  • 検索フィールドが空のため、提案はありません。
画像および/または地上制御点(GCP)がマップビュー上で正しく配置されていません -PIX4Dmapper
Error Description: Images and/or GCPs do not lay at the correct position on the 2D Map. When importing in a project, images with geolocation (known coordinates) or GCPs (points with known coordinates) don't show the expected position on the 2D View.
There are two possible causes for this issue:
  • The image and/or GCP input coordinates are not correct.
  • The image and/or GCP selected coordinate system are not correct.
This article highlights a few of the most common solutions to aid the invalid position of the images and GCPs on the 2D View.
Verify if the image and/or GCP input coordinates are not correct.
  1. Check that the coordinates are correct.
  2. Check that the image geolocation file and/or the GCP georeference file have been correctly imported. For more information about the:
Verify if the selected image and/or GCP coordinate system are not correct.
  1. Check that the correct coordinate system has been selected. For more information about the:
Note: Some coordinate systems can appear twice in the database with exactly the same name for the Datum and Coordinate System. One of them might be deprecated which might be the cause of the incorrect position.
To check if a coordinate system is deprecated: http://spatialreference.org/
To obtain or create a .prj coordinate system syntax file: How to obtain or create a .prj coordinate system syntax file.
Note: In any other case of a technical problem, please contact Support.
