English
  • 検索欄が空のため、提案はありません。
等高線 -PIX4Dsurvey
The Contour lines feature connects points of the same height with a polyline. The height values are extracted from the TIN (Triangular Irregular Network). Major and minor contour lines which are projected also onto the images are generated with this feature.
アクセス:
  • 画面右上の プロセス Pix4Dsurvey process icon あるいは、
  • On the Menu bar, click Process > Contour lines.
Note: To generate contour lines the TIN needs to be generated in the project.
以下の設定を変更できます:
  • Interval [units]: It defines the contour line elevation interval. It can be in meters or in imperial according to the coordinate system used:
    • 1 m - 既定値。
    • 3フィート(米国) - デフォルト。
Tip: The minimum interval value supported is 0.1. Values below this threshold are not valid and will not be accepted.
  • Discard contour loops shorter than [units]: It detects and discards contour lines with shorter length. It can be in meters or in imperial according to the coordinate system used:
    • 10 m - 既定値。
    • 30フィート(米国) - デフォルト。
Starting with PIX4Dsurvey 1.82.0, contour lines in the 3D view display labels indicating their elevation.
 labels_contour_1.83
Example: Contour lines generated from terrain points of the PIX4Dsurvey example dataset.
