  • 検索フィールドが空のため、提案はありません。
PIX4Dmapper密生植生地域の出力を改善する方法
Trees, forest and dense vegetation areas have specific properties that require special care. When processing such datasets, different type of issues might occur as described in this article together with recommendations on how to resolve them.
Initial Processing: Low number of calibrated images
PIX4Dmapper relies on visual similarities between overlapping images to reconstruct the model. Trees and dense vegetation, due to their complex geometry (thousands of branches and leaves), often appear very different between overlapping images. Therefore, it is more difficult to find enough similarities between overlapping images and, if the overlap is not enough, it leads to a low number of calibrated images.
To ensure to have a high number of calibrated images it is recommended to:
  • Process with 1/2 Keypoints Image Scale: This processing option can lead to a higher number of calibrated images in case the default option (original keypoint image scale) does not calibrate all the images. For more information: Menu Process > Processing Options... > 1. Initial Processing > General.
  • Increase the overlap between the images to at least 85% frontal overlap and 70% side overlap.
  • Increase the flight altitude: When flying higher, the images suffer less from perspective distortions and it is easier to detect visual similarities between overlapping images in vegetation areas.
For more details about the flight plan: Step 1. Before Starting a Project > 1. Designing the Image Acquisition Plan > a. Selecting the Image Acquisition Plan Type.
Point Cloud Densification: Areas without 3D points generated
Even when all the images are calibrated, it is possible that no additional 3D points are computed at areas with trees and vegetation during step 2. Point Cloud and Mesh. In order to improve the Point Cloud in such areas it is recommended to:
  • Increase the overlap between the images to at least 85% frontal and side overlap.
  • Set the Image Scale option for the Point Cloud to 1/4 or 1/8 if the dataset consists only of vegetation areas. If the dataset has roads or buildings as well, set the Image scale option to 1/2 and use the Multiscale option. For more information: Menu Process > Processing Options... > 2. Point Cloud and Mesh > Point Cloud.
Orthomosaic: Visual deformation and artifacts
The Orthomosaic is generated from the DSM and it suffers from artifacts in areas where the 3D model is not good. As trees have an infinite amount of details (trunk, branches, leaves) they can only be approximately modeled. This approximation creates visual distortions and artifacts when generating the Orthomosaic. In order to remove the distortions it is recommended to:
  • Improve the DSM by:
  • Improve directly the orthomosaic by:
    • Using the Mosaic Editor: Replace areas with distortions by images generated using a planar projection instead of an ortho projection. For more information about how to use the Mosaic Editor: モザイクエディタの使用.
      Important: Planar projections may not preserve distances and should be used only to improve the visual aspect of the orthomosaic and not to generate orthomosaics that will be used for measuring purposes.
