  • 検索フィールドが空のため、提案はありません。
インターネット接続は必要ですか? -PIX4Dmapper
This article explains if and when an internet connection is needed for PIX4Dmapper. An internet connection is always needed when opening and logging in to PIX4Dmapper.
Note: An internet connection is always needed to open PIX4Dmapper and log in. No offline license is offered for this product. If the Remote Device Deactivation feature is enabled, a license check is done after 30 days since the last license check. More information in the article Remote device deactivation - PIX4Dmapper.
Discovery mode does not require internet connection for processing. An internet connection is only required to activate and deactivate your desktop or laptop. You can process projects without an internet connection after your computer is activated.
Monthly and yearly subscriptions, monthly and yearly rentals, or One-Time Charge (OTC) licenses do not require an Internet connection for processing. An internet connection is only required to activate and deactivate your desktop or laptop. You can process projects without an internet connection after your computer is activated.
Trial requires internet connection.
For more information about the license features and discovery mode: PIX4Ddiscovery / Discovery mode.
