KB_Demo_Projects_React.pngPIX4Dreact example projects
Bahamas hurricane damage
Download images
This project aims to generate a fast mapping after a disaster using PIX4Dreact
Project
Location Bahamas
Average Ground Sampling Distance (GSD) 2 cm
Area covered 20 ha
Image acquisition
Image acquisition plan Grid flight plan
Camera Zenmuse X5S
Images
Dataset size 1.62 GB
Number of images 181
Download the example project
The example project can be downloaded here.
After downloading the zip archive, this needs to be unzipped. The folder contains images in JPG format
Belleview Avenue
Download dataset
The goal of this project is to generate a map of a residential area using the Parrot Anafi drone.
Project
Location Colorado (USA)
Average Ground Sampling Distance (GSD) 2.64 cm / 1.04 in
Area covered 0.12 km2 / 11.86 ha / 0.05 sq mi
Output coordinate system WGS84 / Universal Transverse Mercator zone 13N
Image acquisition
UAV Parrot Anafi
Camera Anafi 4K 1.5.6
Images
Dataset size 208 MB
Number of images 38
Image width 5344 pixels
Image height 4016 pixels
After downloading the zip archive, this needs to be unzipped. The folder contains images in JPG format.
Dominica hurricane damage
Download dataset
This project aims to generate a fast -mapping after a disaster using Pix4Dreact
Project
Location Loubiere (Dominica)
Average Ground Sampling Distance (GSD) 13,23 cm / 5,21 in
Area covered 45,22 ha
Output coordinate system WGS84 / Universal Transverse Mercator zone 20N
Image acquisition
Image acquisition plan grid flight plan
Camera Zenmuse X4S
Images
Dataset size 1.2 GB
Number of images 155
Image width 9234 pixels
Image height 5414 pixels
Open Photogrammetry Format (OPF) example projects
Nadir drone project
Download dataset
Project
Image acquisition
Images
The dataset can be downloaded here (1.74 GB).
  • images:RGB images in JPG format
  • dense_pcl: point cloud in gltf format.
  • project.opf + other files: OPF files.
Instructions
Import the OPF project into PIX4Dmatic
This section describes how to import the OPF project.
Access: To download PXI4Dmatic click here.
  1. Open PIX4Dmatic.
  2. Create a new empty project File > New (Ctrl +N), give it a name and set the path then click Start.
  3. Import OPF project by File > Import OPF project... and point it to the project.opf file
Tip: You can work with OPF files also in Python, for more details check pyopf package https://github.com/Pix4D/pyopf.
Terrestrial scan with lidar data - PIX4Dcatch
Download dataset
Project
Image acquisition
Device iPad Pro 11"
Images
The dataset can be downloaded here (689 MB).
  • Images:RGB images in JPG format.
  • dense, depth, fused, sparse: various point clouds in gltf format.
  • project.opf + other json files: OPF files.
Instructions
  1. Open PIX4Dmatic.
Terrestrial scan - PIX4Dcatch
Download dataset
Project
Average Ground Sampling Distance (GSD) 0.2 cm / 0.08 in
Area covered 82 m2 / 0.0082 ha / 0.020 acres
Output coordinate system ETRS89 / UTM zone 32N - EPSG:25832, Ellipsoidal height over the GRS 1980 ellipsoid
Image acquisition
Device iPhone 13
Camera iPhone 13
Images
Number of images 117
Image size 1440 x 1920 pixels
Image geolocation coordinate system ETRS89 - EPSG:4258, Ellipsoidal height over the GRS 1980 ellipsoid
The dataset can be downloaded here (208 MB)
  • dense, sparse: various point clouds in gltf format.
Instructions
  1. Open PIX4Dmatic.
Industrial zone and agriculture area - OPF
Download dataset
  • Demonstrate the capabilities of the OPF format.
Information: The example project of 135 images is a subset of a larger dataset of 10615 images. The image acquisition of the whole dataset was done using 4 eBee X - senseFly drones flying simultaneously. The flight planning software eMotion was used.
Project
Area covered 0.131 km2 / 13.1 ha / 0.05 sq. mi. / 32.37 acres
Image acquisition
Device eBee X (senseFly)
Images
Number of images 135
Number of GCPs 3
The dataset can be downloaded here (2.41 GB).
  • OPF file format and associated files.
Instructions
Open the OPF project file
  1. Open PIX4Dmatic.
  3. Click Open...
  4. On the pop-up Open Project, specify the location of the project.opf file and click Open.
