  • 検索フィールドが空のため、提案はありません。
Selection tools - PIX4Dmatic
PIX4Dmatic provides selection tools for selecting and working with different elements within a project
Selection tools in PIX4Dmatic
The following selection and vectorization tools (+Keyboard shortcut) are available in PIX4Dmatic:
  • Simple selectorSimple selection (S)
  • Rectangle selectorRectangle selection (R)
  • Polygon selectorPolygon selection (J)
  • Object selectorObject selection (Y)
  • Color selectorColor selection (Shift+C)
  • 5661162608797 Road selection (Shift + A)
How to use selection and vectorization tools in PIX4Dmatic
Selection tools specifics:
  • Simple selection (default): Click on the object to select it.
  • Rectangle selection: Click on the first point and move to the second point to define the rectangle. All the objects, point clouds, and geometries, inside the rectangle, will be selected
    4402466036625
  • Polygon selection: Click as many points as needed to define the selection area.
  • Object selection: Click on the desired entity, and the point cloud related to this entity will be selected. For further information, read this article.
    Object selection
Note: With the selection tools, it is possible to select only specific entities by enabling the select only option.
  • Color selection: Pick a color, and then similar colors within the given tolerance and radius will be selected.
    Color selection
  • Road selection. Select a point and, depending on the color and tolerance, select all the points that apply.
    road_2.0
How to edit selection results in PIX4Dmatic
  • Simple selection: Click on a different element to change the selection.
  • Rectangle selection: Once the rectangle selection is confirmed, it cannot be altered.
  • Polygon selection:  Once the polygon selection is confirmed, it cannot be altered.
  • Object selection: Click on a different entity to change the selection.
  • Color selection: Only one selection per click. It is not possible to add a new color to the selection.
  • Road selection. Only one selection per click. It is not possible to add a new color to the selection.
    Tip: By using rectangle, polygon, and object selection, it is possible to add points to an existing selection by pressing the Shift key and creating a new selection.
    It is also possible to remove points from an existing selection by pressing the Alt key (Windows) or Option key (macOS) when creating a new selection.
