Software download and installation - PIX4Dmapper
 Previous  |  Next
At any given time there are two versions available to download:
  • PIX4Dmapper: This version is meant for production work.
  • PIX4Dmapper Preview: This version contains the newest features, but is not meant for production work.
Download
To download the software:
  1. Go to the download page.
  2. Download PIX4Dmapper or PIX4Dmapper Preview.
Installation
Once the software has been downloaded, install it using the following steps:
1. Double-click the downloaded file. The PIX4Dmapper Setup wizard starts.
2. (optional) If the pop-up Open file - Security Warning appears, click Run.
3. In the pop-up PIX4Dmapper Setup, in the screen Welcome to the PIX4Dmapper Setup Wizard, click Next.
4. (optional) Click Change... to change the destination path for the installation and click Next.
5. Click Install.
6. (optional) In the software information window: "Do you want to allow this app to make changes to your device?", click Yes.
7. Click Finish.
8. A shortcut is created on your desktop and the software opens automatically once the installation is completed.
9. The first time the software opens, the window PIX4Dmapper Login appears:
10. Type the Email and Password of the account and click Login.
11. Read the End-User License Agreement, select I accept the terms in the License Agreement and click Next.
12. Select one of these options:
12.1 Request PIX4Dmapper now (free trial) to activate a 15-day trial.
12.2 Use Pix4Ddiscovery to activate the limited version.
12.3 Available licenses to select among existing licenses on the account.
13. Click OK.
PIX4Dmapper is now ready for processing.
Language settings
You can change the language settings on PIX4Dmapper at anytime:
1. Start PIX4Dmapper.
2. On the menu bar, click Help > Settings…
3. In the window Settings, select the tab Language.
4. Select the user interface language from the drop-down list.
5. Click OK.
The changes will take effect when the software is restarted.
Update
The most recent PIX4Dmapper and PIX4Dmapper Preview versions are always available for download. Additionally, if a new version of PIX4Dmapper is available, a pop-up Software Update with three options is displayed when the software is opened:
  • Download and Install Now to download and install the latest version available.
  • Remind Me Later to not download or install the latest version. The pop-up will appear again in 10 days.
  • Cancel to not download or install the latest version. No reminder will appear.
License deactivation
Starting from the 4.0 version, a new license management has been implemented, enabling to remotely deactivate a device:
1. Log out of PIX4Dmapper.
2. Go to the License Management panel.
3. Under the license, click Enable now.
4. Log in PIX4Dmapper. This will automatically register the device on the License page.
5. To deactivate the device, go to the License Management panel and next to the device name click Deactivate.
13 out of 21 found this helpful
14 comments
  • Aravindan Arjunan
    pix4d software
  • SEDAGRO NL
    Hi, i have a perpetual license of pix4d desktop, my problem is that the last device user is broken, and it looks like I´m not able to deactivate it. I would like to know if you can support me to fix it, My user account is uise.nuevoleon.gob.mx and the device name that is causing me troubles is LAPTOP-CTEQARN5.
    Thank you
  • Avatar
    Beata (Pix4D)
    Hi,
    I deactivated your device as requested.
    Best regards! ;-)
  • Mohammad Haque
    Hello
    Is there a mechanism to prevent the check and prompting of updates for a lab environment? We don't want the users seeing the upgrade prompt and trying to perform the update.
    Thanks
  • Avatar
    Beata (Pix4D)
    Hi Mohammad,
    Unfortunately, it is not possible; I'll take it as a note and pass it to our teams as a feature request.
    Kind regards,
  • Crojas rojas
    Hola, cuales son los requerimientos para uso en OSX? que osx minimo requiere?
  • Marco Paccagnella
    Hola, Pix4mapper ya no se desarrolla en una version macOS. Tenemos una version de Pix4Dmapper que funciona en macOS (Pix4Dmapper 3) que es bastente antigua y no se soporta oficilamente pero tenemos usuarios que la utllizen. Aqui puedes encontrar toda la informacion: Beta macOS version of Pix4Dmapper 3.0
    Edited by Marco Paccagnella
  • Lyle Morgenthaler
    Hi
    Like Sedagro NL I have a perpetual license I lost the hard drive on the one device and I cannot deactivate it the Device 11471-PC. I have another device but it cannot log into Pix4d due a server communications error to the so I cannot use it or deactivate it either. Device 10417-PC  Can I get them deactivated so I can get another machine working on our project. Thank you
  • Marco Paccagnella
    Hello, I have deactivated the license from both machines. You should be able to use them now. Let us know if you get any issues.
  • Lyle Morgenthaler
    Thank you very much have a great day !
  • Nicolas Bergmann
    Hello!
    I tried to process images from a MicaSense camera with the AgMultispectral function to assemble the orthomosaic, but it throws the following error:
    [Warning]: Warning w9020: GDAL Error <4> Unable to create jpeg file C:/Users/VISTAGUAY/Documents/pix4d/LosC/1_initial/project_data/normalised/IMG_0000_1.jpg.
    [Error]: Failed to write to <C:/Users/VISTAGUAY/Documents/pix4d/LosC/1_initial/project_data/normalised/IMG_0000_1.jpg
    Edited by Nicolas Bergmann
  • Avatar
    Momtanu (Pix4D)
    Hi Nicolas, Can you send the logfile?
  • Julio Cesar Betancourt Guillen
    Hola, trato de instalar pix4d mapper en mi nueva pc porque la anterior se daño, pero no puedo desactivar el equipo anterior. podrían ayudarme?
    Edited by Julio Cesar Betancourt Guillen
  • Marco Paccagnella
    Hola Julio. Ya la he desactivado. Ahora la puedes activar de nuevo.
