Remote device deactivation - PIX4Dmapper
PIX4Dmapper includes a remote device deactivation feature allowing a device to be deactivated remotely. This feature can be used to deactivate inaccessible devices occupying a seat on the license. This feature will come automatically enabled with all new PIX4Dmapper licenses, older licenses will have to enable this feature manually.
Enable remote device deactivation
New PIX4Dmapper licenses will have the Remote device deactivation option enabled by default. Previously acquired PIX4Dmapper licenses will have to enable this feature manually.
Important: Before enabling the Remote device deactivation feature, it is necessary to log out all active devices. Active devices will prevent the feature from being enabled.
To enable the Remote device deactivation feature:
  1. Open PIX4Dmapper.
  2. Log out of PIX4Dmapper from all active devices. For more information see How to log out PIX4Dmapper.
  3. Go to the Licenses panel.
  4. In the PIX4Dmapper license, next to the Remote device deactivation, click Enable now.
    PIX4Dmapper enable remote device deactivation
    Enabling remote device deactivation.
  5. Now launch PIX4Dmapper again.
How to deactivate a device remotely
Once the Remote device deactivation feature is enabled, a device can be deactivated remotely as needed.
To remotely deactivate a computer:
  1. Go to the Licenses panel.
  2. Identify the PIX4Dmapper license and the seat that needs deactivation.
  3. In the Active devices section, click DeactivatePIX4Dmapper deactivate button
    PIX4Dmapper deactivate device remote
    Deactivating a device from the license panel.
  4. (Optional) Contact us if a Pix4D license is occupied by a device that cannot be remotely deactivated or from which logging out is impossible.
Note: The device must connect to the Internet at least once every 30 days, or it will be automatically deactivated.
7 out of 29 found this helpful
67 comments
  • University of Madras Department of Geography
    Dear support
    Our system is crashed due to device issue we couldn't deactivate the license in SREC account we want need remotely deactivate the system kindly solve the issue
    License key is 37055892
    System is SREC
  • Kapil (Pix4D)
    Hello,
    I have gone ahead and deactivated the device you requested. There should now be a free seat on this license that you can use with another device. Please note that beginning with version 4.0.11 Pix4D desktop, you have the ability to remotely deactivate a device from the administrator portal of your Pix4D account. You can read about that on the top of this page.
    Edited by Kapil (Pix4D)
  • FERNANDA URENA
    Dear Pix4D support team:
    Currently, I have a problem when trying to deactivate remotly a device. The attached image shows the problem.
    The issue is, previously, appeared an icon like a trash bin at "Deactivate" field, and, the only thing that I had to do was click on it in order to deactivate a license.
    Now, this icon dissapeared and I don´t know how to solve this problem. I also realized that there is a new message that says "Never" on "Device Deactivation" field (please, see the image).
    Many thanks in advance for your coorperation.
  • Kapil (Pix4D)
    Hello, I have gone ahead and deactivated the device that was active. There should now be a free seat on this license that you can use with another device.
  • FERNANDA URENA
    Dear Kapil: thanks a lot!!
    Kind Regards!!
  • reseller aerocamservicios
    Estimado Kapil, en el cuadro de administrador de licencias solo da la opción de desactivar una maquina que este con internet y a la vez con la sesión apagada, aun no logro ver la utilidad de esta opción, en mi caso como capacitador necesitamos activar y desactivar la licencia en mas de 04 maquinas de manera constante, y ahora que una de ellas (la principal) le hemos formateado se quedó la licencia activada, el cuadro de administrador de licencias no me permite liberar esa maquina.
    Este caso es muy común en nuestros clientes, y para solucionarlo siempre hay que contactar con los de soporte técnico, si bien es cierto que funcionan muy bien, pero debería ser algo que uno mismo debería poder solucionar.
    Un cordial saludo,
    Eduardo Liberato
    AeroCam Servicios Perú.
  • Avatar
    Marco (Pix4D)
    Estimado Eduardo,
    Ya me he ocupado de su caso.
    Para aclarar, si desea tener la opción de desactivar su dispositivo desde Internet, debe cerrar la sesión para hacer el cambio y luego volver a iniciar sesión. Luego funcionará.
    Saludos
    Edited by Marco (Pix4D)
  • Phil Zimm
    Hello!
    I have exactly the same problem FERNANDA URENA has.
    Please, I really need to start processing ASAP.
    Regards Phil
    License 42afa69c
  • Avatar
    Marco (Pix4D)
    Dear Phil,
    I have deactivate manually the two devices that were activated on this license.
    Please note that if you want the remote deactivation to work, you should ensure that you logged off before you enable this option.
    Best
  • Phil Zimm
    Thank you! :-)
  • Chris Stiles
    Hey Support,
    Currently, I have a problem when trying to deactivate devices remotely. The license number is bb99ca2f
    Can you please deactivate the two devices manually for me, as I really need to use them ASAP.
    Thanks for your cooperation.
    Chris.
  • Avatar
    Beata (Pix4D)
    Hi Chris,
    I deactivated the devices as requested.
    Best!
  • Luis Sialer
    Hey Support,
    Currently, I have a problem when trying to deactivate devices remotely. The license number is b7a04a9e
    Can you please deactivate the two devices manually for me, as I really need to use them.
    Luis Sialer
  • Kapil (Pix4D)
    Hi Luis,
    I have deactivated the devices as you requested.
    Best!
  • Juan daniel Marin solis
    Hola Soporte
    Tengo un problema y necesito de su ayuda, es con la licencia, no puedo cerrar la sesión en un dispositivo de manera remota y yo estoy causando complicaciones, mi número de licencia es
      5d5ab4e2 les agradesco su atencion, en la imagen dejo subrayado el dispositivo que quiero desactivar, gracias
  • Avatar
    Marco (Pix4D)
    Hola Juan,
    He desactivado su dispositivo.
    Disculpe las molestias.
    Para su información, si desea poder desactivarlo de forma remota, debe habilitarlo aquí:
    Y luego cierre la sesión de todos los dispositivos activados para la licencia que está usando. A continuación, podrá cerrar la sesión de un dispositivo de forma remota.
    Espero que esto ayude.
    Saludos
  • Israel Canino
    Hi I lost my ipad with my parrotfields app, how cann I remotely log out from it? I didn´t have enabled the remotely log out option, what can I do?
  • Kapil (Pix4D)
    Hello,
    I have already deactivated the device remotely. You should be able to use it on the new device.
    Regards
  • Rob De Roo
    When I deactivate a device remotely. It is gone in the licence manager list.
    But when I start pix4d on this device, it does not request a login. It just starts like nothing happend and it pops back up in the license manager. Even if I change the password in the meantime.
    Is there a way that we can make them login again, as this is helpfull to keep overview on which of our students is using it.
    Best regards,
    Steven
  • Avatar
    Beata (Pix4D)
    Hi Rob,
    Could you tell me how did you install your Pix4Dmapper, Educational Classroom license? Did you follow up with our instruction on Pix4D installation for computer lab?
    Best regards
  • Rob De Roo
    Hi Beata,
    No we did not installed it that way, this is because the students use it on their personal computer to follow the course. But I want to make sure at the end of the course they cannot get acces to the software anymore.
    So what I tried is to deactivate the computer in the list and even change the password, but the software keep starting up without a promp to login.
    Best regards
  • Avatar
    Gaël (Pix4D)
    Hi Rob,
    In order to get personal technical support on the issue you are reporting, I would suggest writing a request here. It will enable us to gather information more easily to troubleshoot the issue you are mentioning.
    Also, would you, for example, give me the name of a device where the deactivation is not working properly?
    Best,
  • Vickey Lin
    Dear Pix4D technical support team
    I got a problem with my account,can you help me  deactivation the two  devices now is using on the account?
  • Fernanda Bosmediano
    Hi Vickey,
    I have manually deactivated the devices associated with your account. There should now be free seats on the license that you can use with another device.
    Please note that you can deactivate your device by yourself from your license management panel page.
    For step by step instructions please see the article: https://support.pix4d.com/hc/en-us/articles/115004974006.
    Best,
  • Luis Sialer
    Hello Support,
    Luis Sialer
    Hi Luis,
    Best,
  • Carlos Santiago Gomez Salazar
    Hola estoy necesitando desactivar una licencia de un computador que se daño la board y la cambie, y ahora el pc tiene un nuevo nombre y el que se daño no existe ya mi licencia es f3ee7864, agradezco la pronta solución
    Gracias..!!
    Hola,
    Acabo de desactivar esa computadora. En caso de cualquier duda o problema, por favor no dudes en contactarnos.
    Estaremos al pendiente.
    Saludos,
    Edited by Fernanda Bosmediano
  • Janusz Grobowski
    Hi,
    please deactivate the selected device from the screen.
