インデックス計算機でカラーインデックスマップを生成する方法 -PIX4Dmapper
Important: Available once step
1. Initial Processing is done and both the
Reflectance Map and the
Index Map have been generated.
Note: The Colored Index Maps are obtained by applying defined coloring rules to the Index Maps.
Warning: If a Colored Index Map already exists for the selected Index, generating the new Colored Index Map will
overwrite the existing one.
In order to generate a Colored Index Map:
1. On the Menu bar, click View > Index Calculator.
2. (Optional) Change the number of Classes or how the Classes are defined. For more information: How to edit the Color Mapping in the Index Calculator.
3. In section 5. Export, click Export for exporting the Colored Index Map to the result folder.
Note:
- The Colored Index Map files will be stored in:
...\project_name\4_index\indices\INDEX_NAME. - For more information about the files that are generated: What are the output files after....
- For information about the project folder structure: Project Folder Structure.
