  • 検索フィールドが空のため、提案はありません。
How to export prescriptions for ABZ spraying drones - PIX4Dfields
Introduction
The ABZ exports are compatible with the L & S series. To export the Targeted Operations to ABZ drones:
  • Go to Export, Operations.
  • Select the Operation to be exported.
  • Select ABZ innovation ( L & S series).
    • After selecting the brand, the prescription map is automatically upsampled to an 8 m cell size, as required by the drone.
    • Adjust rate or cell size if needed.
    • Click Export.
  • Select the destination folder and click Select folder.
Two folders will be created:
    • Boundary: it contains the mission boundary limits. It is useful for exporting a field’s boundaries or for specific cases where spot spraying is feasible.
    • Rx: it contains the prescription itself. It is suitable for most applications, and it allows the Variable Rate Application.
Import the map into the controller
After exporting the desired format from PIX4Dfields:
  • Copy and paste the folder onto the micro SD card.
  • Remove the SD card from the laptop and insert it into the controller. Then, power on the controller and import the files.
