Get started with real photogrammetry sample data acquired with drones or UAV and create 2D and 3D outputs.
Download any of these projects for free* and explore Pix4D’s desktop functionalities with a real dataset.
Using real data demonstrates what Pix4D software can do and will help you understand what’s needed when collecting your own data.
Not sure where to begin? Follow the instructions below each data set to create your first project.
PIX4Dmapper example projects
PIX4Dmatic example projects
PIX4Dfields example projects
PIX4Dsurvey example projects
PIX4Dreact example projects
For more inspiration, check out our Community Hall of Fame.
Quarry download dataset or view in PIX4Dcloud
The goal of this project is to generate a DSM and an Orthomosaic of a quarry using an eBee drone with a SenseFly S.O.D.A. |
General project information | |
Project | |
Location | Switzerland |
Average Ground Sampling Distance (GSD) | 5.40 cm / 2.13 in |
Area covered | 0.5776 km2 / 57.7565 ha / 0.223 sq. mi. / 142.79 acres |
Output coordinate system | CH1903 / LV03 Geoid Height Above Bessel 1841. Ellipsoid = 0 meters |
Image acquisition | |
UAV | eBee Classic (senseFly) |
Image acquisition plan | 1 flight, double grid flight plan |
Camera | senseFly S.O.D.A. |
Images | |
Number of images | 347 |
Image size | 5472x3648 |
Image geolocation coordinate system | WGS84 |
GCPs | |
Number of GCPs | 9 3D GCPs |
GCPs coordinate system | CH1903 / LV03 |
Download project files |
The dataset can be downloaded here and can be found processed on PIX4Dcloud here. The downloaded folder contains the following files and folders:
Instructions |
Process the dataset using the included .p4d project file |
This section describes how to process the dataset in order to generate the DSM and the Orthomosaic of a quarry. 1. Open the project example_quarry_2.p4d. 3. On the Processing bar, click Start to start the processing. |
Process the dataset creating a new project |
This section describes how to create and process a project in order to generate the DSM and the Orthomosaic of a quarry. A) Create a new project: 1. Start PIX4Dmapper. 6. (optional) Select the check box Use As Default Project Location to save all new projects in the selected folder. The New Project wizard displays the Select Images window. 9. Click Add Directories... and select the images folder to add the images to the project. The New Project wizard displays the Image Properties window. The image geolocation is automatically loaded from the image EXIF data and is given in WGS84 (latitude, longitude, altitude) coordinates with vertical coordinate system given by a Geoid Height Above WGS 84 Ellipsoid of 0 meters. The camera model is loaded from the camera model database (S.O.D.A._10.6_5472x3648 (SI002001AA7C00213) (RGB).). 11. Click Next. The New Project wizard displays the Select Output Coordinate System window. By default the last output coordinate system selected in the software is selected. 12. Select Known Coordinate System CH1903 / LV03. The New Project wizard displays the Processing Options Template window. 15. Click 3D Maps to select the template. 16. Click Finish to finish the wizard and create the project. The Processing bar opens at the bottom of the main window.
B) Introduce and mark the GCPs: 1. On the Menu bar, click Project > GCP/MTP Manager.... The GCPs and their coordinates are imported and can be visualized in the GCP/MTP Manager window. 11. On the GCP/MTP Manager window click OK. When step 1. Initial Processing is finished the rayCloud opens. 14. Mark the GCPs using the rayCloud following instructions 2. to 11. as described here How to import and mark ground control points (GCPs). The images in the folder inputs/gcp_overview help to identify the GCPs should be marked.
C) Generate the DSM and Orthomosaic When the GCPs are marked and the project is re-optimized. 1. On the Processing bar, deactivate 1. Initial Processing and activate 2. Point Cloud and Mesh and 3. DSM, Orthomosaic and Index. |
Building download dataset or view in PIX4Dcloud
The goal of this project is to generate the 3D model of a building taken by an AscTec Falcon 8 UAV. |
Project | |
Location | Germany |
Average Ground Sampling Distance (GSD) | 1.89 cm / 0.7 in |
Area covered | Undefined |
Output coordinate system | WGS84 / UTM zone 32N Vertical Coordinate System: MSL egm96 |
UAV | AscTec Falcon 8 UAV (Ascending Technologies) |
Image acquisition plan | 1 flight, circular flight around the building |
Camera | Sony NEX-5 (RGB) |
Images | |
Number of images | 36 |
Image size | 4592x3056 |
GCPs | |
Number of GCPs | None |
GCPs coordinate system | None |
Instructions |
To process the dataset in order to generate the 3D model of a building: 1. Open the project example_building.p4d by double clicking it. 3. On the Processing bar, click Start to start the processing. |
This section describes how to create and process a project in order to generate a 3D model of a building. A) Create a new project: 1. Start PIX4Dmapper. 6. (optional) Select the check box Use As Default Project Location to save all new projects in the selected folder. The New Project wizard displays the Select Images window. 9. Click Add Directories... and select the images folder to add the images to the project. The New Project wizard displays the Image Properties window. The image geolocation is automatically loaded from the image EXIF data and is given in WGS84 (latitude, longitude, altitude) coordinates with vertical coordinate system given by MSL egm96. The camera model is loaded from the camera model database (NEX-5_E16mmF2.8_16.0_4592x3056 (RGB)). 11.Click Next. The New Project wizard displays the Select Output Coordinate System window. By default the last output coordinate system selected in the software is selected. 12. Under Unit, select m. The New Project wizard displays the Processing Options Template window. 15. Select the 3D Models template. B) Process the project: 1. On the Processing bar, click Start to start the processing. |
Cadastre download dataset or view in PIX4Dcloud
The goal of this project is to generate the DSM and the Orthomosaic of a village using a Canon IXUS 120IS. |
Project | |
Average Ground Sampling Distance (GSD) | 5.1 cm / 2 in |
Area covered | 0.2128 km2 / 21.2822 ha / 0.0822 sq. mi. / 52.6167 acres |
Output coordinate system | WGS84 / UTM zone 32N Vertical Coordinate System: Geoid Height Above WGS 84 Ellipsoid = 0 meters |
UAV | swinglet CAM (senseFly) |
Image acquisition plan | 1 flight, grid flight plan |
Camera | Canon IXUS 120IS (RGB) |
Images | |
Number of images | 68 |
Image size | 4000x3000 |
GCPs | |
Instructions |
This section describes how to process the dataset in order to generate the DSM and the Orthomosaic of a village. 1. Open the project example_cadastre.p4d. 3. On the Processing bar, click Start to start the processing. |
This section describes how to create and process a project in order to generate the DSM and the Orthomosaic of a village. A) Create a new project: 1. Start PIX4Dmapper. 6. (optional) Select the check box Use As Default Project Location to save all new projects in the selected folder. The New Project wizard displays the Select Images window. 9. Click Add Directories... and select the images folder to add the images to the project. The New Project wizard displays the Image Properties window. The image geolocation is automatically loaded from the image EXIF data. The coordinate system is automatically set to WGS84 with vertical coordinate system given in MSL egm96. As the image geolocation is given in WGS 84 with vertical coordinates system in Geoid Height Above WGS 84 Ellipsoid = 0, the coordinate system has to be changed. 11. On the Image Geolocation > Coodinate System clickEdit.... In the Image Properties window, the camera model is loaded from the camera model database (CanonDIGITALIXUS120IS_5.0_4000x3000 (RGB)). 15. Click Next. The New Project wizard displays the Select Output Coordinate System window. By default the last output coordinate system selected in the software is selected. 16. Select Auto Detected. The New Project wizard displays the Processing Options Template window. 19. Click 3D Maps to select the template. 20. Click Finish to finish the wizard and create the project. The Processing window opens at the bottom of the main window. B) Process the project: 1. On the Processing bar, click Start to start the processing. |
Construction dataset download dataset
The goal of this project is to get an orthomosaic and a 3D point cloud of construction site. |
Project | |
Average Ground Sampling Distance (GSD) | 1.83 cm / 1.04 in |
Area covered | 0.1326 km2 / 13.2612 ha / 0.0512 sq. mi. / 32.786 acres |
UAV | eBee Classic |
Camera | S.O.D.A 10.2 (RGB) |
Images | |
Number of images | 197 |
GCPs | |
The dataset can be downloaded here. The downloaded folder contains the following files and folders:
Instructions |
This section describes how to process the dataset in order to generate an orthomosaic. A) Process the project: 1. Open the project bim_dataset.p4d by double clicking on the file. 3. On the Processing window, click Start to start the processing. |
This section describes how to create and process a project in order to generate an orthomosaic for the whole project. A) Create a new project: 1. Start PIX4Dmapper. 6. (Optional) Activate the check box Use As Default Project Location to save all new projects in the selected folder. The New Project wizard displays the Select Images window. 9. Click Add Directories... and select the images folder to add the images to the project. 10. Click Next. The New Project wizard displays the Image Properties window. The image geolocation it is already set in the Image Properties window under section Image Coordinate System and does not need to be changed. The image geolocation is loaded. The camera model is loaded from the camera model database (S.O.D.A_10.2_5472x3648 (RGB)). 11. Click Next. The New Project wizard displays the Processing Options Template window. 12. On the left of the window, select the 3D Maps template. The New Project wizard displays the Select Output Coordinate System window. By default the last output coordinate system selected in the software is selected. 14. Under Unit, select m. B) Process the project: 1. On the menu bar, click Process > Processing Options... to open the Processing Options window. Once processing is finished, the Orthomosaic can be visualized and modified in the Mosaic Editor. |
Eagle statue – Handheld camera download dataset
The goal of this project is to generate the 3D model of the statue of an eagle by taking images from the ground using a Canon EOS 7D with perspective lens. |
Project | |
Average Ground Sampling Distance (GSD) | Undefined |
Output coordinate system | Arbitrary |
UAV | None |
Image acquisition plan | 2 walks around the statue, each at a different altitude |
Camera | Canon EOS 7D (RGB) |
Images | |
Number of images | 44 |
Image size | 5184x3456 |
Image geolocation coordinate system | None |
GCPs | |
Instructions |
This section describes how to process the dataset in order to generate the 3D model of the statue of an eagle. 1. Open the project example_eagle.p4d by double clicking it. 3. On the Processing bar, click Start to start the processing. |
This section describes how to create and process a project in order to generate the 3D model of the statue of an eagle. A) Create a new project: 1. Start PIX4Dmapper. 6. (optional) Select the check box Use As Default Project Location to save all new projects in the selected folder. The New Project wizard displays the Select Images window. 9. Click Add Directories... and select the images folder to add the images to the project. The New Project wizard displays the Image Properties window. No image geolocation is detected. The camera model is loaded from the camera model database (CanonEOS7D_EF-S15-85mmf/3.5-5.6ISUSM_15.0_5184x3456 (RGB)). 11. Click Next. The New Project wizard displays the Select Output Coordinate System window. By default the last output coordinate system selected in the software is selected. 12. Select Arbitrary Coordinate System with Unit meters. The New Project wizard displays the Processing Options Template window. 14. Select the 3D Models template. B) Process the project: 1. On the Processing bar, select 1. Initial Processing, and deselect 2. Point Cloud and Mesh. 4. Edit the Processing Area such that the height adjusts to the height of the statue. For more information about how to edit a Processing Area with the rayCloud: How to edit a processing area in the rayCloud. 5. On the Processing bar, deselect 1. Initial Processing, and select 2. Point Cloud and Mesh. |
Forensic download dataset
The goal of this project is to generate the Point Cloud and the 3D Textured Mesh of a forensic scene. |
Project | |
Location | USA |
Average Ground Sampling Distance (GSD) | 0.24 cm / 0.09 in |
Output coordinate system | WGS84 / UTM zone 17N |
UAV | DJI Phantom 3 Advanced |
Image acquisition plan | 1 flight, circular flight around the scene |
Camera | FC300 X (RGB) |
Images | |
Number of images | 69 |
GCPs | |
Instructions |
This section describes how to process the dataset in order to generate the 3D model of a building. 1. Open the project example_forensic.p4d by double clicking it. 3. On the Processing bar, click Start to start the processing. |
This section describes how to create and process a project in order to generate a 3D model of a building. A) Create a new project: 1. Start PIX4Dmapper. 6. (optional) Select the check box Use As Default Project Location to save all new projects in the selected folder. The New Project wizard displays the Select Images window. 9. Click Add Directories... and select the images folder to add the images to the project. The New Project wizard displays the Image Properties window. The image geolocation is automatically loaded from the image EXIF data and is given in WGS84 (latitude, longitude, altitude) coordinates with vertical coordinate system given at Geoid Above Ellipsoid=0 m. The camera model is loaded from the camera model database (FC300X_3.6_4000x3000 (RGB)). 11.Click Next. The New Project wizard displays the Select Output Coordinate System window. By default the last output coordinate system selected in the software is selected. 12. Under Unit, select m. The New Project wizard displays the Processing Options Template window. 15. Select the 3D Models template. B) Process the project: 1. On the Processing bar, click Start to start the processing. |
Indoor mapping – Spherical camera download dataset
The goal of this project is to generate the 3D model of a church taken by an NCTech iSTAR spherical camera. |
Project | |
Location | "The Church of Santiago", located in Betanzos (A Coruña, Spain) |
Output coordinate system | Arbitrary Coordinate System |
UAV | None |
Image acquisition plan | 2 walks in the church |
Camera | NCTech iSTAR |
Images | |
Number of images | 8 |
Image size | 10000x5000 |
Image geolocation coordinate system | Arbitrary Coordinate System |
GCPs | |
Instructions |
This section describes how to process the dataset in order to generate the 3D model of a building. 1. Open the project example_spherical.p4d by double clicking it. 3. On the Processing bar, click Start to start the processing. |
This section describes how to create and process a project in order to generate a 3D model of a building. A) Create a new project: 1. Start PIX4Dmapper. 6. (optional) Select the check box Use As Default Project Location to save all new projects in the selected folder. The New Project wizard displays the Select Images window. 9. Click Add Directories... and select the images folder to add the images to the project. The New Project wizard displays the Image Properties window. No image geolocation is detected. The camera model is loaded from the camera model database (iSTAR_2.7_10000X5000(RGB)). 11.Click Next. The New Project wizard displays the Select Output Coordinate System window. By default the last output coordinate system selected in the software is selected. 12. Select Arbitrary Coordinate System with Unit meters. The New Project wizard displays the Processing Options Template window. 14. Select the 3D Models template. B) Process the project: 1. On the Processing bar, click Start to start the processing. C) Improve the project: To improve the results of the Densified Point Cloud and the 3D Textured mesh, the following Processing Options can be selected:
1. On the Menu bar click Process > Processing Options... 5. In the Processing Options window click 2. Point Cloud and Mesh. 8. Click OK. |
Industrial building – Parrot Bebop 2 download dataset or view in PIX4Dcloud
The goal of this project is to get a 3D model of industrial building. Images were acquired with Parrot Bebop 2 using PIX4Dcapture. |
Project | |
Location | Nantes, France |
Average Ground Sampling Distance (GSD) | 9.25 cm / 3.64 in |
Area covered | 0.0113 km2 / 1.13 ha / 0.0043 sq. mi. / 2.79 acres |
Output coordinate system | WGS84 / UTM zone 30N Vertical Coordinate System: MSL egm96 |
UAV | Parrot Bebop 2 |
Image acquisition software | PIX4Dcapture |
Image acquisition plan | Grid Mission and Circular Mission |
Camera | Bebop 2 camera |
Images | |
Number of images | 138 |
Image size | 4096x3320 |
Instructions |
This section describes how to process the dataset in order to generate a 3D textured mesh of the building using Parrot Bebop 2. 1. Open the project example_bebop2_industrial_building.p4d. 3. On the Processing bar, click Start to start processing. |
This section describes how to create and process a project in order to generate a 3D mesh of a house. A) Create a new project: 1. Start PIX4D Desktop. 6. (optional) Select the check box Use As Default Project Location to save all new projects in the selected folder. The New Project wizard displays the Select Images window. 9. Click Add Directories... and select the images folder to add the images to the project. The folder contains the images of the grid mission and circular flight. Click Choose. The New Project wizard displays the Image Properties window. The image geolocation is automatically loaded from the image EXIF data and is given in WGS84 (latitude, longitude, altitude) coordinates with vertical coordinate system given by MSL = egm96. The camera model is loaded from the camera model database (Bebop2_1.8_4096x3320 (RGB)). 11. Click Next. The New Project wizard displays the Select Output Coordinate System window. By default the last output coordinate system selected in the software is selected. 12. Select Known Coordinate System and Advanced Coordinate Options. Click From List... button, select World Geodetic System 1984 datum and WGS 84 / UTM zone 30N coordinate system, click OK. The New Project wizard displays the Processing Options Template window. 15. Click 3D Models to select the template. Click Finish to finish the wizard. The Processing bar opens at the bottom of the main window. B) Process the project: 16. On the Processing bar select 1. Initial Processing and deselect 2. Point Cloud and Mesh. When Initial Processing finishes, the rayCloud opens. 18. Use the rayCloud to define a Processing Area to remove noisy points from the background and to keep only points of the building. For more information about how to draw a Processing Area with the rayCloud: How to use a processing area in PIX4Dmapper Desktop. 19. Edit the Processing Area to focus on the area of interest. For more information about how to edit a Processing Area with the rayCloud: How to edit a processing area in the rayCloud. 20. On the Processing bar, deselect 1. Initial Processing, and select 2. Point Cloud and Mesh. |
Office building – DJI download dataset or view in PIX4Dcloud
The goal of this project is to get a 3D model of buildings using a DJI Phantom 4 and acquiring the images with PIX4Dcapture. |
Project | |
Average Ground Sampling Distance (GSD) | 1.67 cm / 0.65 in |
UAV | DJI Phantom 4 |
Image acquisition plan | Circular mission, 4° angle between images, 30m above ground. |
Camera | Phantom Vision FC330 |
Images | |
Number of images | 85 |
Instructions |
This section describes how to process the dataset using the included .p4d project file in order to generate a 3D mesh of buildings. 1. Open the project dji_demo.p4d. |
Thermal download dataset
The goal of this project is to generate a thermal map using a FLIR Zenmuse XT thermal camera. |
Project | |
Average Ground Sampling Distance (GSD) | 9.24 cm / 3.64 in |
Area covered | 0.035 km2 / 3.4685 ha / 0.01 sq. mi. / 8.5753 acres |
UAV | DJI Inspire 1 |
Image acquisition plan | 2 flights, grid flight plan (90%-90% overlap) |
Camera | FLIR Zenmuse XT (Thermal) |
Images | |
Number of images | 152 |
Image size | 640x512 |
GCPs | |
Number of GCPs | No GCPs |
Instructions |
This section describes how to process the dataset in order to generate the thermal map of the area. 1. Open the project thermal.p4d 3. On the Processing bar, click Start to start the processing.
This section describes how to create and process a project in order to generate the thermal map. A) Create a new project: 1. Start PIX4Dmapper. 6. (optional) Select the check box Use As Default Project Location to save all new projects in the selected folder. The New Project wizard displays the Select Images window. 9. Click Add Directories... and select the images folder to add the images to the project. As the images are RJPG, the software will automatically convert them to thermal TIFF images and they will be stored in a folder called Converted. Those are the images that the software will use for processing. The New Project wizard displays the Image Properties window. The image geolocation is automatically loaded from the image EXIF data and is given in WGS84 (latitude, longitude, altitude) coordinates with vertical coordinate system given by a Geoid Height Above WGS 84 Ellipsoid of 0 meters. The camera model is loaded from the camera model database (FLIR Zenmuse XT (Thermal)). 11. Click Next. The New Project wizard displays the Select Output Coordinate System window. By default the last output coordinate system selected in the software is selected. 12. Select Auto Detected. The New Project wizard displays the Processing Options Template window. 15. Click Thermal camera to select the template and check the thermal_ir index to be generated. 16. Click Finish to finish the wizard and create the project. The Processing bar opens at the bottom of the main window. 17. Run Step1, Step2 and Step3 18. Check/Visualize the thermal map. We recommend using Equal Spacing and 24 number of classes: |
Industrial zone and agriculture area download dataset
The goal of this project is:
The dataset with 1469 images (senseFly, AeriaX) and 8 GCPs contains an industrial zone, suburban houses, and the surrounding agriculture area. The dense point cloud, images, and markers are displayed in the 3D view. |
Project | |
Average Ground Sampling Distance (GSD) | 2.28 cm / 0.9 in |
Area covered | 1.154 km2 / 115.4 ha / 0.446 sq. mi. / 285.3 acres |
Output coordinate system | WGS 84 / UTM zone 32N - EPSG 32632, WGS 84 ellipsoid |
UAV | eBee X (senseFly) |
Image acquisition plan | 4 flights, single grid flight plan |
Camera | senseFly AeriaX |
Images | |
Number of images | 1469 |
Image size | 6000 x 4000 pixels |
Image geolocation coordinate system | WGS84 - EPSG 4326, WGS 84 ellipsoid |
Ground control points (GCPs) | |
Number of GCPs | 8 |
GCPs coordinate system | WGS84 - EPSG 4326, WGS 84 ellipsoid |
The dataset can be downloaded here (14.7 GB). The downloaded compressed .zip file contains the following files and folders:
Instructions |
Open the .p4m Pix4Dmatic project file |
This section describes how to open the .p4m project.
Once the project is successfully imported, the images and GCPs appear in the 3D view. |
Urban area download dataset
The dataset with 100 images (senseFly, AeriaX) and 3 GCPs was flown over a town. The dense point cloud, images, and markers are displayed in the 3D view. |
Project | |
Average Ground Sampling Distance (GSD) | 2.41 cm / 0.95 in |
Area covered | 0.0214 km2 / 2.14 ha / 0.008 sq. mi. / 5.3 acres |
Image acquisition plan | 1 flight, single grid flight plan |
Images | |
Number of images | 100 |
Number of GCPs | 3 |
The dataset can be downloaded here (0.99 GB). The downloaded compressed .zip file contains the following files and folders:
Instructions |
PIX4Dcatch project download dataset
The dataset contains 300 image files, plus LiDAR depth data (Confidence.tiff and DepthMap.tiff files) capturing a rainwater harvesting installation. The Dense/Depth/Depth & dense fusion point clouds and camera positions are displayed in the 3D view. |
Project | |
Average Ground Sampling Distance (GSD) | 0.3 cm / 0.13 in |
Area covered | 175 m2 / 0.0175 ha / 0.043 acres |
Device | iPad Pro 11" |
Image acquisition plan | Terrestrial, circular |
Camera | iPad Pro w/LiDAR |
Images | |
Number of images | 300 |
Image size | 1920 x 1440 pixels |
The dataset can be downloaded here (1.1 GB). The downloaded compressed .zip file contains the following files and folders:
Instructions |
Once the project is successfully imported, the point clouds appear in the 3D view, with the DSM and Orthomosaic in the 2D view. (Optional) To process the project it is necessary to Find images... first:
For more information: How to process PIX4Dcatch datasets in PIX4Dmatic. |
Rostock Sequoia multispectral download dataset
The goal of this project is to get an NDVI index map of a field using the Sequoia camera that captures Green, Red, Red edge and NIR wavelengths. |
Project | |
Average Ground Sampling Distance (GSD) | 10.0 cm / 3.94 in |
Area covered | 0.449 km2 / 44.9 ha / 0.173 sq. mi. / 110.95 acres |
Output coordinate system | WGS84 / local Transverse Mercator |
UAV | eBee (senseFly) |
Image acquisition plan | 1 flight, grid flight plan, 106 meters flight height |
Camera | Sequoia (Green, Red, Red edge, NIR) |
Images | |
Number of images | 1804 |
Image size | 1280x960 |
Start a new project in PIX4Dfields |
To begin processing the dataset, follow the guide A project step-by-step. |
Rostock S.O.D.A. RGB camera download dataset
The goal of this project is to get an VARI index map of a field using the S.O.D.A camera that captures Red, Green, Blue wavelengths. |
Project | |
Average Ground Sampling Distance (GSD) | 2.80 cm / 1.10 in |
Area covered | 0.483 km2 / 48.3 ha / 0.186 sq. mi. / 119.35 acres |
Image acquisition plan | 1 flight, grid flight plan, 119 meters flight height |
Camera | S.O.D.A. (Red, Green, Blue) |
Images | |
Number of images | 374 |
PIX4Dmapper project with terrestrial laser scans download dataset
Project | |
Average Ground Sampling Distance (GSD) | 2.39 cm / 0.94 in |
Area covered | 0.0441 km2 / 4.41 ha / 0.017 sq. mi. / 10.90 acres |
Output coordinate system | CH1903+ / LV95 Vertical Coordinate System: Geoid Height Above Bessel 1841 Ellipsoid = 0 meters |
Image acquisition plan | 2 flight, single grid flight plan |
Images | |
Number of images | 101 |
Terrestrial laser scans | |
Laser scanner | Leica RTC360 3D Laser Scanner |
Number of scans¹ | 2 |
Number of points² | 3,549,517 - Bridge 5,327,201 - Village |
Laser point cloud coordinate system | CH1903+ / LV95, Bessel 1841 Ellipsoid |
² The number of points after cleaning the point cloud and reducing the resolution of the point cloud.
The dataset can be downloaded here (1.6 GB). The downloaded compressed .zip file contains the following files and folders:
Instructions |
Open the .p4s Pix4Dsurvey project file |
This section describes how to open the .p4s project to set it up for vectorization.
Once the import is completed both the point clouds and calibrated images will be displayed. You are ready to start vectorizing the project. |
Suburban area download dataset
Project | |
Location | Denver, Colorado, US |
Average Ground Sampling Distance (GSD) | 1.13 cm / 0.44 in |
Area covered | 0.041 km2 / 4.1 ha / 0.02 sq. mi. / 10.17 acres |
Output coordinate system | NAD 1983 StatePlane Colorado Central FIPS 0502 Feet Vertical Coordinate System: EGM 96 |
UAV | DJI Phantom 4 Pro |
Camera | DJI Phantom 4 Pro |
Images | |
Number of images | 188 |
The dataset can be downloaded here (1.6 GB) The downloaded compressed .zip file contains the following files and folders:
Instructions |
Belleview Avenue download dataset
The goal of this project is to generate a map of a residential area using the Parrot Anafi drone. |
Project | |
Location | Colorado (USA) |
Average Ground Sampling Distance (GSD) | 2.64 cm / 1.04 in |
Area covered | 0.12 km2 / 11.86 ha / 0.05 sq mi |
Output coordinate system | WGS84 / Universal Transverse Mercator zone 13N |
UAV | Parrot Anafi |
Camera | Anafi 4K 1.5.6 |
Images | |
Dataset size | 208 MB |
Number of images | 38 |
Image width | 5344 pixels |
Image height | 4016 pixels |
Download the example project |
The example project can be downloaded here. After downloading the zip archive, this needs to be unzipped. The folder contains images in JPG format. |
Dominica hurricane damage download dataset
This project aims to generate a fast -mapping after a disaster using Pix4Dreact |
Project | |
Location | Loubiere (Dominica) |
Average Ground Sampling Distance (GSD) | 13,23 cm / 5,21 in |
Area covered | 45,22 ha |
Output coordinate system | WGS84 / Universal Transverse Mercator zone 20N |
Image acquisition plan | grid flight plan |
Camera | Zenmuse X4S |
Images | |
Dataset size | 1.2 GB |
Number of images | 155 |
Image width | 9234 pixels |
Image height | 5414 pixels |
Hi, there is no GCP files in the Quarry sample dataset. Does anyone know where to download? Thank you!!
I too am having the same issue. Does anyone have a resolution to this problem?
Hi There,
I'd love to see a sample that has multiple flights using different methods, is this acceptable practice?
E.g. Grid flight, circular flight and GCP's.
Thanks
Allan
Under Quarry B) 4) had to choose coordinate system "From EPSG" 21781, as this is what the GCP coordinates are given in in the provided GCP file. They are not in WGS 84 Latitude, Longitude, Altitude (EPSG:4326).
I understand that GCP's will help with the accuracy. However, if you are providing a demo, do you need the GCP's? Can you fly using Pix4D without the GCP's. Will this app allow you to provide a fairly decent looking model without using GCP's. The reason I ask is because I have used Drone Deploy and it does a great job allowing you to deliver or showcase whats possible without using GCP's.
Ref. Construction Dataset, I need to know the calculation for number of Images. I can see the Image Size as 54x36 ( pix meters ) means per image area 1944m2. Now when I divide the same with 33 Acres or 133546m2 Area of the Construction Site the images will be 133546/1944 = 68 Images add 80% Front Overlap = 58 Images add 70% Side Overlap = 48 Images, Total = 174. assuming 30% extended edges add 20 Images. Total 194. Please verify & confirm. I want to understand the math behind so I can plan my missions technically accurate.
REALICE 31 VUELOS CON UN DRON WINGTRA PARA CUBRIR 2000 HAS, EL RESULTADO FUE DE 19400 IMAGENES, PROCESE LAS IMAGENES EN UN SOLO GRUPO Y ESTOY REALIZANDO EL PROCESAMIENTO EN 2 COMPUTADORAS UNA DE 12 NUCLEOS Y OTRA DE 36 NUCLEOS AMBAS TIENEN UNA TARJETA DE VIDEO 1080 LA DE 12 N Y LA OTRA DE 2080 DE LA DE 36, PERO LAMENTABLEMENTE NO PUEDO IR A LA PASO 2 PORQUE ME TRUENA EL PROCESO, SERIAN TAN AMABLE DE AYUDARME PARA VER COMO PROCESAR, SE LES ESTA ENVIANDO LOS LOGS DE CADA UNA DE LA COMPUTADORA EN OTRO CORREO PERO COMO ESTAN MUY PESADOS SE ANEXA UN LINKS.
ESPERO Y NOS PUEDAN AYUDAR.
DANIEL MARIN
Hola Juan Daniel,
Lamentablemente, su comentario no tiene nada que ver con este artículo.
Por favor, si usted es elegible para recibir apoyo personal, envíenos un ticket aquí:
https://support.pix4d.com/hc/en-us/requests/new?
Si no lo está, no dude en publicar en nuestra nueva plataforma de Comunidad.
Allí podrá adjuntar sus documentos o enlaces de descarga.
https://community.pix4d.com/
Saludos
Is tehre any video about each example showing what we kind of data/information we can extract?
Regards!
HI Paulo Henriques,
Here are all our videos:
Pix4Dmapper-video-tutorials
Here are described all the outputs that can be generated in Pix4Dmapper:
Pix4D-outputs-with-other-software-by-output
Basically it generates point cloud, 3D textured mesh, orthomosaic and DSM. Then it is on you to know which information you want to extract.
Best
