English
  • 検索欄が空のため、提案はありません。
PIX4Dcloudで標高プロファイルを作成する方法
This article explains how to generate, visualize, measure, and export an elevation profile in a PIX4Dcloud project. The elevation profile allows users to analyze height variations along a line or polyline based on elevation data derived from a Digital Surface Model (DSM).
ライセンス:この機能は、PIX4Dcloud およびPIX4Dcloud のライセンスで利用可能です。
Roles: Only OwnersManagers, and Editors can generate an elevationn profile in a dataset.
要件
The Elevation Profile feature is available when one of the following conditions is met:
  • The project is processed in PIX4Dcloud, is georeferenced, and includes a DSM.
  • A DSM has been uploaded to PIX4Dcloud and is georeferenced.
To visualize the elevation profile in the 3D view, at least one of the following outputs must also be available:
  • Point Cloud
  • 3Dテクスチャ付きメッシュ
Generate an Elevation Profile
Video: The following video tutorial explains step by step how to generate an elevation profile from a polyline in PIX4Dcloud.
To generate an elevation profile:
  1. Open an existing PIX4Dcloud project.
  2. Select the 2D or 3D view. The 3D view is recommended to ensure accurate selection of the start and end points.
  3. Add a distance measurement:
    • click ic_line_black.png または
    • add an item to the Annotations layer by clicking add.png when hovering it and select 距離や標高を測定する.
  4. Draw a (poly)line. Double-click to end it.
  5. On the right, on the details panel, click Generate elevation profile.
If the elevation profile does not load, refer to the troubleshooting article: Output is not displayed / feature is missing on PIX4Dcloud.
Measure on an Elevation profile
Once generated, the elevation profile is displayed in the bottom panel.
  • Move the mouse along the curve to display the elevation value and its corresponding position on the map or model.
  • Zoom in on the curve for higher measurement precision.
  • Click Reset Zoom in the Elevation Profile panel to return to the default view.
Axis description:
The elevation values are computed from the DSM at each pixel intersected by the polyline. By default, the sampling resolution corresponds to the project’s Ground Sampling Distance (GSD).
Export an Elevation profile
To export the elevation profile:
  2. The elevation profile is exported as a CSV file, containing all 3D points along the profile, and saved locally.
The exported CSV file includes the following columns:
  • X, Y: Horizontal coordinates in the output coordinate system or the coordinate system detected in the uploaded DSM.
  • Z: Vertical coordinate in the vertical output coordinate system or the one detected in the DSM, expressed in meters or feet depending on account preferences.
  • Distance: Ground distance from the origin of the profile, expressed in meters or feet depending on account preferences.
