rayCloud -PIX4Dmapperにおけるオブジェクトの編集方法
If the position of the projected vertices (green crosses) on the images is not optimal, select the object on the 3D View and correct the position of the vertices:
" appears, indicating that the measurement accuracy cannot be calculated till all the vertices of the Object are marked on at least 2 images.
Using the 3D View (less accurate):
1. In the 3D View, click the vertex to select it.
2. Click the vertex again and drag and drop it to its new position.
Using the right sidebar (more accurate):
2. In the Images section of the right sidebar, zoom in/out of the images to better see the position of the vertex using the scroll wheel of the mouse (moving forwards to zoom in and backwards to zoom out) and pan using the left click of the mouse.
3. Left click to mark the vertex on the images. Mark the vertex on at least 2 images.
- A green cross represents the projection of the corresponding 3D vertex.
- A yellow cross represents the edited/marked vertex in the image.
4. Click Apply.
5. The 3D position of the associated Manual Tie Point is corrected in the 3D View.
