  • 検索フィールドが空のため、提案はありません。
エラー:点群内のブラックホール - 品質レポートのオーバーラップマップ上の緑、オレンジ、黄色の矩形 -PIX4Dmapper
Error
  • Green, orange and yellow patches in the Overlap map in the Quality Report.
  • Black holes (black rectangles or sharp triangles) in the model where no data is generated.
Figure 1. Quality Report
Figure 2. Point Cloud with black rectangles
Description
  • Lower accuracy in the position of the 3D points.
  • Black holes (black rectangles or sharp triangles) in the point clouds.
  • Rectangles in the DSM.
Cause
This issue appears if there is not enough frontal and/or side overlap.
Even if there are enough keypoints found on each image, there might be some areas that can only be seen in 2 images.
The Densified point cloud is generated using the Automatic Tie Points and, by default, only contains keypoints that can be identified in at least 3 images. All outputs depending on the Densified point cloud will be affected.
Solutions
Use keypoints found in 2 images as keypoints for the Point Cloud Densification:
1. In the menu bar, click Process > Options...
2. Select the tab Point Clouds.
3. In the section Minimum Number of Matches, instead of 3, select 2.
4. Click OK.
5. Process step 2 again.
If the problem persists:
Add and mark Manual Tie points on the problematic areas, and process step 1 again. For more information about how to add Manual Tie Points: How to import and mark Manual Tie Points (MTPs)
Fly again using higher frontal and side overlap and process the project again. For more information about the flight plan design: Step 1. Before Starting a Project > 1. Designing the Image Acquisition Plan.
