Important: PIX4Dmapper, PIX4Dcloud, PIX4Dmatic, PIX4Dreact, and PIX4Dfields can process images taken virtually from any image acquisition app even if PIX4Dscan or PIX4Dcapture don't support the drone. For more information: Which image acquisition app can I use with Pix4D's software?
List of drone/camera/controller supported by PIX4Dcaputre
Manufacturer
Drone / Camera / Controllers
Android
iOS
Inspire 2 (X4S, X5S)
Compatible (3.8.1 and later)
Compatible (1.7.1 and later)
Mavic Air
Compatible (4.3.0 and later)
Compatible (3.2.0 and later)
Mavic Air 2
Not compatible
Not compatible
Mavic Mini
Not compatible
Not compatible
Mavic Pro
Compatible (3.5.0 and later)
Compatible (1.6.0 and later)
Mavic 2 Pro
Compatible (4.5.0 and later)
Compatible (4.1.0 and later)
Mavic 2 Zoom
Not compatible
Not compatible
Mavic 2 Enterprise (Zoom)
Not compatible
Not compatible
Mavic 2 Enterprise (Dual)
Not compatible
Compatible only with RGB (4.7.0 and later)
Mavic 3
Not compatible
Not compatible
Matrice 200
Compatible (4.1.1 and later)
Compatible (2.9.2 and later)
Matrice 200 V2 series
Not compatible
Compatible - Not tested (4.10.0 and later)
Matrice 210
Matice 210 V2
Not tested
Not tested
Matrice 210 RTK
Matrice 300 RTK
Not compatible
Not compatible
Phantom 1
Not compatible
Not compatible
Phantom 2
Not compatible
Not compatible
Phantom 2 Vision
Not compatible
Not compatible
Phantom 2 Vision+
Not compatible
Not compatible
Phantom 3 Advanced
Compatible (2.0.6 and later)
Compatible (1.0.0 and later)
Phantom 3 Professional
Phantom 3 Standard
Compatible (3.1.0 and later)
Phantom 4
Compatible (1.2.0 and later)
Phantom 4 Pro V1
Compatible (3.6.0 and later)
Compatible (1.6.1 and later)
Phantom 4 Pro V2.0
Compatible (4.3.2 and later)
Compatible (3.4.0 and later)
Phantom 4 Pro+ V2.0
Not compatible
Not compatible
P4 Multispectral
Not compatible
Not compatible
Spark (Free flight mission only)
Compatible (3.8.5 and later)
Compatible (2.3.0 and later)
Zenmuse XT2
Not compatible
Zenmuse X3
Zenmuse X4S
Zenmuse X5
Compatible (2.1.1 and later)
Zenmuse X5R
Not tested
Not tested
Zenmuse X5S
Not tested, compatible (3.8.1 and later)
Zenmuse X7
Not compatible
Not compatible
Zenmuse Z3
Not compatible
Zenmuse Z30
Not compatible
DJI controllers
Smart controller
Not compatible
Not compatible
Parrot drones
Anafi
Compatible (4.4.0 and later)
Compatible (4.0.0 and later)
Anafi Thermal (RGB+ Thermal images)
Compatible (4.8.0 and later)
Anafi USA (RGB only)
Compatible (4.10.0 and later)
Compatible (4.11.0 and later)
Bebop 1
Not compatible
Not compatible
Bebop 2 using Wifi
Not compatible
Not compatible
Bebop 2 with Skycontroller 2
Compatible (1.1.0 and later)
Bluegrass
Compatible (2.7.0 and later)
Disco
Not compatible
Not compatible
Disco-Pro AG
Not compatible
Compatible (2.0.0 and later)
Parrot controllers
Skycontroller
Not compatible
Not compatible
Skycontroller 2
Compatible (3.8.0 and later)
Skycontroller 3
Yuneec drones
H520
Compatible (4.2.0 and later)
Not compatible
Yuneec cameras
E90
Not compatible
Yuneec controllers
ST16, ST16S
Not compatible
3DR
Solo ( GoPro Hero 4 Black or Silver)
Not compatible
Not compatible (no iOS SDK)
Recommendations to fly a drone that was not tested
The drone to be selected before starting a mission should be one of those having the same connection mode (Wi-Fi or USB cable).
Tip: The following drones are not officially supported by PIX4Dcapture. However, you may be able to fly your mission if you select the appropriate settings in PIX4Dcapture:
- DJI Phantom 3 4K: Select Phantom 3 Advanced or Professional in PIX4Dcapture's settings.
- DJI Phantom 4 Advanced: Select Phantom 4 Pro in PIX4Dcapture's settings.
- DJI Matrice 600: Select Matrice 100 in PIX4Dcapture's settings.
