  • 検索フィールドが空のため、提案はありません。
How to process Sentera Double4K in PIX4Dfields
The Sentera Double4K (D4K) camera has several versions:
  • Double 4K Ag+ (RGB and NDVI multispectral imagery).
  • Double 4K Analytics (Zoom RGB and NDVI multispectral imagery).
  • Double 4K Multispectral (5-band multispectral mapping).
  • Double 4K NDVI/NDRE.
All band combinations can be processed directly in PIX4Dfields. It is not recommended to use the Sentera pre-processing pipeline.
As the camera captures two types of images, they should be processed separately in PIX4Dfields.
In order to process the images:
  1. Create a new project, import only ONE folder (RGB, NDVI, or NDRE)
  2. Click process.
  3. After processing the first folder of images, go to Import
  4. Select the second folder RGB/RedEdge/NIR images.
Two orthomosaics will be available afterward, depending on the camera used.
