English
  • 検索欄が空のため、提案はありません。
PIX4Dcloud に共有PIX4Dcloud PIX4Dmatic
This is a feature that makes it easy to share a project or part of one with just a web link. The depth, dense, and fused point cloud, Mesh, DSM, Orthomosaic and Layers can be uploaded to PIX4Dcloud when logged in with a valid PIX4Dmatic license.
All outputs will be stored in PIX4Dcloud, with shareable URL links that can be obtained during and after the upload.
PIX4Dcloud への共有に関するPIX4Dcloud
  • This feature is available for PIX4Dmatic version 1.36.0 or above. A valid PIX4Dmatic license is required, such as a trial, monthly, yearly, and One-Time Charge (OTC) license with active Support and Upgrade (S&U).
For users with a PIX4Dcloud license, the limits are determined by the PIX4Dcloud license/subscription type, and the Storage expiration policy:
Note: Uploading data from PIX4Dmatic to PIX4Dcloud using the "Share to PIX4Dcloud" feature requires having either the Owner, Manager or Editor role within the Organization.
For information on how to manage roles within an organization, refer to the following articles: Organization management and FAQ - Organization management
「PIX4PIX4Dcloudに共有」の使い方
PIX4Dcloudにアップロードして共有するには:
  • ~より ファイル menu select the PIX4Dcloudに共有... option or click on the PIX4Dcloud ボタン pix4dcloud_button, found at the top-right corner of the PIX4Dmatic window.
Note: The Share to Cloud feature will be disabled when the project consists of images only.
  • Select the project where the dataset will be shared.
  • Select the outputs for upload to PIX4Dcloud. The outputs that are available for upload are Images, Depth point cloud (for LiDAR PIX4Dcatch projects only), Dense point cloud, Depth & dense fusion (for LiDAR PIX4Dcatch projects only), Mesh, Digital surface model DSM, Orthomosaic, and Layers (geometries).
    cloud_share
Note: starting from version 1.80, meshes can be loaded in OBJ format, enabling direct download from PIX4Dcloud.
  • If the project has already been uploaded to PIX4Dcloud, the View project in PIX4Dcloud option will be enabled, allowing you to access the project directly in the cloud.
    view_1.81
Point cloud file format and Share to PIX4Dcloud
バージョン1.67.0より、PIX4Dmatic 点群の新しい形式(gLTF)PIX4Dmatic 。これにより、大規模PIX4Dcloud へ共有」機能をより簡単に利用できるようになりました。
  • For projects created using an older version, a warning message is displayed to convert the point cloud to the new format before using the Share to PIX4Dcloud.
Convert older point cloud to newer format
点群を変換するには:
  • 処理」パネルに移動します
  • 点群の変換」ステップを確認してください。
  • スタート」をクリックします
Processing options for converting point cloud
Important: All the point clouds in a project are merged into a single point cloud for the upload. The newly uploaded point cloud will always replace the previous one. The number of uploaded projects and the total number of projects that can be uploaded to PIX4Dcloud are displayed at the top of the Share to PIX4Dcloud dialog window.
Tip: The upload of geometries (Markers, Polylines, and Polygons) attached to Layers is available from the 1.67.0 version of PIX4Dmatic or newer versions.
注記:
  • 以下の条件を満たす場合、アップロードするたびに新しいPIX4Dcloud が作成されます:
    • The project was never uploaded before.
    • このプロジェクトの座標系が変更されました。
    • クラウド上のプロジェクトが消去されました。
  • Each project can contain a single-point cloud. If a PIX4Dmatic file contains two or more point clouds, one of them has to be selected to be uploaded with Share to PIX4Dcloud.
  • The link between PIX4Dmatic and PIX4Dcloud is unidirectional. Changes in PIX4Dcloud will not be reflected in the PIX4Dmatic project.
  • Both the 2D and 3D views are available for projects uploaded from PIX4Dmatic.
  • ユーザーがPIX4Dcloud ライセンスを所有していない限り、PIX4Dcloud の機能は利用できません。
  • Uploading PIX4Dmatic outputs does not consume PIX4Dcloud credits.
