  • 検索フィールドが空のため、提案はありません。
How to export prescriptions for EAVision drones - PIX4Dfields
This article explains how to create EAVision prescription files that precisely define the treatment area, outline obstacles, and establish rates for zones.
Introduction
EAVision supports the import of prescription files created with PIX4Dfields, which precisely define the treatment area, assign rate to zones and outline obstacles.
This enhances operational safety and efficiency by ensuring that the application is limited to the intended areas, while avoiding obstacles and restricted regions. A single fixed rate or variable rates can be applied across the prescribed area, streamlining workflow and minimizing the risk of accidental application outside the defined boundaries.
EAVision spraying drones support two types of missions:
  • EAVision Boundary mission:
    • It allows the definition of the field area to be sprayed along with obstacles and no-spraying zones. It only supports one fixed rate.
    • Exported file: KML.
  • EAVision VRA mission:
    • It allows a variable rate to be applied to the field area to be sprayed, along with obstacle and no-spraying zones. It supports up to seven different application rates.
    • Exported files: KML and JSON.
Creating a Targeted Operation
Targeted operations enable users to mark obstacles and variable rate zones directly on the operational map. These zones can be delineated on an orthomosaic generated from drone images.
    EAVision_Operation-1
    Exporting for EAVision Boundary mission
    To export the Targeted Operation to EAVision drones:
      • Go to the Export menu.
      • Click Operations.
      • Select the Operation to be exported.
      • Select EAVision Boundary mission.
      • Upload the KML to the EAVIsion platform.
    Uploading boundary mission to the EAVision platform
    1. Log in
      Navigate to https://web.eavtechus.com/mapCloud/#/login and log in with the account credentials.
      EAVISIon_PlatformLOgin-1
    2. Open the map page
      After logging in, enter the Map page and click Upload Plots on the toolbar.
      EAVISIon_Platform2_UploadPlot2
      その Upload Plots menu will appear.
    3. Configure upload parameters
      In the upload menu, set the required parameters such as project name, demand, and associated team.
      Then, click Select File to choose the KML file exported from PIX4Dfields.
      EAVISIon_Platform3_Configure-1
    4. Confirm and upload
      Review your settings and click OK.
      Once the upload is complete, the system will display a message indicating the upload result.
    5. Verify the imported file
      Return to the map view and verify that the plot boundaries (blue),  obstacles (in red), and no-spray zones (in yellow) are displayed correctly.
      EAVISIon_Platform4_CheckResult-1
    Exporting EAVision VRA mission
    To export the Targeted Operations as EAVision VRA mission:
      • Click Operations.
      • Select EAVision VRA mission.
        EAVISION VRA
      • Upload the files to the EAVIsion platform.
