異なるスペクトル特性(RGB、NIRGBなど)を持つ画像の処理方法 -PIX4Dmapper
Processing images with different spectral signature (RGB, NIRGB, etc) in one project can be useful, for example, in the following cases:
- Generating different orthomosaics (one orthomosaic per dataset) that are perfectly overlaid because they are generated from the same DSM.
- When processing different types of imagery together, all input bands contribute with a specific weight to the keypoint extraction. Thus more 3D points can be extracted than when processing each dataset separately. This leads to a more precise DSM, in turn leading to better orthomosaics.
本記事では
Band configuration - Grouped Images
Images with different EXIF ID detected with correct band information
Images with different EXIF ID detected with incorrect band information
Images with the same EXIF ID detected with incorrect band information
To process images with different band configurations (RGB, NIRGB, etc) verify that:
- The camera model associated to each image has the correct band configuration.
- The images with different band configuration are grouped into one group per band configuration. For more information about groups: Menu Project > Image Properties Editor... > Images Table.
If the resolutions of the two cameras are significantly different:
- Calibration of the images in Step 1. Initial Processing will be improved if the processing options are adapted to each set of images. For this the following merging procedure is recommended: Merging projects.
PIX4Dmapper reads the EXIF data from the images in order to retrieve an EXIF ID that is used to associate each image to a camera model from PIX4Dmapper's database. The following cases can be encountered:
- Images with different EXIF ID detected with correct band information
- Images with different EXIF ID detected with incorrect band information
- Images with the same EXIF ID detected with incorrect band information
1. Create a new project.
2. In the New Project Wizard, add all the images.
3. In the New Project Wizard, in the Image Properties window, verify how many camera models are detected.
4. In the New Project Wizard, in the Image Properties window, examine the band configuration for each camera model: it is written next to the camera model under the section Selected Camera Model (for example: CanonPowerShotG12_6.1_3648x2736 (RGB)).
For step by step instructions about how to create a new project: Step 2. Creating a Project.
1. Create a new project. For step by step instructions about how to create a new project: Step 2. Creating a Project.
2. In the New Project Wizard, add all the images. Images with different EXIF ID that are associated to different camera models with the correct band information are already grouped correctly.
3. Process the project. For more information about how to process a project: Step 4. Processing.
1. In this case, in order to group the images correctly and to set the correct band configuration, follow: How to merge Images with different Spectral Signatures (RGB, NIRGB, etc).
