Setup Failed: How to upgrade to PIX4Dmatic 2.3 or newer from an older version on Windows
Error Description
When a PIX4Dmatic version 2.2 (or older) is already installed on a Windows computer, the installation of PIX4Dmatic version 2.3 (or newer) leads to a "Setup failed" error.
Solution
To solve this problem, it is necessary to first uninstall the older PIX4Dmatic version (2.2 or older) and then install the newer PIX4Dmatic version.
Uninstall PIX4Dmatic
In the Windows Search, type Add or remove programs.
Scroll to find PIX4Dmatic and click the three dots and then uninstall.
- Click Uninstall.
- If a pop-up appears asking Do you want to allow this app to make changes to your device? click Yes.
- Install PIX4Dmatic 2.3 (or newer) by double-clicking on the .exe file.
Info: If, after uninstalling PIX4Dmatic 2.2 (or older), you still get a Setup Failed error when installing PIX4Dmatic 2.3 (or newer), it might be necessary to completely uninstall PIX4Dmatic 2.2 (or older). You can find a step-by-step guide here: How to completely uninstall PIX4Dmatic (Windows).
