English
  • 検索欄が空のため、提案はありません。
技術リリースノート -PIX4Dcloud
関連記事:
February 16th, 2026 - SLPK projection support for ArcGIS Online
What's new:
  • ArcGIS Online integration now supports projecting SLPK 3D textured meshes to WKID: 3857 - Web Mercator, allowing proper alignment with ArcGIS Online’s default global scene basemaps.
February 13th, 2026 - Support for new server cluster (Switzerland)
What's new:
Bug fixes:
  • Fixed the issue where DXF design overlay layers could be reordered in the web UI’s 2D/3D editor layers list.
  • Fixed the issue where it was not possible to open or download individual images with the web UI.
January 21st, 2026 - Support for new server clusters
What's new:
改善点:
  • More comprehensive and clearly defined 2D background maps.
Bug fixes:
  • Fixed the issue where the Transfer to ArcGIS Online integration sometimes failed to transfer especially large files.
  • Fixed the issue where the point cloud sometimes flickered or reloaded in the 3D compare mode.
  • Fixed the issue where the web UI’s 3D editor sometimes rendered Autotags in front of Gaussian splats.
  • Fixed the issue where the web UI’s 2D editor sometimes displayed triangle-shaped artifacts while rendering orthomosaics.
January 16th, 2026 - Enhanced 3D Editing, Seamless Credit Processing, and Improved Layer Alignment
改善点:
  • The web UI’s 3D editor does not render points that were disabled and then uploaded with PIX4Dmatic.
Bug fixes:
  • Fixed the issue where annotations created with PIX4Dcatch while collecting a dataset were not consistently aligned with other layers.
  • Fixed the issue where some orthomosaic GeoTIFFS could not be downloaded during the retention period.
  • Fixed the issue where processing would not start automatically after buying credits.
  • Fixed the issue where PIX4Dcloud Pro Professor license owners could not access Pro features.
