  • 検索フィールドが空のため、提案はありません。
GPUの使用 -PIX4Dmapper
This article provides information on the GPU's effect on processing speed, the minimum requirement for a GPU, recommended GPU, and how to enable GPU processing in PIX4Dmapper.
Information:
PIX4Dmapper leverages the power of Nvidia GPUs for faster processing.
The speed increase depends highly on the project, the number of images, the image size, and the image content. For example, using a GTX 970, speed up between 10% and 75% on step 1. Initial Processing, and around 10% in step 2. Point Cloud and Mesh were observed. As a rule of thumb, projects with high overlap, high image content, and a high number of key points can be benefited more from the speedup.
Minimum requirements for CUDA speedup
Nvidia GPU (GTX, Mobile, Titan, Quadro) with at least 2GB RAM, supporting CUDA 9.1 with the latest driver installed (starting at least from 343).
Recommended GPU
GTX 750, GTX 970 (around 200-400$), GTX 1060, 1070, 1080 with the latest driver installed.
How to enable GPU processing
If a GPU with CUDA support is automatically detected, it will be used for processing automatically.
The use of the GPU can be enabled or disabled in the Processing Options:
1. In the Menu Bar, click Process > Processing Options...
2. Select Resources and Notifications.
3. In the Maximum Resources Available for Processing section, select or unselect the GPU device.
Important:
