対応ドローンおよびカメラ -PIX4Dmapper
PIX4Dmapper supports all the drones that takes regular RGB images.
Overview
PIX4Dmapper technically supports the processing of RGB images from any drone. The main requirement of the PIX4Dmapper software is that there should be enough image overlap while capturing the images to generate good-quality results.
List of supported cameras:
RGB Cameras
PIX4Dmapper supports processing images from any drone with RGB camera. So, all the drones equipped with RGB cameras are supported.
Multispectral Cameras
PIX4Dmapper is capable of processing data from various multispectral cameras, including but not limited to:
- RedEdge
- Altum
- DJI Multispectral
- MAPIR
For a full list of supported multispectral cameras, please refer to the article titled supported drones and cameras.
Thermal Cameras
PIX4Dmapper supports the processing of thermal data from several thermal cameras, including:
- FLIR cameras
- DJI Zenmuse
- Sensfly
- Micasense Altum
For detailed information regarding the specific thermal cameras supported, visit the section titled "Which thermal cameras are supported by PIX4Dmapper?"
Pix4Dmapper is currently unable to generate a reflectance map with temperature values from certain thermal cameras, such as the Mavic 3T Enterprise, Matrice 30T, Mavic 2 Dual Enterprise Advanced, Zenmuse H20T, and Zenmuse H20N from DJI and Skydio thermal cameras. For more information, click here.
