Issues with license key or voucher code redemption
If you encounter issues activating a license key or redeeming a voucher code, there are a few common issues to check before proceeding.
This article highlights a few of the most common solutions to aid the license key or voucher code activation process described in this article: License activation.
"Verify the code entered. We cannot find it in our records."
Check if the license key or coupon code has been mistyped
Check if the code is an EMLID code
"This license is already assigned"
Verify if the license is already assigned to your account
Check if the license key or voucher code has not been redeemed by another account of the same company
Note: The process of redeeming a license key has to be done only once and is not related to the device activation.
This message appears when a license key or code that cannot be found in our records is entered.
- Enter the correct license key or coupon code.
- If the code is in the following format
emlidxx-xx-xx-xxxxxxxx
, it means that it refers to a code received by EMLID, and it cannot be redeemed on our redemption page. Please get in touch with our sales team and mention the code in the message.
Verify if the license is already assigned to your organization account
To verify if the license key redemption has already taken place, please follow these steps:
- Open your account page and log in with your Pix4D account.
- Under Your organizations, select the Dashboard of your organization holding the license(s) you want to check.
- On the left sidebar, select Plans and Licenses.
- Select the Licenses tab
- Scroll down until you find your license.
Check if the license key activation has not been redeemed by another account of the same company using a different organization
If the license has been purchased by your company's IT team or finance team, it is possible that the license has been assigned to their Pix4D account organization. Please verify with your IT team (or the team that purchased the license) if the license was assigned to their account or organization. If this is the case, please ask them to invite you to their organization.
Note: In any other case of a technical problem, please contact Support. Remember to mention the license key/redeem code/coupon.
"This voucher has expired"
The expiration date of the voucher has been reached
Vouchers are valid for 3 months. After this time period, these codes expire and cannot be redeemed.
