Cannot load old data - PIX4Dfields
PIX4Dfields 2.3.0 and later cannot migrate a database that was last used with a version older than 1.10.0. The message below appears, and PIX4Dfields then closes. Project files remain in the data storage folder.
Error message
"Cannot load old data.
PIX4Dfields reports that data generated with a version older than 1.11.0 cannot be loaded. A version between 1.11.0 and 2.2.0 is required to migrate that database."
After clicking OK, PIX4Dfields closes.
When it happens
The message appears when PIX4Dfields 2.3.0 or later is installed over a database that was never opened in PIX4Dfields 1.11.0 through 2.2.0.
A database already opened in PIX4Dfields 1.11, 1.12, 2.0, 2.1, or 2.2.0 can be opened directly in the latest version.
Solution
- Keep the data storage folder. Do not delete the local PIX4Dfields application data folder.
- Uninstall the current PIX4Dfields version. See How to uninstall PIX4Dfields.
- Install PIX4Dfields 2.2.0. Any version from 1.10.0 through 2.2.0 can migrate the database. 2.2.0 is the latest version that can still do it.
- Open PIX4Dfields and confirm that the existing projects are listed.
- Install the latest PIX4Dfields version: Download softwares
A project saved in PIX4Dfields 2.3.0 or later cannot be opened in PIX4Dfields 2.2.0 or older. PIX4Dfields then shows R0014. See Project created in a newer version - R0014 - PIX4Dfields.
