メニュー プロセス > 品質レポートの生成 -PIX4Dmapper
This article explains how to generate a quality report when using PIX4Dmapper.
Access: On the Menu bar, click
Process > Generate Quality Report (enabled once step
1. Initial Processing has been completed).
This process generates a new Quality Report that refers to the new reconstruction obtained after applying changes to the project once step 1. Initial Processing has been completed. Such changes can be:
- Adding GCPs.
- Adding Manual Tie Points.
- Adding Check Points.
- Changing coordinate systems.
- Enabling/disabling images.
- Running the Rematch and Optimize option.
Important: When adding GCPs, Manual Tie Points, Check Points, changing coordinate systems, or enabling/disabling images, the
Reoptimize option has to be applied before generating the new
Quality Report.
