Error e0203a: Cannot generate DTM - PIX4Dmapper
Error description: e0203a Cannot generate DTM. This error can be identified in the project log file. This article highlights a few of the most common solutions to correct this error.
Log out of Discovery mode.
If logged in Discovery mode:
    1. Log out from Discovery mode: How to log out from Discovery.
    2. Log in to PIX4Dmapper: How to log in to PIX4Dmapper.
    3. On the welcome screen, select the trial or paid license.
    4. Select Ok.
Confirm that steps 2 and 3 have been processed.
If steps 2 and 3 are shown in red, they need to be processed.
PIX4Dmapper processing tab.
To process the missing steps, follow the instructions on How to process a single step - PIX4Dmapper.
Confirm the correct processing options were selected to generate a DTM.
Check the procedure for generating a DTM in the following support article: How to automatically generate a Digital Terrain Model (DTM) - PIX4Dmapper.
Ensure there is enough RAM for processing.
Please note that for successful processing, especially for datasets with more than 500 images, a minimum of 32 GB RAM is highly recommended.
For more information, System requirements: Minimum and recommended computer specifications.
Note: In any other case of a technical problem, please contact Support.
0 out of 0 found this helpful
