English
  • 検索欄が空のため、提案はありません。
新しいデータセット > GCPの自動化 > GCP/チェックポイントを使用しない処理 -PIX4Dcloud
Create a new dataset to start processing imagery and create maps and digital twins of the reality or upload outputs to PIX4Dcloud.
Access: To start processing a dataset, navigate to step 5 of the project wizard.
Licenses: This article is only valid for PIX4Dcloud Starter and Pro licenses (formerly PIX4Dcloud Advanced).
権限:PIX4Dcloud では、オーナー、マネージャー、およびエディターのみがデータセットの作成および編集を行うことができます。
1.Dataset creation     > 2. Image selection  > 3.Output coordinate system                        > 4.Processing options           > 5. GCPs automation
Processing with GCPs/checkpoint            / Processing without GCPs/checkpoints
To process a project without GCPs:
  1. Click Skip and process.
The project starts processing to finalize the dataset creation. The upload of the inputs to the server is started.
Information:
  • Once the dataset begins processing, it is no longer possible to add more images or make changes to the processing options.
  • If changes to the processing options are necessary after the dataset has already begun processing, a new project must be created and processed from scratch.
  • If a user is unsure whether all images will be uploaded to the project (due to internet connection issues) or believes more will be necessary, Pix4D recommends disabling the "Start Processing Automatically" option. This will allow more images to be manually added before beginning dataset processing.
