  • 検索フィールドが空のため、提案はありません。
Feature per license - PIX4Dmatic
FEATURE Discovery
(no license)
PIX4Dmatic Analyst PIX4DmaticStandard PIX4Dmatic Pro
Welcome view
Open old PIX4Dmatic projects
Import PIX4Dsurvey projects
Import PIX4Dmapper projects
Import OPF
File menu
New project
Open project
Merge project
Open project folder
Open project export folder
Save
Save copy
 File -> Import
- Images
- Images from folder
- Image geolocation and orientation
- GCPs
- Marks
- Region of Interest
- Point clouds
- Geometries
- OPF project
- PIX4Dmapper projects
Volume base surface as LandXML
Animation trajectory
Drag and drop imports
Importing images to an existing project
- Point clouds
- Geometries
- OPF project
Selection tools
Simple selection
Rectangle selection
Polygon selection
Color selection
Object selection (AI)
Road selection
Vectorization tools
Marker
Polyline
Polygon
Polygon hole
Circle
Arc
Catenary
Road detection
Roof detection
Wall detection
Measurement tools
Distances
Volumes
Stockpile detection
Scale constraint
Orientation constraint
Region of Interest (ROI)
Region of interest (ROI)
Import/export ROI
Sections & orthos
Section creation
Orthoplane
Export orthoplane
Export section geometries
Orthomosaic editor
PIX4Dmatic processing
Calibration
Depth
Dense
Depth & dense
Outlier removal
DSM
Orthomosaic
Mesh
AI tools
Export section
- Quality report
- Dense point cloud
- Depth
- Fused
✅(not  for trials)
- Point cloud from mesh
✅ (not for trials)
- Mesh
✅ (not for trials)
- DSM
✅ (not for trials)
- Orthomosaic
✅ (not for trials)
Importing processing template
Exporting processing template
Survey processing
Terrain filter
Grid of points
TIN
Digital Terrain Model (DTM)
Contour lines
Road object detection (AI)
Videos & views
Save views
Create animation
Add logo
Export animation
Import the animation trajectory
Content panel
Display classes Terrain (switch)
Display classes ASPRS (switch)
Add custom classes
Export layers
Export point clouds
Grid actions: change color, rename, delete
Grid actions: export
TIN actions: change color, delete
TIN actions: export
DTM actions: delete
DTM actions: export
Contour lines actions: change color, delete
Contour lines actions: export
Export point clouds with the terrain filter
Importing layer template
Exporting layer template
Cameras panel
Camera internals (open)
Edit externals
Edit internals
Save to database
Load optimized parameters
Import geolocation and orientation
Export geolocation and orientation
Sort cameras
Set image CRS
Imports
Importing Mapper projects
Tie points panel
GCP CRS
Import GCPs
Import marks
Export GCPs
Export MTPs and ITPs
Export marks
Edit GCP data
Edit a tie point name
Convert a tie point into a GCP
Convert a tie point into a checkpoint
Add tie point
Delete all tie points
Remove tie point
Convert tie point to vertex
Remove marks
Merge tie points
Copy WKT
Sort
Reports panel
Summary (stats)
Quality report export
Custom report export
Settings
Camera size
Tie point size
Marker size
Mask size
Point size
Marker label
Mask label
Contour line label
Min nº matches
Color ATPs
Color by elevation
Color by normal
Color by GPS
Face orientation
Clipping box
Snapping window
Distortion aware
Backface culling
Object occlusion
Perspective/orthographic view
Viewport layouts
Background (sky and color)
Preferences
Language
Project handling
Theme
3D viewer background color
2D viewer (basemap)
Email notification
Properties
Software updates toggle
Release notes toggle
Hardware (GPU)
Mesh rendering
Point cloud rendering
Layer templates
Processing template
Network
Offline license
Image viewer
Auto mark
Auto mask
Mark MTP
Mark mITP
Create mask
Center and re-sort
Filter/Sort
Maximize/enlarge
Import images
Hide/show all reprojection marks
Edit ortho patch camera or projection type
Open Photogrammetry Format (OPF)
Import
Export
Overwrite OPF
PIX4Dcloud interactions
Process in PIX4Dcloud
(Valid license of PIX4Dcloud)
Share to PIX4Dcloud
Other
Point cloud registration
History panel
Export undistorted images
Reclaim seat
AutoGCP
Export image base site calibration
Automatic boundary detection
2D/3D interactions
Disable point cloud points
Restore point cloud points
Assign to ASPRS class
Assign to Terrain class
Delete grid points
Delete vertices
Move to layer
Convert polyline<>polygon
Convert polygon<>volume
Convert polyline<>volume
Join/split/continue/offset
Convert to VTP
Drape polyline
Set to planar/non-planar
Create clipping box from selection
Reset clipping box
Flip face
Invert selection
Edit ortho patch (add/move/remove vertex)
