  • 検索フィールドが空のため、提案はありません。
メニュー プロセス > 等高線生成 -PIX4Dmapper
This article explains in detail how to generate contour lines for DSM or DTM in PIX4Dmapper.
Access: On the menu bar, click Process > Generate Contour Lines DSM or DTM. The processes will be active once step 3. DSM, Orthomosaic and Index has been completed and if any contour lines format is selected in the processing options. For step-by-step instructions: How to generate the contour lines.
Important: The processes to generate the contour lines are grayed out if the raster digital surface model (DSM) or raster digital terrain model are not generated or merged.
For more information about the options of the raster DSM: Menu Process > Processing Options... > 3. DSM, Orthomosaic and Index > DSM and Orthomosaic.
For more information about the raster DTM: Menu Process > Processing Options... > 3. DSM, Orthomosaic and Index > Additional Outputs.
Note:
  • If contour lines with the same options are already generated, they will be overwritten.
  • If the Contour Lines have been selected in the processing options, they will be generated when processing step 3. DSM, Orthomosaic and Index.
