New dataset > GCPs automatization > Processing without GCPs/checkpoints - PIX4Dcloud
Create a new dataset to start processing imagery and create maps and digital twins of the reality or upload outputs to PIX4Dcloud.
Licenses: This article is valid for all PIX4Dcloud licenses.
Roles: Only Owners, Managers, and Editors can create and process datasets in PIX4Dcloud.
| 1.Dataset creation > | 2. Image selection > | 3.Output coordinate system > | 4.Processing options > | 5. GCPs automation |
| Processing with GCPs/checkpoints / | Processing without GCPs/checkpoints |
To process a project without GCPs:
- Click Skip and process.
The project starts processing to finalize the dataset creation. The upload of the inputs to the server is started.
Note: If Automatically start processing is enabled, processing starts automatically after all images have been uploaded.
The processing status in the PIX4Dcloud interface may take some time to update to Processing ongoing. This does not necessarily mean that processing has not started.
An email notification is sent to confirm when processing starts.
Information:
- Once the dataset begins processing, it is no longer possible to add more images or make changes to the processing options.
- If changes to the processing options are necessary after the dataset has already begun processing, a new project must be created and processed from scratch.
- If a user is unsure whether all images will be uploaded to the project (due to internet connection issues) or believes more will be necessary, PIX4D recommends disabling the "Start Processing Automatically" option. This will allow more images to be manually added before beginning dataset processing.
