Remote device deactivation - PIX4Dmapper
PIX4Dmapper includes a remote device deactivation feature allowing a device to be deactivated remotely. This feature can be used to deactivate inaccessible devices occupying a seat on the license.
PIX4Dmapper includes a remote device deactivation feature allowing a device to be deactivated remotely. This feature can be used to deactivate inaccessible devices occupying a seat on the license. This feature will come automatically enabled with all new PIX4Dmapper licenses, older licenses will have to enable this feature manually.
How to enable the remote device deactivation option
How to deactivate a device remotely
How to deactivate a device that cannot be deactivated using the remote device deactivation option
New PIX4Dmapper licenses will have the Remote device deactivation option enabled by default. Previously acquired PIX4Dmapper licenses will have to enable this feature manually.
To enable the Remote device deactivation feature:
- Open PIX4Dmapper.
- Log out of PIX4Dmapper from all active devices. For more information see How to log out PIX4Dmapper.
- Go to the Licenses panel.
- Select the organization where your license is located and click Continue.
- In the PIX4Dmapper license, next to the Remote device deactivation, click the checkbox Enabled (the number of active devices should be 0).
- Now launch PIX4Dmapper again.
Once the Remote device deactivation feature is enabled, a device can be deactivated remotely as needed.
To remotely deactivate a computer:
- Identify the PIX4Dmapper license and the seat that needs deactivation.
- In the Active devices section, click Deactivate Device
- (Optional) Contact us if a Pix4D license is occupied by a device that cannot be remotely deactivated or from which logging out is impossible.
Note: The device must connect to the Internet at least once every 30 days, or it will be automatically deactivated. The Device deactivation date refers to the date 30 days after the last connection to the internet. This time shows when the software will request the next login. The Device deactivation date is not related to the validity period of the license.
If the Deactivate device button
does not appear near your device in the Active devices list, and the Device deactivation is set to "Never" (screenshot below), it means that, most likely, the device was still active while the Remote device deactivation option has been enabled. Please log out from this device and enable the remote deactivation option again.
If access to the device is not available, the support team can manually deactivate it from the license. A support ticket should be opened here, ensuring that device deactivation is selected as the topic/product.
Important: After you get the device deactivated by the support team, please enable the remote device deactivation option. This action can only be done while you have no active device(s), so it is best to enable it before activating any new device. Doing so, it will allow you to remote deactivate a device without the need of asking the support team.
Note: Users without an active Maintenance Plan can still open a support ticket if device deactivation is selected as the topic/product.
