[2023] Technical release notes - PIX4Dcloud
Note: This article includes the release updates for PIX4Dcloud Starter and PIX4Dcloud Pro (formerly PIX4Dcloud Advanced).
December 7th, 2023 - New 3D maps template
What's new
  • New 3D maps processing pipeline with the following advantages:
    • Vertical coordinate system and geoid model support.
    • Faster processing.
    • Supports larger datasets.
    • Higher quality of point cloud and 3D textured mesh.
Improvements
Changes
November 21st, 2023 - Improvements
Improvements
  • (Only for PIX4Dcloud Advanced users) In the PDF annotations report, it is possible to:
    • Preview and delete an automatic annotation screenshot.
    • Create a new screenshot manually.
    • Screenshots of inspections are now included in the PDF report.
  • (Only for PIX4Dcloud Advanced users) Importing overlay in projects processed with a WKT2 file from PIX4Dcatch site localization is now possible.
  • Vertical system and geoid are displayed in the lower left corner in projects coming from PIX4Dcatch.
Bug fixes
  • The markers are now displayed in the screenshot of the PDF Annotations report.
  • The position of the marker on the map is displayed, which was previously not updated when changing the coordinates in the details panel.
September 19th, 2023 - Improvements
What's new
  • Annotations report in PDF format, including all types of annotations. This feature is only available for PIX4Dcloud Advanced.
  • Mission planner:
    • Corridor mission: Create, edit, and delete corridor missions.
      • Ideal for linear mapping.
      • Split big corridors into small sections for an organized data acquisition.
    • Link to PIX4Dcloud projects: link missions to your PIX4Dcloud projects to organize your processing results.
  • Organization Support and user management:
June 29th, 2023 - Improvements
What's new
  • Mission planner:
    • Cut direction setting in grid mission split.
    • Flight time estimation: Indicates the estimated total flight time of the mission.
    • Split missions by time: grid missions can now be split based on flight time.
    • Updated mission summary panel: better visibility of the different values.
    • Improved user interface: multiple improvements.
Improvements
  • DXF is now included in the take screenshot feature.
  • Timeline improvements:
    • Clustering for dates that are closer together.
    • Zooming in up to minutes.
  • IFC can be deleted from the hierarchy.
May 16th, 2023 - Export annotations in DXF
What's new
May 4th, 2023 - Mission planner feature
What's new
  • Access to Mission Planner. A web-based application that allows drone flight planning. It can be accessed from PIX4Dcloud and synchronized with the PIX4Dcapture PRO for mission execution.
    • Main features:
      • Plan management: create, edit, and delete flight plans.
      • Mission management: create, edit, and delete missions.
      • Mission types: Grid, Cylinder, and Orbit missions.
      • Import flight plans from external files: import CSV and KML files to create custom missions.
      • Mission split: automatically divide big missions into smaller ones to better organize your data acquisition for extensive areas.
      • Synchronization with PIX4Dcapture PRO app: access your plans and missions from PIX4Dcapture PRO to execute them in the field.
    • Support documentation: Mission Planner - PIX4Dcapture pro.
Improvements
  • New user account login page.
March 9th, 2023 - Display DXF Design Overlay in 3D
What's new
Improvements
  • Available Focus on feature for point cloud, 3D mesh, IFC, and DXF.
  • The Localization Points layer now displays the correct name of each point in projects uploaded and processed with PIX4Dcatch using a custom coordinate system.
January 26th, 2023 - Improvements
What's new
  • Projects processed from PIX4Dcloud User Interface are using PIX4Dmapper version 4.8.3.
Improvements
  • Projects uploaded and processed with PIX4Dcatch using a custom coordinate system show the ortho and DSM with the Mapbox background.
  • DXF files can be organized by groups inside the Design Overlay layer.
