  • 検索フィールドが空のため、提案はありません。
How to export, back up, and manage projects - PIX4Dreact
This article explains how to export and import PIX4Dreact projects. This process is particularly important, as the data can consume a significant amount of physical storage space.
Where are projects stored?
Projects are saved/stored in the Data Storage Folder.
To access it:
1- Go to Settings on the top-right:
2- Click on the Data storage folder:
  • All projects and files generated will be stored in this folder. Several file types will be present
  • To modify the storage location of your projects, select a different folder in the Data storage folder settings. Changing your data storage folder will not move existing projects to the new location.
  • To move projects, please read: Batch export PIX4Dreact projects (.p4z)
The default project storage locations are:
For Windows: C:\Users\USERNAME\Pix4Dreact
For Mac: Users/USERNAME/Pix4Dreact/Data
Export a single PIX4Dreact project (.p4f)
Tip: This method describes exporting a single project. When moving multiple projects, the Export Projects feature is recommended.
  1. Open a project.
  2. Click on Export.
  3. Click on Project.
  4. Select the folder where to save the project> click Select folder.
  5. Inside the selected folder (root folder) there will be 3 files:
    • Data folder
    • Pix4Dreact project file (.p4r)
Tip: To share a PIX4Dreact project and open it on another device, share the root folder as a .zip file. See the video below.
Import a single PIX4Dreactproject (.p4f)
The data folder, .p4r, and snapshot.png are required to import a PIX4Dreact project.
Important: Collaborators need to own a PIX4Dreact license to be able to import a project.
    1. Download the folder that contains the .p4r file.
    2. Log in to PIX4Dreact
    3. Close PIX4Dreact (stayed login)
    4. Double-click on the .p4r file
    5. A message Confirm to import project appears, click Continue
    6. The project is ready to use in the new device.
Batch export of PIX4Dreact projects (.p4z) - 🆕
Using the Export projects feature is recommended when moving multiple projects at a time or backing up.
An additional feature of the batch export aimed at advanced users is not exporting the files stored in the Data Storage Folder (which contains large files and images). With this option, only the project structure is exported, and the user is required to move the content of the Data Storage Folder manually, making the export operation very fast. For details, see below.
To access the feature:
  1. Click the Settings icon at the top right of the home screen.
  2. Click Export projects
    ExportImport_BatchProcess
  3. The Export projects menu appears.
  4. All projects will be selected by default.
    1. Order projects by clicking on the column name. You can order by Name, Size, or Created/Modified dates.
      Ordering by Size is recommended to know which projects occupy the most space.
      ExportMenu_WithSizeOrder
  5. Click Export project(s).
    1. Ensure sufficient disk space before exporting, otherwise Error 0175 will occur.
      “Unable to detect sufficient disk space.
       R0175: Caution, the selected folder may not have sufficient disk space, projects may fail to export correctly”
  6. Each selected project will be exported as a single .p4z file
  7. The exported files can be opened in any
Batch import of PIX4Dreact projects (.p4z) - 🆕
To import projects:
  2. Click Import projects
  3. Select one or multiple .p4z files to import.
  4. Click Open.
Delete a PIX4Dreact project
To delete PIX4Dreactprojects:
  1. Go to the Dashboard.
  2. Click on the project settings.
  3. Click the Delete icon at the bottom.
    2025-01-14_12-29-22
Share outputs using PIX4Dcloud
With a PIX4Dreact license, uploading outputs to PIX4Dcloud directly is possible. For more information: Share to PIX4Dcloud - PIX4Dreact
Important: Collaborators do not need to own a PIX4D license to be able to access the shared links.
Export outputs to use them in third-party software
PIX4Dreact generates outputs that can be exported for use outside the software. See PIX4Dreact outputs and their formats here: PIX4Dreact inputs and outputs.
Warning: The export functionality is available only for commercial licenses. During the trial period, the results of PIX4Dfields cannot be exported. For more information about commercial licenses, contact our sales team here.
