English
  • 検索欄が空のため、提案はありません。
GCPレイヤー -PIX4Dcloud
The GCPs layer in PIX4Dcloud Pro provides a visual, qualitative overview of a project’s georeferencing accuracy. By displaying Ground Control Points (GCPs) and Check Points directly in the 2D/3D view, it allows users to quickly assess alignment quality. For detailed accuracy analysis, it is recommended to consult the AutoGCP report and the project Quality Report.
Licenses: This article is only valid for PIX4Dcloud Pro licenses.
Roles: Only Owners, Managers, Editors, and Readers can view the GCPs layer in a dataset in PIX4Dcloud.
Accessing the GCPs Layer
The GCPs layer is available only for PIX4Dcloud Pro projects where Ground Control Points have been detected using the AutoGCPs detection functionality.
To access the layer:
  • Open the dataset in the 2D or 3D view.
  • In the left panel, expand Layers.
  • The GCPs layer appears in the list when AutoGCPs detection has successfully identified control points.
Content of the GCPs Layer
The GCPs layer includes the following elements:
  • Ground Control Points (GCPs):
    Points detected and marked by the AutoGCPs functionality. These are displayed in    purple.3d_gcp.jpg
  • Check Points:
    Points detected and marked by the AutoGCPs functionality for independent accuracy validation. These are displayed in yellow. check_point.jpg
Warnings and Notes
警告:
  • If the AutoGCPs detection fails and no points are found, the GCPs layer is not displayed.
  • If AutoGCPs detection does not identify all control points specified by the user, the GCPs layer is still displayed with the detected points only. For more details, see Detection of the GCPs failed.
Note: When a project is shared, the GCPs layer—if present—remains visible through the shared URL, allowing viewers to assess GCP and Check Point placement.
