English
FAQ Pix4D supported RTK devices - PIX4Dcatch
What is a Pix4D-adapted RTK device?
Pix4D adapted RTK devices for use with Pix4D can be attached to certain phone devices or tablets. When paired with PIX4Dcatch, these devices can geotag images with RTK precision as they are captured. This synchronization allows for real-time connection to NTRIP services, ensuring absolute accuracy for 3D photogrammetry scans.
Extensive research has revealed that it is possible to achieve 3D models with an absolute geolocation accuracy of less than 5 cm. More information is in the white paper.
The hand-held RTK devices replaces more expensive ground surveying equipment that does not compromise on accuracy to achieve 3D, actionable results.
How to use the PIX4Dcatch with a Pix4D-adapted RTK device?
Basic requirements:
  • PIX4Dcatch app.
  • Pix4D supported RTK device.
  • NTRIP service subscription.
  • Internet access.
  • PIX4Dmatic, PIX4Dmapper, or PIX4Dcloud (Advanced) license or trial for processing.
Once the latest version of PIX4Dcatch is installed, select the Pix4D supported RTK device via Bluetooth settings.
What are the recommended devices?
Recommended
Supported
iOS
iPhone 17 Pro Max
iPhone 17 Pro
iPhone 16 Pro Max
iPhone 16 Pro
iPhone 15 Pro Max
iPhone 15 Pro
iPhone 14 Pro
iPhone 14 Pro Max
iPhone 13 Pro
iPhone 13 Pro Max
iPhone 12 Pro
iPhone 12 Pro Max
iPad Pro 11-inch (2nd gen and later)*
Any iPhone device with an iOS version 18.0 and higher
Any iPad 11-inch (2nd gen and later) device with an iOS version 18.0 and higher
Any iPad 12.9-inch (2nd gen and later) device with an iOS version 18.0 and higher
Android
Any Android device with ARCore and Depth API capability**
Any Android device with ARCore capability
*Wi-Fi-only iPad models do not contain an internal GPS. This may result in projects not being geolocated unless used with the Pix4D-adapted viDoc RTK rover or GCPs.
**LiDAR is not supported on Android
Important: RTK devices are not supported on Android from version 1.28.0 please contact to the RTK distributor
If you bought the RTK device through Pix4D, please Contact Support
How are the images captured in PIX4Dcatch synchronized with the Pix4D supported RTK devices?
The image acquisition in PIX4Dcatch is independently done from the recording of the GNSS data from the RTK rover. When the capture is complete and the project is saved, the geolocation information from the rover is tagged to the corresponding images based on the image timestamps. The orientation of the images is computed based on information from the AR tracking. If part of the GNSS data has low accuracy (for example, due to poor satellite visibility), relative AR positioning is used to improve the positions and accuracy.
How are the orientations of images set when using PIX4Dcatch+Pix4D supported RTK devices?
The orientation of the geotagged images is indirectly computed from the internal IMU (Inertial Measurement Unit) of the mobile device and not from the Pix4D supported RTK devices.
Is the offset between the rover's antenna and the camera taken into account?
Yes this is one of the most important things when you setup your RTK device, we currently offer measured offsets from known devices that can be selected from the app.
If your device combination with the RTK device isn't measured yet would be necessary to measure and enter the offset manually For more information check the respective article to your RTK device:
Emlid Reach RX
Trimble
Bad Elf Flex
viDoc distributed by Pix4D
Can I generate a 3D model or 2D map in a coordinate reference system of my choice using PIX4Dcatch+Pix4D-adapted devices?
It is possible to select the coordinate system when uploading to PIX4Dcloud/PIX4Dcloud Advanced, in PIX4Dmatic or PIX4Dmapper, to get the 3D model or 2D map in a coordinate reference system of your choice. You can also transform the image geolocation in the desired coordinate system with third-party software.
For more information:
What is the height reference of the geolocated images and how can I change it?
The height is based on the ellipsoid of the input horizontal coordinate reference system.
Example: The input coordinate reference system has to match the coordinate reference system the NTRIP service broadcasts corrections. We have identified several input coordinate reference systems used from various regions and the associated ellipsoid.
Input coordinate reference system
Ellipsoidal height over the:
Europe - ETRS 89 (EPSG: 4258)
GRS 1980 ellipsoid
United States - NAD83(2011) (EPSG: 6318)
GRS 1980 ellipsoid
Japan - JGD2001 (EPSG:6668)
GRS 1980 ellipsoid
Singapore - SVY21 (EPSG:4757)
WGS 84 ellipsoid
In order to get the results georeferenced based on the local geoid, you can:
Will tilting the device during data acquisition have an impact on the accuracy of the 3D models?
The antenna on the Pix4D supported RTK devices has the best visibility of satellites when it is directly pointing upwards (90 degrees). The more the antenna is tilted from the 90-degree position, the lower its accessibility to satellites. Hence, it is recommended to only slightly tilt the device from the ideal 90-degree position to a maximum of 20 degrees.
How precisely is the RTK trajectory synchronized with the images?
The images acquired from PIX4Dcatch+Pix4D supported devices should be precisely synchronized to within 100ms.
Please ensure that the device clock is synchronized. To synchronize the clock in your iPhone or iPad:
  • Open the Settings app.
  • Tap "General."
  • Tap "Date & Time."
  • Verify that "Set Automatically" is toggled to the right and appears green.
Can Pix4D-adapted viDoc RTK devices for PIX4Dcatch be used without an internet connection?
An internet connection is needed during data capture to stay connected to the NTRIP service.
An internet connection is also needed every time PIX4Dcatch is started for logging into the app and uploading the data to PIX4Dcloud for generating the 3D model.
Can I do PPK or use my own base station?
At the moment the Pix4D supported RTK devices only allows access to an NTRIP service to receive real-time correctional GNSS data. It is not possible to do PPK or to connect to your own base station.
Can I accurately acquire data with PIX4Dcatch + Pix4D supported RTK devices over time?
Yes, PIX4Dcatch with Pix4D supported RTK devices allows to capture and process a 4D model and visualize it on PIX4Dcloud Advanced's timeline. Due to the RTK accuracy, the 3D models at different times are registered with cm accuracy. You can use PIX4Dcloud Advanced sliders to compare orthomosaics or track volume changes of small stockpiles.
Can I combine RTK drone data and terrestrial PIX4Dcatch + Pix4D supported RTK devices mobile phone data?
Drone RTK flights, as well as PIX4Dcatch RTK data, can be combined in a single project inside PIX4Dmapper to obtain a 3D model that has the overview and roof data (from drone imagery) as well as the terrestrial details (from PIX4Dcatch mobile phone data).
More information about how to process such datasets is in the How to merge projects article.
How can I purchase the Pix4D supported RTK devices?
Contact us directly for the purchase of the Pix4D supported RTK devices.
How can I get technical support for the Pix4D supported RTK devices?
Pix4D customers: For technical questions, contact our support team.
Not a customer yet? Contact sales or post on the Pix4D Community.
Battery care and maintenance.
The following recommendations will ensure optimum performance and extend the life of your batteries:
  • The battery is supplied partially charged. Fully charge the battery before using it for the first time.
  • Try not to allow the batteries to fully discharge.
  • Keep the battery charged continuously when not in use.
  • If you need to store the rover, fully charge it before storage and then charge it at least every three months.
  • To charge the battery, only use a charger/cable that is suitable for charging the lithium-ion battery.
  • If the unit has been stored for more than three months, charge the battery before using the receiver.
  • During operation, it is possible to charge the Pix4D supported RTK devices with a power bank when the battery status is low.
Which geoids are compatible with PIX4Dcatch and the RTK devices?
The following list contains the geoids available to PIX4Dcatch using the Pix4D supported RTK devices.
Important: Before selecting the Geoid, it is necessary to select the correct Vertical coordinate reference system. Only geoids corresponding to a certain vertical coordinate system are listed in the Geoid drop-down menu.
When selecting the vertical coordinate reference system, be sure the unit of measurement is the same as the horizontal coordinate reference system. e.g. ftUS/ftUS, meter/meter, not ft/ftUS, ft/meter etc.
Country or region Vertical coordinate reference system Geoid
  Global
EGM2008 height - (EPSG:3855) EGM2008
EGM96 height - (EPSG:5773) EGM96
Argentina SRVN16 height - (EPSG: 9255) GEOIDE-Ar16
Arctic SVD2006 - (EPSG: 20000) arcgp-2006-sk
Australia
AHD height - (EPSG:5711)
AUSGeoid98
AHD (Tasmania) height - (EPSG:5712)
AUSGeoid09
AHD height - (EPSG:5711) AUSGeoid2020
Austria EVRF2000 Austria height - (EPSG: 9274) Austrian Geoid 2008
Belgium Ostend height - (EPSG: 5710) hBG18
Canada
CGVD28 height - (EPSG:5713) CGG2000/HTv2.0
CGVD2013 height - (EPSG:6647) CGG2013
CGVD2013(CGG2013a) height - (EPSG:9245) CGG2013a
Czechia and Slovakia Baltic 1957 height - (EPSG: 8357) DVRM05
Denmark - onshore
DNN height - (EPSG:5733) DNN
DVR90 height - (EPSG:5799) DVR90
DVR90 height - (EPSG:10483) DVR90
DVR90 height - (EPSG:10484) DVR90
DVR90 height - (EPSG:10485) DVR90
Faroe Islands - onshore FVR09 height - (EPSG: 5317) FVR09
Finland
N60 height - (EPSG:5717) FIN2000
N2000 height - (EPSG:3900) FIN2005N00
N2000 height - (EPSG:3900) FIN2023N2000
France - mainland onshore NGF-IGN69 height - (EPSG:5720) RAF09, RAF18, RAF18b, RAF20
France - Corsica onshore NGF-IGN78 height - (EPSG: 5721) RAC09
Germany DHHN2016 height - (EPSG: 7837) GCG2016
Greece Piraeus height - (EPSG: 5716) GR_HEPOS2011
Gibraltar - onshore and Spain - mainland onshore Alicante height - (EPSG: 5782) EGM08-REDNAP
Greenland - onshore and offshore between 58°N and 85°N and west of 7°W GVR2016 height - (EPSG: 8267) GGEOID2016
Greenland - onshore and offshore between 59°N and 84°N and west of 10°W GVR2000 height - (EPSG: 8266) GGEOID2000
Hungary EOMA1980 height - (EPSG: 5787) Geoid2014
Iceland - onshore ISH2004 height - (EPSG: 8089) IceGeoid2011
Ireland - onshore United Kingdom (UK) - Northern Ireland (Ulster) - onshore Malin Head height - (EPSG: 5731) OSGM15
Isle of Man - onshore Douglas height - (EPSG: 5750) OSGM15
Japan - onshore mainland - Hokkaido, Honshu, Shikoku, Kyushu
JGD2011 (vertical) height - (EPSG: 6695) GSIGEO2011
JPGEO2024 (vertical) height - (EPSG: 6695) GSIGEO2024
Latvia Latvia 2000 height - (EPSG: 7700) LV14
Mexico
NAVD88 height - (EPSG: 5703)
GGM10
NAVD88 height - (EPSG: 6360)
NAVD88 height - (EPSG: 8228)
Netherlands - onshore, including Waddenzee, Dutch Wadden Islands, and 12-mile offshore coastal zone NAP height - (EPSG: 5709) NLGEO2018
New Zealand
NZVD2009 height - (EPSG:4440) NZGeoid2009
NZVD2016 height - (EPSG:7839) NZGeoid2016
Northern Mariana Islands - onshore - Rota, Saipan, and Tinian
NMVD03 height - (EPSG:6640)
GEOID12A
GEOID12B
Norway - onshore
NN54 height - (EPSG:5776) HREF2008a
NN2000 height - (EPSG:5941) HREF2018b
Poland
EVRF2007-PL height - (EPSG:9651)
PL-geoid-2011
Baltic 1986 - (EPSG:9650)
EVRF2007-PL height - (EPSG:9651) PL-geoid-2021
Portugal Cascais height - (EPSG: 5780) GeodPT08
Puerto Rico - onshore
PRVD02 height - (EPSG:6641)
GEOID12A
GEOID12B
GEOID18
Singapore SHD height - (EPSG: 6916) SGeoid09
Slovenia SVS2010 height - (EPSG: 8690) SLO-VRP2016/Koper
South Africa - onshore SA LLD height - (EPSG: 9279) SAGEOID2010*
Spain - Balearic Islands - Ibiza and Formentera Ibiza height - (EPSG:9394)
EGM08-REDNAP
Spain - Balearic Islands - Mallorca Mallorca height - (EPSG:9392)
Spain - Balearic Islands - Menorca Menorca height - (EPSG:9393)
Spain - Canary Islands - El Hierro El Hierro height - (EPSG:9401)
Spain - Canary Islands - Fuerteventura Fuerteventura height - (EPSG:9396)
Spain - Canary Islands - Gran Canaria Gran Canaria height - (EPSG:9397)
Spain - Canary Islands - La Gomera La Gomera height - (EPSG:9399)
Spain - Canary Islands - La Palma La Palma height - (EPSG:9400)
Spain - Canary Islands - Lanzarote Lanzarote height - (EPSG:9395)
Spain - Canary Islands - Tenerife Tenerife height - (EPSG:9398)
Spain - Ceuta Ceuta 2 height - (EPSG:9398)
St Helena, Ascension, and Tristan da Cunha - St Helena Island - onshore SHVD2015 height - (EPSG: 7890) EGM2008
Sweden - onshore RH2000 height - (EPSG: 5613) SWEN17
Switzerland and Liechtenstein
LN02 height - (EPSG:5728)
CHGeo2004
LN95 height - (EPSG:5729)
Taiwan TWVD 2001 height - (EPSG: 8904) TWGEOID2018h
United Kingdom (UK) ODN height - (EPSG:5701)
OSGM15
United Kingdom (UK) - Great Britain - England - Isles of Scilly onshore St Marys height - (EPSG:5749)
United Kingdom (UK) - Great Britain - Scotland - Orkney Islands onshore ODN Orkney height - (EPSG:5740)
United Kingdom (UK) - Great Britain - Scotland - Outer Hebrides onshore Stornoway height - (EPSG:5746)
United Kingdom (UK) - Great Britain - Scotland - Shetland Islands onshore Lerwick height - (EPSG:5742)
United Kingdom (UK) - Northern Ireland (Ulster) - onshore Belfast height - (EPSG:5732)
United Kingdom (UK) – offshore between 2km from shore and boundary of UKCS within 49°46'N to 61°01'N and 7°33'W to 3°33'E ODN (Offshore) height - (EPSG:7707)
United States (USA) NAVD88 height (US Survey foot) - (EPSG: 6360)
GEOID03, GEOID06, GEOID09, GEOID12A, GEOID12B, GEOID18, GEOID99, GGM10*
United States (USA) - onshore - Arizona, Michigan, Montana, North Dakota, Oregon, South Carolina NAVD88 height (foot) - (EPSG: 8228)
United States (USA) NAVD88 height - (EPSG: 5703)
US Virgin Islands - onshore - St Croix, St John, and St Thomas VIVD09 height - (EPSG: 6642) GEOID12A, GEOID12B, GEOID18
American Samoa - Tutuila Island ASVD02 height - (EPSG: 6643) GEOID12A, GEOID12B
Guam - onshore GUVD04 height - (EPSG: 6644) GEOID12A, GEOID12
* Geoid not available in PIX4Dcloud / PIX4Dcloud Advanced
