How to export prescriptions for ABZ spraying drones - PIX4Dfields
Introduction
The ABZ exports are compatible with the L & S series. To export the Targeted Operations to ABZ drones:
- Go to Export, Operations.
- Select the Operation to be exported.
- Select ABZ innovation ( L & S series).
- After selecting the brand, the prescription map is automatically upsampled to an 8 m cell size, as required by the drone.
- Adjust rate or cell size if needed.
- Click Export.
- Select the destination folder and click Select folder.
- Boundary: it contains the mission boundary limits. It is useful for exporting a field’s boundaries or for specific cases where spot spraying is feasible.
- Rx: it contains the prescription itself. It is suitable for most applications, and it allows the Variable Rate Application.
Import the map into the controller
After exporting the desired format from PIX4Dfields:
- Copy and paste the folder onto the micro SD card.
- Remove the SD card from the laptop and insert it into the controller. Then, power on the controller and import the files.
