Previous | Next |
First, ensure to have a Pix4D account. If not, create an account following the previous article. Then to redeem a license:
1. In the .pdf LICENSE CERTIFICATE sent by email when purchasing a Pix4D license, click the link under Activation Instructions or go to the license redeem page.
2. Enter the license key in the box below.3. Click Redeem. The license is now associated with the Pix4D account and activated.
If you are switching from a trial license to a paid license you need to log out of desktop application and log back in to activate your license. The license redeem page has nothing to do with it.
Hi,
I did all the processes to remove the Pix4D desktop application and then reinstall, I still have the Error e0709 code, and my trial days are from 10 to 7 now so I would like to solve this as soon as possible ! ( I am in Quebec so I had to change my laptop time in march, I think that is why it's bugging now. Thank for your help !
Hi Dominic Fillion,
Which is the time zone set in your machine? Could you please check that the current time on the machine is not earlier than the last time you used the software. This error can happen if the machine's clock gets set back for whatever reason.
Additionally, please try to uninstall completely (not repair or modify) and reinstall the software following the steps described here:
1. In the Search Windows type, type program and select Add or remove programs in the Settings list.
2. Scroll to find Pix4D Desktop and click the application.
3. Click Uninstall.
4. On the path where Pix4D desktop (Pix4Dmapper) is installed: C:\Program Files\Pix4Dmapper make sure this folder does not exist anymore. If it exists, DELETE this Pix4Dmapper folder.
5. On the following path: C:\Users\pix4d\AppData\Local\pix4d make sure this folder does not exist anymore. If it exists, DELETE this Pix4Dmapper folder.
6. C:\Users\pix4d\Documents\pix4dmapper make sure this folder does not exist anymore. If it exists, DELETE this Pix4Dmapper folder.
7. On windows the search bar type: regedit and then search for the folder stored in the path: HKEY_CURRENT_USER\Software\pix4d and make sure this folder does not exist anymore. If it exists, DELETE this Pix4Dmapper folder.
8. Restart the computer.
Well it seems that there is a time issue with this computer. Maybe you can try with another computer'. For now you have two free seats for your trial license.
Best
Thank you !
It worked this time, I have done all the other steps 3 times before but it was a fail every time. So one thing I have done this time, is that my clock was set manually, because when we had a time change last month I noticed that for the first time (new laptop) the time wasn't updating automaticaly so I had to force it to change, but doing that, the sync was off so I put it back on and reinstall and it's working.
Thank you ! what do you mean ''two free seats'' ?
Hi Dominic, What Marco meant was, the license is floating, it can be used on two devices at one time (You can be logged into two devices and use it simultaneously). This is the case for trial. The monthly license can also be used on two devices. The perpetual license can be used on one device.
Alright !
Thank you
I have a new licence but for some reason it is saying "no valid licence."
Any help?
Hi Daniel, This is because you have a single device desktop license. This does not give access to the cloud. You can reach out to our sales team in case you want to process in cloud.
Hi,
i have Tried to fill my new license but it's still unrecognize... please advise...
Thanks
Hi Pss Assistant
Please contact the Support Team and provide us with the license key. We will help you solve the problem.
Regards
Hello,
The software does not recognize my license code
Hi Saingré Célestin
Please also contact the Support Team and provide us with the license key. We will help you solve the problem.
Regards
need support with license, seems there was an error with payment, have updated but still have no access
-Rosa
Hi Rosa,
I would suggest you to contact Sales here. They will help to process your payment.
Regards,
Hello! Is there a Way to find out if my license is single user or floating?
Hi Axel,
Pix4D license is floating license. You can move your software from one computer to another. For more information, visit Floating license and How to move a Pix4Dmapper license to another computer.
Regards,
Привет
Я пытался заполнить мою новую лицензию, но он по-прежнему непризнанным ... пожалуйста, сообщите...
уменья тоже самое помогите
Hello Xabibulla,
Could you submit a support request from this link and provide more details?
Regards
