Supported drones, cameras and controllers - PIX4Dcapture
Important: PIX4Dmapper, PIX4Dcloud, PIX4Dinspect, PIX4Dmatic, PIX4Dreact, and PIX4Dfields can process images taken virtually from any image acquisition app even if PIX4Dscan or PIX4Dcapture don't support the drone. For more information: Which image acquisition app can I use with Pix4D's software?
Drones and cameras supported by Pix4D's software and apps
Drones, cameras and controllers supported by PIX4Dcapture
The status of PIX4Dcapture support for the different drones, cameras, and controllers is described in the table below. When the app has not been tested, it means that the app could work, but Pix4D makes no guarantee.
If a non-DJI camera is mounted on DJI drones, PIX4Dcapture will not be able to trigger the camera. Making it work will rely on the fact that a time-lapse can be set in this custom camera. A specific functionality has been developed on iOS to keep the right overlap up to the camera specifications. More information here.
Manufacturer Drone / Camera / Controllers Android iOS
DJI drones Inspire 1 (X3, X5, XT) Compatible (2.0.6 and later) Compatible (1.0.0 and later)
Inspire 2 (X4S, X5S) Compatible (3.8.1 and later) Compatible (1.7.1 and later)
Mavic Air Compatible (4.3.0 and later) Compatible (3.2.0 and later)
Mavic Air 2 Not compatible Not compatible
Mavic Mini Not compatible Not compatible
Mavic Pro Compatible (3.5.0 and later) Compatible (1.6.0 and later)
Mavic 2 Pro Compatible (4.5.0 and later) Compatible (4.1.0 and later)
Mavic 2 Zoom Not compatible Not compatible
Mavic 2 Enterprise (Zoom) Not compatible Not compatible
Mavic 2 Enterprise (Dual) Not compatible Compatible only with RGB (4.7.0 and later)
Mavic 3 Not compatible Not compatible
Matrice 100 (X3, X5, XT) Compatible (3.1.1 and later) Compatible (1.4.0 and later)
Matrice 200 Compatible (4.1.1 and later) Compatible (2.9.2 and later)
Matrice 200 V2 series Not compatible Compatible - Not tested (4.10.0 and later)
Matrice 210 Compatible (4.1.1 and later) Compatible (2.9.2 and later)
Matice 210 V2 Not tested Not tested
Matrice 210 RTK Compatible (4.1.1 and later) Compatible (2.9.2 and later)
Matrice 300 RTK Not compatible Not compatible
Matrice 600 (X3, X5, XT) Not tested Compatible (2.0.0 and later)
Phantom 1 Not compatible Not compatible
Phantom 2 Not compatible Not compatible
Phantom 2 Vision Not compatible Not compatible
Phantom 2 Vision+ Not compatible Not compatible
Phantom 3 Advanced Compatible (2.0.6 and later) Compatible (1.0.0 and later)
Phantom 3 Professional Compatible (2.0.6 and later) Compatible (1.0.0 and later)
Phantom 3 Standard Compatible (3.1.0 and later) Compatible (1.0.0 and later)
Phantom 3 4K Not tested Not tested
Phantom 4 Compatible (3.1.0 and later) Compatible (1.2.0 and later)
Phantom 4 Advanced Not tested Not tested
Phantom 4 Pro V1 Compatible (3.6.0 and later) Compatible (1.6.1 and later)
Phantom 4 Pro+ V1 Not tested Not compatible
Phantom 4 Pro V2.0 Compatible (4.3.2 and later) Compatible (3.4.0 and later)
Phantom 4 Pro+ V2.0 Not compatible Not compatible
P4 Multispectral  Not compatible Not compatible
Spark (Free flight mission only) Compatible (3.8.5 and later) Compatible (2.3.0 and later)
DJI cameras Zenmuse XT Compatible (3.6.0 and later) Compatible (2.0.0 and later)
Zenmuse XT2 Not compatible Compatible - Not tested (4.10.0 and later)
Zenmuse X3 Compatible (2.0.6 and later) Compatible (1.0.0 and later)
Zenmuse X4S Compatible (3.8.1 and later) Compatible (1.7.1 and later)
Zenmuse X5 Compatible (2.1.1 and later) Compatible (1.2.0 and later)
Zenmuse X5R Not tested Not tested
Zenmuse X5S Not tested, compatible (3.8.1 and later) Compatible (1.7.1 and later)
Zenmuse X7 Not compatible Not compatible
Zenmuse Z3 Not compatible Compatible - Not tested (4.10.0 and later)
Zenmuse Z30 Not compatible Compatible - Not tested (4.10.0 and later)
DJI controllers Smart controller Not compatible Not compatible
Parrot drones Anafi Compatible (4.4.0 and later) Compatible (4.0.0 and later)
Anafi Thermal (RGB+ Thermal images) Compatible (4.8.0 and later) Compatible (4.8.0 and later)
Anafi USA (RGB only) Compatible (4.10.0 and later) Compatible (4.11.0 and later)
Bebop 1 Not compatible Not compatible
Bebop 2 using Wifi Not compatible Not compatible
Bebop 2 with Skycontroller 2 Compatible (2.1.1 and later) Compatible (1.1.0 and later)
Bluegrass Compatible (4.1.0 and later) Compatible (2.7.0 and later)
Disco Not compatible Not compatible
Disco-Pro AG Not compatible Compatible (2.0.0 and later)
Parrot controllers Skycontroller Not compatible Not compatible
Skycontroller 2 Compatible (3.8.0 and later) Compatible (1.6.0 and later)
Skycontroller 3 Compatible (4.4.0 and later) Compatible (4.0.0 and later)
Yuneec drones H520 Compatible (4.2.0 and later) Not compatible
Yuneec cameras E90 Compatible (4.2.0 and later) Not compatible
Yuneec controllers ST16, ST16S Compatible (4.2.0 and later) Not compatible
3DR Solo (GoPro Hero 4 Black or Silver) Not compatible Not compatible (no iOS SDK)
Recommendations to fly a drone that was not tested
The drone to be selected before starting a mission should be one of those having the same connection mode (Wi-Fi or USB cable).
Tip: The following drones are not officially supported by PIX4Dcapture. However, you may be able to fly your mission if you select the appropriate settings in PIX4Dcapture:
  • DJI Phantom 3 4K: Select Phantom 3 Advanced or Professional in PIX4Dcapture's settings.
  • DJI Phantom 4 Advanced: Select Phantom 4 Pro in PIX4Dcapture's settings.
  • DJI Matrice 600: Select Matrice 100 in PIX4Dcapture's settings.
102 out of 131 found this helpful
123 comments
  • Kapil (Pix4D)
    Hello Ivan,
    The Mavic 2 Enterprise is only supported on the iOS version of Pix4Dcapture. However, the Pix4Dcapture app is only compatible with the RGB camera. If you have any issues, I would suggest you go through all the basic checks and troubleshooting steps as it will solve most of the issues that can be encountered if properly followed.
    Regards,
  • Gabriel Martins Genovez
    Gostaria de saber se tem compatibilidade com o drone fimi x8 se dá xiaomi
  • Kapil (Pix4D)
    Hi Gabriel, It is not compatible with Xiaomi FIMI X8.
  • Juan Arce
    Hello I want to know if the mvick air 2 will be support at some point?
    thanks
  • Fernanda Bosmediano
    Hi Juan,
    Supporting the DJI Mavic Air 2 is not in our roadmap for this year. If we support this drone, we will notify our users in our social media.
    Kind regards,
  • Wilmer Johan Hernandez
    Hola
    Tengo un dron Phantom 3 estandar y actualmente no me deja realizar el plan de vuelo con la aplicación Pix4Dcapture
  • Kapil (Pix4D)
    Hello,
    The behavior you are describing can’t be replicated on our side and has not been reported to us so far. I would suggest you go through all the [basic checks and troubleshooting steps] as it will solve most of the issues that can be encountered if properly followed.
    Regards,
  • Yohan Jang
    Hello,
    Will skydio 2 be supported by pix4d?
    Thanks.
    Hi,
    The Skydio 2 is not supported by Pix4Dcapture at the moment and it is currently not in our pipeline to support it. However, your interest has been shared with the team and any updates will be published on this page.
  • Gianni Gregoris
    Hi
    In future there are any possibilty tha Pix4d can be avaible on Dji Matrice 300 RTK ?
    If yes, When ?
    Thanks and bestregards
  • Kapil (Pix4D)
    Hello Gianni,
    The DJI Matrice 300 RTK  is not supported by pix4Dcapture at the moment and it is currently not in our pipeline to support it by the first quarter of 2021. If things change, we will publish it at our page on Supported drones, cameras and controllers
    I would also recommend you to go through our support article on Which image acquisition app can I use with Pix4D’s software?.
  • Mubashshir Zaman
    Hi,
    Since the SDK for the DJI Mavic Mini has been available since the end of July 2020, I was wondering whether or not Pix4d were working to make it compatible with the application. I know many people, including myself, would love to see Pix4d be compatible with the mini drone.
  • Gustavo Salvador
    Buenos días..
    Cuando podremos soportar el DJI Mavic Air 2 con la app de Pix4d capture,
    Cuando harán la actualización?
  • Zendesk Admin Service Account
    There are no plans for the Pix4Dcapture app to support the DJI Mavic Air 2 in 2020.
    You can find more information on our forum
    Edited by Zendesk Admin Service Account
  • bsyrt immas
    Since the upgrading of Anafi Parrot to firmware 1.7, Pix4D mapper is not working anymore on Android
  • Kapil (Pix4D)
    Hello,
    The Parrot Anafi won't work with the recent firmware update of 1.7.3. We will release a new version for Pix4Dcapture android within a few weeks and it should work with that version.
    For now, the only option is not updating the firmware to 1.7 or using the iOS version of the Pix4Dcapture app.
    Regards,
  • Sara Heshmati
    Hi,
    Anyone to please update me on this:
    Has anyone tried flying missions using Pix4dCapture on Android with the Matrice 200 v2 (just want to know if it is now compatible)? It is annoying that one can't import kml files into the iOs version of Pix4dCapture especially if you need the mission to accurately overlay the area of interest.
    Are there any plans to make this possible for users, it has been requested by several pix4d community members already.
    Edited by Sara Heshmati
  • Claudio Paiano
    Buonasera io ho un mavic air 2 e al momento px4d non è supportato. Quando è possibile utilizzare la app? Grazie e buona serata
  • Kapil (Pix4D)
    Hello,
     At the moment and it is currently not in our pipeline to support it. If things change, we will publish it on our page on Supported drones, cameras, and controllers
  • Michael Herman
    I'm disappointed to see the DJI Mavic 2 Zoom is not supported.  Can you explain the reason for this?  Thank you, Michael
  • nico tripcevich
    Hello good news from DJI regarding the SDK allowing 3rd party support for the Mavic Air 2:
    Dear Developer, We are excited to announce the release of the DJI Mobile SDK 4.14 Trial1 and DJI UX SDK 4.14 Trial1. You can find them on our developer site at DJI MSDK Download 2, DJI UXSDK Download.
    This version of Mobile SDK introduces support for DJI Mavic Air 2 and adds some new features for Matrice 300 RTK, including the selection of lens to for taking photos or recording videos, custom file name and folder name for manual flight and waypoint flight, and support radar accessories for obstacle avoidance. Also, we added some new features for Phantom 4 RTK, including fetch XMP file from camera and support maintain positioning accuracy mode. In addition, we have fixed some serious bugs. Please refer to the release notes for the full list of changes.
    This version of UX SDK introduces support for Mavic Air 2 and fixes for various bugs. We are transitioning towards an upcoming major version of UX SDK, version 5.0, which is open source, modular and customizable. Shortly after this 4.14 release, you will find the new iOS UXSDK version 5 beta 4 1 and Android UX SDK version 5 beta 5 1 on Github. We look forward to all of your feedback and pull requests.
    As always, the DJI Dev Team is committed to improving your developer experience. Please report any bugs or questions you have to dev@dji.com. We recommend frequently checking the DJI SDK Download Page to ensure that you are always working with the latest version of the DJI SDK.
    If you don’t want to subscribe news about our SDK anymore, you can go to our developer website to unsubscribe it. You can go to the link below to unsubscribe.
    link: https://developer.dji.com/user/account 1
    If you would like to contribute or ask questions to the DJI Developer Community please check out DJI Developer Forum here: EN CN.
    Best, The DJI Developer Technologies Team
  • JM Tecno
    Good morning, recently DJI has released compatible SDK for DJI Mavic Air 2, the question is easy.
    Will you make Pix4D compatible with Mavic Air 2? When?
  • JM Tecno
    Good morning, recently DJI has released a compatible SDK for DJI Mavic Air 2 v.2020.12.10, the question is easy.
    Edited by JM Tecno
    Hello, thanks for posting the news!
    Unfortunately, there are no plans to support the Mavic Air 2 in Pix4Dcapture.
    If anything changes, we will communicate on the official post for Mavic Air 2:
    DJI Mavic air 2 and Pix4Dcapture
  • Maek Ebersole
    Does anyone know if there is plans for the Mavic Air 2 to be supported?
    Hello! Pix4Dcapture, our flying app does not support the Mavic Air 2.
    Please keep in mind that our processing software such as Pix4Dmapper can process images taken from virtually any flying app as long as they are of good quality and overlap. For more information: Which image acquisition app can I use with Pix4D's software?.
    That being said, you can get a trial of our processing software and start using them with your Mavic Air 2 images at any moment.
  • Maek Ebersole
    I will consider Pix4Dmapper when I can use Pix4Dcapture.  The SDK has been available so your software should be made to support the Mavic Air 2.  Let us know when it is available.
  • Han Jidong
    I need your support for Mavic air2. When can I apply?
  • Jaeho Lee
    I would like to continue Pix4d Mapper, but, my drone is 'DJI matrice 300 RTK'. Do you a plan for the drone to use ?
    Hello Jaeho,
    Currently, there is no plan to add the DJI matrice 300 RTK in Pix4Dcapture.
