  • 検索フィールドが空のため、提案はありません。
How to export prescriptions for TopXGun agricultural drones - PIX4Dfields
The following article describes exporting spot spraying and variable rate prescriptions using the PIX4Dfields Targeted Operation feature.
Introduction
The TopXGun agricultural drones support different file types and prescription maps, depending on the mission.
When exporting Targeted Operations to the TopXGun, there are two available formats:
  • Go to Export, Operations.
  • Select the Operation to be exported.
  • Select TopXGun:
    • TopXGun Boundary Mission: it is useful for exporting a field's boundaries or in specific cases where spot spraying is feasible.
    • TopXGun VRA Format: suitable for most applications, it allows exporting a Variable Rate Application (VRA) map.
Note: before using PIX4Dfields files, please verify that the following requirements are met:
PIX4Dfields 2.10:
  • TopXGun app version is 8.6.5 or above.
  • TopXGun aircraft firmware version is 15.05.12 or above.
PIX4Dfields 2.11 and above:
  • TopXGun app version is 8.8.4 or above.
Exporting TopXGun boundary mission
Exporting boundaries is useful for determining the area extent of a mission and applying a fixed rate to it.
If this option is unavailable in PIX4Dfields, exporting it as a TopXGun VRA mission might be the best solution. For more information: Disabled TopXGun boundary mission - PIX4Dfields.
Each boundary exported will result in a single flight mission on the remote controller:
  • Exporting field boundaries: please follow How to export field boundaries for TopXGun in PIX4Dfields.
  • Spot spraying (limited): When application areas are large and distinct, spot spraying is also possible with this export format.
    • In this case, the application map is ready using the Targeted Operation feature.
      Flying over the violet zone requires applying 10 liters of growth regulator.
      ExportAsTopXGun Boundary mission
    • It will export one folder called "TopxGun" with a shapefile inside.
      Each area inside the prescription map will be differentiated when imported into the RC controller:     WhatsApp Image 2024-09-03 at 14.21.35
When should I use the Boundary mission?
Boundary missions are recommended when a single application rate is used or when distinct treatment areas exceed 3 hectares. These boundaries can be directly exported for operational use.
Exporting Variable Rate Application (VRA) format
In this case, using the Targeted Operation feature, a weed application map was created after detecting the Sorghum infestation in Peanuts using the Magic Tool.
Total boundary area that the drone will fly: 15 hectares.
Total area to be sprayed: 0.96 hectares.
Set the proper rate to be applied. Editing on the remote controller is not possible.
Example operation
Reducing Total Flying Area
Before exporting the prescription map to the controller, you can manually create a new boundary to shrink the area and reduce flying over non-application zones.
  1. Click on the Operation layer on the left.
  2. Click on the Boundary icon.
    Steps 1 and 2 on the software
  3. Draw the new boundary, reducing the extent.reducingBoundary
  4. Click on the previous Boundary and delete it  delete.
  5. The total area was reduced by 20%, from 15 to 12 hectares.reducing Boundary of all the field
  6. Creating multiple boundaries can also be beneficial, as each boundary will correspond to a separate flight when planning the application on the remote controller:
    multiple boundaries covering application area
  7. VRA map imported into remote controller. Each boundary is converted into a flight plan:
    Drone controller image showing VRA map
 Export the final prescription map:
  • Select TopXGun, TopXGun VRA mission.
  • Set the Flight height, which is recommended between 1.5 and 3 meters, and the Spraying width, which should be around 5 meters.
  • It will export a "TopXGun" folder with two sub-folders:
    • Shapefile:
       It will contain a shapefile with the boundary of the mission.
    • Rx:
      It will contain a .tiff file with different rates following each operation (zone).
When should I use the Variable rate missions?
  • TopXGun VRA missions should be used when multiple rates are applied or when complex spot spraying missions are performed.
  • The downside is that the boundary should be edited when doing Spot Spraying, to reduce flying over the non-application areas.
Import map into TopXGun controller
After exporting the desired format from PIX4Dfields:
  • Copy-paste it into the SD card.
  • Remove the SD card from the laptop and insert it into the the controller. Then, power on the controller.
  • Click on the SD Card icon.
  • Select the proper boundary under Import files and click Confirm:
    SelectingBoundary
  • For a VRA application, change the selector to Prescription Map and select the file.
     SelectingVRA
  • The Prescription Map Import Options menu will appear:
  • ImportingVRA
    • Select the Area unit: ha, no matter the units being used.
    • Set the Resample option:
      • Max Value: this will apply the max rate when the drone passes over two cells.
      • Average Value: this will apply the average rate when the drone passes over two cells.
Load the prescription to the field
Once the Boundary and Prescription are imported, the VRA must be assigned to the field.
  • Access the boundary field and click the Rx icon to assign the Prescription.
    ToxGun_ClickRxIcon
  • Select the Prescription from the menu
  • Click Use
       VRAandFlightSettings
  • Set desired flight parameters, load desired product, and hit Start. Safe flights!
Please watch the complete workflow on this video:
Tip: The following video explains step-by-step how to use PIX4Dfields to generate maps for spot spraying applications:
